RV.Net Open Roads Forum: Help needed- 1997 Bounder steering parts needed
 > Help needed- 1997 Bounder steering parts needed
Bounder-ing
Prairies
Posted: 07/03/19 11:13pm Link  |  Quote  |  Print  |  Notify Moderator
Hello all,
our mo-co-home, as the youngest calls it, needs some steering parts per shop's quote. The unit is a 1997 Fleetwood Bounder, 30ft, 454 gas, P3 chassis, 16,500lbs GVWR. It's our first motorhome, and while we/I did research them, I did not come across the difficulty in sourcing parts for them. i.e., parts being discontinued already.
While the unit tracks straight, has little steering play, no uneven tire wear, and is very easy to drive, it does make a racket going down the road so I don't doubt the shop's estimate.
1. Here's where I need most of your help please. Neither the shop nor I could find this discontinued "ROD KIT, STRG LNKG CONN, GM #19354911". Any ideas if there's a place where I can get this? I tried even many auto wrecks, but so far all of them did not keep an inventory of their motorhomes and would not search by chassis either.
2. I also need lower ball joints. Any suggestions for which ones to get?
3. Lastly, I need driver's side idler/bell crank, "ARM KIT STRG (CASTING #26033559 or #26053653, AC DELCO #26034753)". From what I read here Supersteer is the way to go. Any other suggestions?
I am fine buying from the US, although of course I'd prefer Canada due to rate exchange.
Thank you, and Happy 4th of July!
Branson N Tucson
Posted: 07/04/19 12:44am Link  |  Quote  |  Print  |  Notify Moderator
Try a Place called Vision Salvage RV parts. Located in Kentucky. Go on web. Bring up the inventory. They have a complete 1998 Blunder they are parting out. Shows the whole unit. Phone number 606 843 9889. They ship all over.
Great place largest RV salvage place in U.S.
Good luck.
mike brez
Unknown
Posted: 07/04/19 05:26am Link  |  Quote  |  Print  |  Notify Moderator
Try here alsox2 on the Supersteer bell crank. I'm sure they may even have the drag link.
Make sure you get the correct size ball joint there are two that are very similar.
* This post was edited 07/04/19 05:41am by mike brez *
1998 36 foot Country Coach Magna #5499 Single slide
Gillig chassis with a series 40
02 Ford F250 7.3 with a few mods
2015 Wrangler JKU
newman fulltimer
louisiana
Posted: 07/04/19 06:27am Link  |  Quote  |  Print  |  Notify Moderator
Auto zone shows it all in stock and ebay has them as well
enblethen
Moses Lake, WA
Posted: 07/04/19 07:24am Link  |  Quote  |  Print  |  Notify Moderator
Try these people in the Portland, OR area. They have a good selection of P-30partsDSU Workhorse
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
enblethen
Moses Lake, WA
Posted: 07/04/19 08:30am Link  |  Quote  |  Print  |  Notify Moderator
Be extremely careful on the ball joints. They are different from many listings. The ones listed are not the correct taper. The correct ones are shorter and have sharper taper.
tropical36
Southwest Florida_USA
Posted: 07/04/19 10:04am Link  |  Quote  |  Print  |  Notify Moderator
Bounder-ing wrote:
Hello all,
Your chassis is most likely a 96, which should be the same, but do check the VIN.
Noise is most likely coming from worn sway bar bushings and easily changed.
If you still have air bags, I strongly suggest you go with after market coils from Henderson and be done with it. Saves long term pain and money in the long run, as well.
check here for what you need and do call the vendor before they ship, with any questions.... AMAZON
Here's another of many sources .... GM P30
* This post was edited 07/04/19 10:11am by tropical36 *
"We are often so caught up in our destination that we forget to appreciate the journey."
07 Revolution LE 40E_Spartan MM_06 400HP C9 CAT_Allison 3000.
Dinghy_2010 Jeep Wrangler JKU ISLANDER.
1998 36ft. National Tropi-Cal Chevy Model 6350 (Sold)
RLS7201
Posted: 07/04/19 10:54am Link  |  Quote  |  Print  |  Notify Moderator
HendersonLineUp is the way to go for you P32 steering and suspension parts. Robert Henderson's custom bell cranks have been a tremendous asset to the P32 community.
At 76, I still do some part time front end work and have a lot of respect for Robert.
Richard
If I had a dollar for every girl that found me unattractive,
they would eventually, find me attractive.
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
Bounder-ing
Prairies
Posted: 07/04/19 11:51am Link  |  Quote  |  Print  |  Notify Moderator
Many many thanks for all your suggestions, your informative and quick replies make me feel better about RVing. My wife and I used to travel lots before the kids were born, now we thought to give RVing a try to accommodate the kids and dogs. So far we like it.
With your help I figured out what threw me off with the draglink. Based on my blown up suspension image from GM it seemed the draglink has an opening on the left side, and all I found was of course without, that hole was related to an adjacent part.
Tropical36, thank you for the advice on airbags. Previous owner had them removed and installed new springs. To my untrained eye the front is low, but this is on the back burner for now because the handling is great. I compare it to a previous E350 conversion van that wondered all over. I downloaded a pdf on how to measure this properly, will check it out later. Now I'm busy redoing the roof rubber and getting the steering sorted out. Plus the kids love the RV, we're busy doing short 3-5 days trips.
Richard, congrats on doing the work yourself. What's going on with PNW, there are many great shops there [emoticon] It's too bad they're about 1000 miles away. We were planning on going on a few weeks trip in the Rockies come August, on the Canadian side, but now I'm mapping out detours South. I didn't have a great experience with the shop who did the inspection, in their defense they work on semis not on RVs, but I'm limited given the rural area we live in.
I start to understand that I need to find a good RV shop. Any suggestions closer to Minot ND?
Ball joints wise, is going by VIN the way to go? I'm not sure how to tell the difference. Enblethen, Mike?
Thank you.
enblethen
Moses Lake, WA
Posted: 07/04/19 12:18pm Link  |  Quote  |  Print  |  Notify Moderator
Fellow poster here GJAC had major issue with ball joints. This link to Rare Parts available through Auto zone. Don't trust anybody except Rare Parts or Moog to get the correct ones bases not only for MH, but its weight and type of brakes in rear. Rear brakes for some reason makes different on front suspension.
Rare parts
