RV.Net Open Roads Forum: Help needed- 1997 Bounder steering parts needed
 > Help needed- 1997 Bounder steering parts needed
Gjac
Milford, CT
Posted: 07/04/19 01:52pm Link  |  Quote  |  Print  |  Notify Moderator
Be very careful when selecting Ball joints for your P-30 chassis. I have had two ball joint failures because a shop installed the wrong ball joints twice. One was at 60 mpg around a corner when the front end just collapsed and the MH almost rolled over. You probably won't find the correct OEM part number so you will look for the after market ones. Does you MH have disc brakes or drum brakes in the rear? The larger heavier P-30's had disc brakes the shorter lighter one had drum breaks. The ball joints are much different. If you have disc brakes on the rear of your P-30 chassis the part number you need is Moog K6511 for the lowers and K6174 for the uppers. Stay away from the Dorman ball joints they are all for the lighter chassis with drum breaks on the rear even though they say HD they are under size on the taper, this is what my shop at home installed and after about 5000 miles they work hardened from being loose in the taper and just failed. Henderson sells these ball joints. Also check your A arms for cracking. That is a whole other discussion. Good Luck.
enblethen
Moses Lake, WA
Posted: 07/04/19 03:15pm Link  |  Quote  |  Print  |  Notify Moderator
Gary, I thought you would have the numbers.
OP: I would try to get new control arms with the right joints installed. Takes time and money to have new joints pressed in your control arms.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Gjac
Milford, CT
Posted: 07/04/19 03:46pm Link  |  Quote  |  Print  |  Notify Moderator
. Hi Bud, I provided the numbers in my post. Maybe lost in the detail. They are K6511 and K 6174.
enblethen
Moses Lake, WA
Posted: 07/04/19 04:41pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, Gary! I saw them. I could not find my numbers.
Bounder-ing
Prairies
Posted: 07/04/19 11:16pm Link  |  Quote  |  Print  |  Notify Moderator
Yikes, glad you're OK. I went to the local NAPA, trucks division, and the parts guy told me frankly that he'd rather not order stuff because it's not guaranteed to fit. I thought he was too lazy, but I was wrong. Thank you for the parts numbers and advice, appreciated. It does have the discs on all four, so your numbers are what I need.
I will look for arms, didn't realize that is an issue either.
Gjac
Milford, CT
Posted: 07/05/19 07:46am Link  |  Quote  |  Print  |  Notify Moderator
If you need the arms you probably won't find the arms with the correct ball joint, said another way the arms will be correct but the ball joints will have to be replaced with the correct one. Check your ride height by measuring the distance between the bumper stop to the upper A arm you should have at least 1.5 ins on both sides.
mike brez
Unknown
Posted: 07/05/19 08:41am Link  |  Quote  |  Print  |  Notify Moderator
Some good info on the P chassis
Here and Here
1998 36 foot Country Coach Magna #5499 Single slide
Gillig chassis with a series 40
02 Ford F250 7.3 with a few mods
2015 Wrangler JKU
Bounder-ing
Prairies
Posted: 07/09/19 08:12pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks guys for the help and resources.
To add some info, one of the parts guys from SuperSteer said that they can't get the arms anymore, Moog doesn't have them in stock and there's no notice of when/if production resumes. He said the motorhome arms are different from the van ones, of course.
Once all the parts arrive I hope to have my MH sorted out for a couple years. After that I'll be looking for something that is more straight forward in terms of parts. I don't mind the cost, I knew things needed to be fixed, but this run around is a bit much.
enblethen
Moses Lake, WA
Posted: 07/09/19 08:23pm Link  |  Quote  |  Print  |  Notify Moderator
Did super steer have the moog control arm part numbers?
Check with Rare Parts!
Bounder-ing
Prairies
Posted: 07/09/19 08:38pm Link  |  Quote  |  Print  |  Notify Moderator
Nope,didn't think to ask for the number. I'll call tomorrow and post. The shop checked mine and they couldn't find any cracks so I stopped searching for them.
