RV.Net Open Roads Forum: Honda 2000: surprisingly poor oil fill tube design
 > Honda 2000: surprisingly poor oil fill tube design
Page of 5
larry barnhart
wenatchee. wa usa
Posted: 07/04/19 12:55pm Link  |  Quote  |  Print  |  Notify Moderator
our honda 1000i will get it's oil changed before we hit the road for Az. Not that hard but easy to have a little clean up. Not much of a chance It will be running but nice to keep it ready.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
NRALIFR
Truck Camping Out West
Posted: 07/04/19 02:23pm Link  |  Quote  |  Print  |  Notify Moderator
profdant139 wrote:
OK -- now I get it. Suboptimal design is no big deal .........
Well, in my ever so humble opinion, it’s a more common issue than you think. At least based on my experience, it’s something that I’ve dealt with on so many small engines that the occasional good design gets my attention.
I’ve had many small engine driven devices that you couldn’t drain the oil without getting the used oil on stuff you really don’t want oil on (like belts). My Yamaha 1000 gen is just like your Honda, which is why I suggested the oil fill process I did. My Husqvarna lawnmower has no oil drain plug at all. If you do something less than brilliant like not get the dipstick cap twisted on right and you don’t notice that it was loose the whole time you were mowing the grass until you’re done, and you just KNOW dirt got down in there, you get to turn the lawnmower upside down to drain the dirty oil. My truck has the oil drain plug on the side of the oil pan instead of the bottom, and if you misjudge how far out the oil is going to shoot when you remove the plug you’ve got a big mess on the floor.
My tractor has a nice oil drain system. A valve rather than a plug, and a tube that stays connected to the valve to direct the old oil right into the pan without splattering.
[emoticon][emoticon]
2001 Lance 1121 on a 2016 F450
Home Skillet
Pearland Texas
Posted: 07/04/19 04:45pm Link  |  Quote  |  Print  |  Notify Moderator
Cummins12V98 wrote:
Drain the engine, measure the exact ounces removed. Now add that exact same amount.
Nope.
What if the genny is burning oil?
2005 Gulf Stream Conquest 31ft
BigFoot Levelers,TST in tire TPMS,Bilstein Shocks,Trans temp guage,Lowrace iWAY
Cummins12V98
on the road
Posted: 07/04/19 07:07pm Link  |  Quote  |  Print  |  Notify Moderator
Home Skillet wrote:
Nope.
Maybe next time you READ what i said. Maybe next time you quote you include EVERYTHING I said pertaining to the subject you are referring to!!!
THIS is what i said, THIS is what you should have quoted!!!
GOT IT????????
"More better way is to verify it's full before draining. Drain the engine, measure the exact ounces removed. Now add that exact same amount."
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
MFL
Midwest
Posted: 07/04/19 07:43pm Link  |  Quote  |  Print  |  Notify Moderator
My over fill/spill came filling first time when new. Mine was filled at factory, run/tested, then drained before shipping. I went by amount in manual, to fill, and second guessed a small amount of residual not drained at factory. I guessed right on after break in, when draining refilling, due to knowing exact amount, that was just a bit much. I did catch every last drop in my small pan, so yes, measuring the exact amount in pan would work well.
Jerry
Cummins12V98
on the road
Posted: 07/05/19 06:06am Link  |  Quote  |  Print  |  Notify Moderator
" I did catch every last drop in my small pan"
THANK GOD!!!
Cummins12V98
on the road
Posted: 07/05/19 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
Drained mine today. First verified it was full. I propped up the back side to the point it almost tipped over. I had a pc of tin under the drain area. Had it up on a folding table. Drained into the measuring device filled it up with 13 OZ +old oil. Spec is 13.2 OZ. Cleaned out dispenser and refilled with 13 + OZ AMZ/OIL 15-40 Diesel Marine non LE oil.
mikestock
Vestavia Hills, AL, USA
Posted: 07/06/19 12:50pm Link  |  Quote  |  Print  |  Notify Moderator
Been using my pair for years. Measure the amount I put in every time. Use a long funnel. Never thought to complain. Do in my neighbor's driveway, just in case. JK
SidecarFlip
SE Michigan
Posted: 07/06/19 02:05pm Link  |  Quote  |  Print  |  Notify Moderator
Seems as though every small engine has the same fill / level setup. Haven't you noticed your lawnmower is the same deal.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
noteven
Turtle Island
Posted: 07/06/19 07:31pm Link  |  Quote  |  Print  |  Notify Moderator
I keep my drain pan handy, pour in what looks like enough new oil, tip er back level if any overage I drain it inta the pan. I package the wasteoil forproper disposal then clean up the drain pan and sneak it back inta the kitchen.
Page of 5
