RV.Net Open Roads Forum: Honda 2000: surprisingly poor oil fill tube design
 > Honda 2000: surprisingly poor oil fill tube design
Page of 5
SidecarFlip
SE Michigan
Posted: 07/06/19 08:43pm Link  |  Quote  |  Print  |  Notify Moderator
noteven wrote:
I keep my drain pan handy, pour in what looks like enough new oil, tip er back level if any overage I drain it inta the pan. I package the wasteoil forproper disposal then clean up the drain pan and sneak it back inta the kitchen.
I won't tell on you if you don't tell on me....lol
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
Homeless by Choice
North America
Posted: 07/07/19 09:35am Link  |  Quote  |  Print  |  Notify Moderator
I believe that is what God had in mind when He encouraged the design of dishwashers.
LeRoy
Homeless by Choice
FULL TIMER since 2012
2015 Chevy 3500, Duramax, 4X4, DRW, Crew cab, Long bed
2013 Northern Lite 8'11"Q Sportsman truck camper
2015 Polaris RZR Side by Side
3 tons
NV.
Posted: 07/07/19 02:11pm Link  |  Quote  |  Print  |  Notify Moderator
4 pages on oil filler?? lol
Crabbypatty
Long Island, New York
Posted: 07/08/19 04:08am Link  |  Quote  |  Print  |  Notify Moderator
Ive had an oil change "pump", since owning a boat with a v6 down below. I use it on the 2000 as well as other small motors. Start it up, warm up the oil, turn off, then suck out the oil. Putting oil back in i use a funnel and look, add some, look add some.
John, Lisa & Tara">">">
2015 F250 4x4 6.2L 6 spd 3.73s, CC Short Bed, Pullrite Slide 2700, 648 Wts Solar, 4 T-125s, 2000 Watt Xantrax Inverter, Trimetric 2030 Meter, LED Lights, Hawkings Smart Repeater, Wilson Extreme Cellular Repeater, Beer, Ribs, Smoker
SidecarFlip
SE Michigan
Posted: 07/08/19 07:42am Link  |  Quote  |  Print  |  Notify Moderator
Bored to tears.....[emoticon]
Cummins12V98
on the road
Posted: 07/08/19 09:56am Link  |  Quote  |  Print  |  Notify Moderator
I just used my Fumoto valve I installed on my 350 Boat engine last year (it was a mess). Slip hose on Fumoto run thru transom and into container and open the valve = GOLDEN!!!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
2manytoyz
Central FL
Posted: 07/08/19 10:37am Link  |  Quote  |  Print  |  Notify Moderator
My Yamaha and Champion generators are the same.
Here's my method:
Purchased on Amazon: https://amzn.to/2Jx6p2r
The blue part of the funnel is a valve. Open it only as much as needed, close it when the generator is full. No mess, no fuss.
Robert
Merritt Island, FL
2015 Forest River Georgetown 328TS
2006 Jeep Wrangler Unlimited TOAD
Falcon 2 Towbar, Roadmaster 9400 Even Brake System
http://www.2manytoyz.com/
3 tons
NV.
Posted: 07/08/19 02:20pm Link  |  Quote  |  Print  |  Notify Moderator
Luckly I found the ideal fix for this ubiquitous pandemic malady - I use a widely available $0.69 kitchen funnel, and pay close interactive attention to the task at hand - after many oil changes, I’ve found this method to be nearly error free...
dieseltruckdriver
Black Hills of SD
Posted: 07/08/19 07:42pm Link  |  Quote  |  Print  |  Notify Moderator
If you change your settings, it's only two pages. [emoticon]
I have a lot of years, and a lot of hours on both my Hondas, and never found oil changes to be difficult.
2000 F-250 7.3 Powerstroke
2018 Arctic Fox 27-5L
rickhise
home
Posted: 07/08/19 07:57pm Link  |  Quote  |  Print  |  Notify Moderator
RAS43 wrote:
NRALIFR wrote:
Make it easy on yourself and measure out the correct quantity of oil (yours is about 13.5 oz), tip the generator on it’s side and use a long neck funnel to pour it in. Put the cap on and don’t bother checking the level against the filler hole.
Your generator has a low oil level warning system on it that will shut the engine down before it reaches an unsafe level.
[emoticon][emoticon]
This!!
Ditto use a dawn dish soap bottle put a piece of duct tape even with 13.5 ounce level
funnel. I stuff a few paper towels inside the filler an case tip it over and let it drain in a towel on a flat baking dish
No need to check the level
Page of 5
