RV.Net Open Roads Forum: Tow Vehicles: Old truck vs new truck
Search only in Tow Vehicles
 > Old truck vs new truck
shum02
Burlington ON CDA
Posted: 07/04/19 09:17am Link  |  Quote  |  Print  |  Notify Moderator
I have over 250k miles on my 6.0L. The starter let go on me totally out of the blue while up at the yard bringing the camper back to the house to restock.
Long storey short it was 20 minutes to get the tow truck there to flat tow it home, so while waiting around phoned around for a starter, found one. 3 hours after having made the call for the tow truck I was back on the road having installed the starter myself which on the 6.0L took all of an hour to R&R.
Yea, once in a while....but I`d rather do that that spend almost 1K a month for the next 5 years on a new truck. It runs like a champ but wear items like starters, bearings, brakes, ball joints, tie rods, alternators........ are wear items, they wear out, can`t be avoided.
Your truck in my view is almost new. Maybe a little preemptive maintenance would be in order.
2006 F350 Lariat FX4 CC 4x4 PSD
2007 KZ2505QSS-F Outdoorsman
4x4ord
Alberta
Posted: 07/05/19 01:41am Link  |  Quote  |  Print  |  Notify Moderator
Fixing and running your 05 will definitely be less expensive than buying something newer. I'd buy a new diesel.
2017 F350 SRW Platinum short box 4x4.
B&W Companion
wvu_traveler
Charleston, WV
Posted: 07/05/19 06:20am Link  |  Quote  |  Print  |  Notify Moderator
Thanks all for the responses. May go out and drive a new F250 with a gas and see if I like it. My 2005 is completely stock other than AFE mouthpiece I had installed. If I had the tools and someplace to work on my own truck...id likely just keep my Chevy a few more years. With wife and kids....I just may buy new for piece of mind and go on with life. I don't think i'm brave enough to jump into a diesel of any brand with all the emission junk to deal with.
shum02
Burlington ON CDA
Posted: 07/05/19 08:12am Link  |  Quote  |  Print  |  Notify Moderator
That is what warranties are for.
wvu_traveler
Charleston, WV
Posted: 07/05/19 08:40am Link  |  Quote  |  Print  |  Notify Moderator
True, but I tend to hold onto them beyond the warranty period....and as a daily driver ill be beyond the warranty in 4 years. I don't worry too much about normal upkeep but its the big ticket items that scare me. (turbo, injectors, etc) I cant tolerate much of that. Maybe my current setup has spoiled me, even with its recent rash of expenses...some of its 1k repairs are nothing compared to having to replace a turbo, etc at dealer cost.
larry barnhart
wenatchee. wa usa
Posted: 07/05/19 09:45am Link  |  Quote  |  Print  |  Notify Moderator
We have lost money on every warranty including our 2001 alpenlite that was $1400 at a discount.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
kellem
Shenandoah valley,VA
Posted: 07/05/19 10:02am Link  |  Quote  |  Print  |  Notify Moderator
Newer trucks keep getting stronger and stronger and with better transmissions....but wow are they expensive.
I'm mechanically inclined and would likely keep the 6.0,good engines.
NWnative
Maple Valley, WA
Posted: 07/05/19 10:20am Link  |  Quote  |  Print  |  Notify Moderator
If you do, try and drive one with the 4.30 axle. They are hard to find (I special ordered mine). Tows very well with that combo.
2019 Ford F250 Lariat CrewCab Short Bed 4x4 - 6.2 Gas w/4.30 Axle
2016 Airstream Flying Cloud 30RB / Blue Ox Sway Pro / Rock Tamers
2017 Jeep Grand Cherokee Limited 4x4
shum02
Burlington ON CDA
Posted: 07/05/19 10:49am Link  |  Quote  |  Print  |  Notify Moderator
chevman
I'm talking factory OEM GM warranty, not aftermarket insurance policies. I'd never purchase or recommend one either.
Posted: 07/05/19 11:50am Link  |  Quote  |  Print  |  Notify Moderator
Wvu, you're overthinking it, IMO.
Did you think the same about your Lily Duramax when you bought it? Becasue intercoolers, overheating and injectors were "issues" with them.
You literally do not have more to worry about with a new diesel than the old one in your driveway. If you were talking 08 up to about 2013 I'd have a different answer.
Of course buy what you want, but financially, if your 05 is in otherwise great shape, you're money ahead to run it, even if you do sink a few grand into preventative repairs.
The Internet is good and bad. Now everyone has 1000% more things at their fingertips to worry about!
Gas trucks aren't magically problem free either. Most all new trucks ARE pretty problem free, but example my 2016 Silverado. If it was newer it would have been out of warranty when it spit out a bad transmission at 60k miles, without warning and with proper maintenance. I could look at the flip side and say if it was an Alli behind a Dmax, it wouldn't have happened.
03 Arctic Fox 860
07 Dodge 2500 deezul
"Obviously I don't want to overload my truck and be unsafe, but the reality is the truck is way more capable than the 10K GVWR they put on the sticker.
KJ"
