RV.Net Open Roads Forum: Fifth-Wheels: Late model truck for hauling a 5th wheel.
 > Late model truck for hauling a 5th wheel.
topjimmy
Washington Coast
Posted: 07/05/19 06:26pm Link  |  Quote  |  Print  |  Notify Moderator
That would be my answer as well, As far as the 2001-2004 Dmax Injectors most of them have been repaired by owner or replaced on GM's 10 year Warranty by now other than that the LB7's are one heck of a motor as I have had two of them along with my Fantastic 07 LBZ DMAX/Allison (in most peoples opinion the best DMAX made[emoticon]
KD4UPL wrote:
Define late model. If you're going newer than 2011 they are all pretty good. Prior to 2011 avoid the Ford diesels. If you're going way back avoid the Duramax from 2001 to 2004.5 the injectors were problematic. If you're going for a late '90s to mid 2000's Dodge avoid the automatics.
In my personal experience GM trucks have proven themselves extremely reliable. I don't buy them because I like the name, I buy them because they give good service in my business over and over again.
2015 Montana 3735MK Legacy,2004 2500HD GMC Short Bed, LB7 Duramax/Allison ,Pacbrake,Firestone Airbags Bullydog Tuner
jshupe
Austin, TX
Posted: 07/05/19 07:43pm Link  |  Quote  |  Print  |  Notify Moderator
Cummins12V98 wrote:
I did TNINK I wanted a Lartamie until I sat in the seats after setting in my Folks new LongHorn at Dave Smiths. I left with a LongHorn, now I have another.
I went to the dealer to test drive a Laramie and ended up taking home a Longhorn after DW wandered around the lot and sat in one. I don't recall a massive difference in seat comfort, but according to her there is a significant difference. We both liked the Longhorn better, as an overall package, enough to justify the price increase. We're talking 2019, so earlier models may be a bit different.
As for the op's question, they need to define what they consider "late model" and a budget. There are too many variables to narrow down a suggestion when we could be talking anywhere between 2009 and 2019, $20K and $100K.
2019 RAM 3500 Longhorn HO/AISIN 4x4 CCLB DRW | 2015 Keystone Alpine 3730FB
Random musings (blog): https://www.lifeenroute.com
Dtank
Posted: 07/09/19 01:01am Link  |  Quote  |  Print  |  Notify Moderator
spud1957 wrote:
My Gad man!! Do realize what this question will cause on this forum. Apparently you don't visit this site too often.
Ram owners will say Ram.
GM owners will say GM.
Ford owners will say Ford.
Late model to me is 2017+. Pick any. They are all great trucks. They all have there issues. Non no better than the other.
S
Well said !! (Except the last two sentences).
To the OP: Suggest you visit *any* of the diesel pickup forums for each brand (there are several for each).
Check the sections for the model and configuration you are considering. (Engines & trannys).
See what *problems* owners are having - how solved, repair costs, etc.
You won't find brand bashing - as the forum/s are for the same brand.
The can't agree with - last two sentences in your post:
Late model to me means "DEF" required. Pre 2006 is my preference.
Unfortunately the 6.0 Ford engines have a (deserved) bad reputation -
due to the "fixits" the factory would allow. Using after market (and after warranty) parts did way better than the factory!
My BIL is a retired GM employee - so, of course he has a (2003) Chevy diesel pickup. His major "after warranty" repair was injectors.
When he looked under the hood of my Dodge '05 CTD - first thing he said was, "You can actually SEE the engine!"
If I was buying new (or "late model") now - it would most likely be a gas burner - or if I was towing heavy, an HDT (way less $ than a new pickup).
Roll on!
[emoticon]
laknox
Arizona
Posted: 07/09/19 11:21am Link  |  Quote  |  Print  |  Notify Moderator
My personal preference is an LBZ Duramax, but you know how hard one is to find that's 1) NOT a dually and 2) a short bed? Were my '02 in a bit better condition, I've seriously thought about buying an LBZ from a wreck an swapping it out. Biggest issue is that I'd have to install a TapShift of some sort, or change the steering column, due to the 6 speed Allie vs the 5 speed I have.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 61 Year Member
Allworth
Orlando, FL
Posted: 07/10/19 10:28am Link  |  Quote  |  Print  |  Notify Moderator
Oh Six and a half LBZ.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
2008 Titanium 30E35SA; EZ-Lube axles; wet bolts; spring hanger gussetts; BFG Commercial TAs
"Real Jeeps have round headlights"
