RV.Net Open Roads Forum: Tech Issues: Coleman Mach Air conditioner fan problem???
 > Coleman Mach Air conditioner fan problem???
jolooote
Miami, FL
Posted: 07/03/19 05:48pm Link  |  Quote  |  Print  |  Notify Moderator
Hi all. 2015 Thor Vegas, 15K BTU AC. All worked B4 I started work. Just got done cleaning the roof Ac fins. Removed roof plastic cover, Removed tin sheet metal cover over the Evaporator? fins. Cleaned em. Put all back together. Now, got nothing when indoor thermostate is on FAN, any position, Auto, Manual, Fast or lo. But, When in the AC position the fan runs in only the LO position. The compressor runs in both Lo and HI. WHAT have I done?[emoticon]
Shoulda listened to my dads advise. "If it ain't broke ...DON'T fix it!"
Joe & Charlotte
2020 Jayco Greyhawk Prestige 29MV Celestial Blue Full Body Paint E-450 305hp V10 6spd Class C 'COACH'
2012 Jeep Wrangler 285hp V6 'TOAD'
Gabby & Molly are Dogs
Leroy's a Conure, Loretta's a Squeaker
"Once it starts breakin'...GET RID OF IT!!!"
newman fulltimer
louisiana
Posted: 07/03/19 06:37pm Link  |  Quote  |  Print  |  Notify Moderator
Look at the box where the filter is sounds like you knocked a wire loose
Lone Pine, CA
Posted: 07/03/19 07:15pm Link  |  Quote  |  Print  |  Notify Moderator
“Shoulda listened to my dads advise. "If it ain't broke ...DON'T fix it!"
Nope. Maintenance is important and necessary.
Winnebago 2101DS TT & 2019 Chevy Silverado LTZ Z71, 300 watts solar-parallel & MPPT, Trojan T-125s. TALL pole for flags. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - old MOS 1542 & 1560.
jolooote
Miami, FL
Posted: 07/03/19 09:04pm Link  |  Quote  |  Print  |  Notify Moderator
opps, I'm in 'Roads and Routes'. Thout it was Tech. Issues. Sorry.
DFord
Near St Louis, MO
Posted: 07/03/19 09:21pm Link  |  Quote  |  Print  |  Notify Moderator
Whether the fan runs or not is controlled by a relay. It probably has a center off position and either switches to high or low depending on what's selected on the thermostat. I could be more help if I knew the brand/model of the a/c so I could find a wiring schematic.
Don Ford
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
cavie
Posted: 07/04/19 05:50am Link  |  Quote  |  Print  |  Notify Moderator
This should be your first clue You disturbed some wiring at the A/C. Got water into some connections? Knocked some wires loose?
jolooote
Miami, FL
Posted: 07/05/19 08:52pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks
dedmiston
Valencia
Posted: 07/08/19 07:02pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from Roads & Routes.
Wherever I happen to park
Posted: 07/09/19 06:44am Link  |  Quote  |  Print  |  Notify Moderator
First on Colemans you do not need to remove the sheet metal cover to clean the condenser. Colemans suck so the crud collects on the OUTSIDE and all you need remove is the outer shroud.
Sounds like yo knocked a wire loose but how you did that I don't know as there are no wires near the area you were working on
Check all plugs and connections.
Home is where I park it.
jolooote
Miami, FL
Posted: 07/10/19 09:51pm Link  |  Quote  |  Print  |  Notify Moderator
Yep, wiggled those wires, works now.
