RV.Net Open Roads Forum: Truck Campers: Truck questions
 > Truck questions
Mommalu
Mpls. MN
Posted: 07/01/19 07:38am Link  |  Quote  |  Print  |  Notify Moderator
Hello, be patient with me I belong on the A forum. The last 4 outings with our 32' gas Jayco Precept the wind has been 24 mph or greater.
I have the CDL love big vehicles and its my happy place to drive, However on the last outings my very DH uttered feelings I must explore. "This beast is NOT a road machine, everything needs to be planned & calculated, remember when we used to get in the car and just drive?"
We are planning to replace our F150 and DH thought bigger truck and then a camper might bring back the spontaneity we once had with travel.
My question is can any truck be set up for a truck camper, we're thinking 350 crew cab 6'6" bed gas 4x4 SWD. We typically find gently used vehicles, haven't seen any used with the camper option on them.
Also will we need to improve handling with after market products? We have added $4000 for the nasty F53 chassis which we will keep, we used it 45 days last year with week-end only state parks. It has its place just not a get in and drive for 2 weeks kind of vehicle. We're 10 years from retirement, have 6 weeks vacation so thinking its time for mad dashes thru the US and Canada, hoping a truck camper will meet that desire. Hubby not interested in a van or small C.
What are your thoughts? Thanks for the help.
Kayteg1
California > Nevada
Posted: 07/01/19 08:39am Link  |  Quote  |  Print  |  Notify Moderator
Short bed and SRW will drastically lower your camper choices and moving from 32' ClassA I doubt your wife will be happy with them.
Also new Fords 4x4 are pretty high, what not only adds steps to get to the camper, but issues with jacks length.
Buzzcut1
Norcal
Posted: 07/01/19 08:46am Link  |  Quote  |  Print  |  Notify Moderator
with the SRW you will pretty much be limited to the smaller lighter truck campers with less space and options. Essentially truck campers are heavy and you will exceed the tire load capacity unless you upgrade to commercial 19.5 wheels and tires. A dually in a long bed configuration gives you the most camper choices. Best advice is to find a camper that you both like first then shop for a truck that is capable of carrying it.
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 08 Lance 1055, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
Mommalu
Mpls. MN
Posted: 07/01/19 09:52am Link  |  Quote  |  Print  |  Notify Moderator
I understand the weight concerns, but truck will be a daily used vehicle and a dually does not appeal to either one of us, so its SWD.
Looking at campers for 150/1500's, just want A/C & furnace, hot water heater, shower big enough to get my elbows out to wash my hair, queen bed, double burner stove, 5 cf fridge.
This will be used where it's a different campground every night, tanks dumped & water added every morning so amenities tank size not so much a concern.
We are keeping the motorhome for extended stays.
jshupe
FT
Posted: 07/01/19 10:21am Link  |  Quote  |  Print  |  Notify Moderator
I had that line of thought for the last several years. Kept chasing good money after bad (suspension upgrades, 19.5" wheels/tires, etc) to make my daily driver SRW handle a DRW load. Recently picked up a DRW and have no idea why I waited so long. Both my wife and I are finding my new truck very easy to drive and I think the worries I had about a DRW were unfounded. I suggest you at least test drive one before you rule it out.
work2much
Jackson Ca
Posted: 07/01/19 10:46am Link  |  Quote  |  Print  |  Notify Moderator
There are short bed campers that will work fine on a 1 ton SB SRW. Lance makes 3 or 4 units like that. Adventurer 80 RB would be an option. Bigfoot 1500 series are well made.
Lot's of great options for a lightweight short bed truck.
Without the dually I would look for a non slide unit to keep the weight down. You will also most likely be dealing with a wet bath which can be a little more cramped than a dry shower. You will need to go see them and try them out.
2017 Ram 3500 Laramie CTD DRW Crew 4x4 Aisin 4:10 Air ride.
2018 Host Mammoth. 1080 Watts solar. 600 AH usable LFP battery. Magnum 2800 Watt inverter.
2020 Grand Design Solitude 2930RL 2400 watts solar. 600ah lithium. Magnum 4000 watt inverter.
twodownzero
NM
Posted: 07/01/19 11:06am Link  |  Quote  |  Print  |  Notify Moderator
Don't need camper option, just make sure you load within payload capacity and you will be fine. Don't listen to anyone who encourages overloading any truck.
If you want a slide truck camper, don't bother with an srw truck.
joerg68
St. Ingbert, Germany
Posted: 07/01/19 02:03pm Link  |  Quote  |  Print  |  Notify Moderator
These trucks are not really made for carrying campers. Just about any hardwall camper with the features you describe will be pushing the limits of a 150/1500.
With popup campers there are more to choose from.
Do not trust the dry weights stated by camper manufacturers. They are often just for a bare camper shell, without battery, LPG, any extras, your stuff, ...
Whatever you decide to do, make a realistic weight calculation - do not be overly optimistic.
work2much
Jackson Ca
Posted: 07/01/19 02:22pm Link  |  Quote  |  Print  |  Notify Moderator
From the OP's first post
OP is looking for a 1 ton SRW to replace the 150 not a camper for their 150.
I think in the follow up post they mean that they are looking at light campers marketed for 1/2 tons but will be putting it on a 1 ton. There are a number of "half ton" campers being marketed now. There suitability on a half ton may be up for discussion but they should certainly be fine on a 1 ton truck.
GeoBoy
Bennington
Posted: 07/01/19 02:27pm Link  |  Quote  |  Print  |  Notify Moderator
If your bound and determined to go SRW truck then look at a Northstar TC. If your bound and determined to go with a 150/1500 truck, then look at a Four Wheeler Granby/Hawk pop up camper.
 > Truck questions
