RV.Net Open Roads Forum: Class C Motorhomes: Jayco slide out seal replacement
 > Jayco slide out seal replacement
map40
Posted: 07/06/19 08:16am Link  |  Quote  |  Print  |  Notify Moderator
Does somebody know what seal to buy for a Jayco Redhawk 2015 slide out? Wayyyy too many options. Any help will be greatly appreciated!
Alfa SeeYa, 2015 Jayco XL31, 2015 Itasca XL31, 2012 CA 25, 2008 CA 28. RV with most millage: 312K miles on a V10
Life rocks when your home rolls
IB853347201
Eastern Ontario
Posted: 07/06/19 08:39am Link  |  Quote  |  Print  |  Notify Moderator
Ask Jayco?
Touring in our 2010 Suncruiser, beaches, site seeing, national parks, chillaxing..
map40
Posted: 07/06/19 09:49am Link  |  Quote  |  Print  |  Notify Moderator
IB853347201 wrote:
Ask Jayco?
Thanks, kind of obvious, already did. You have to go to your local dealer (RV One for us) and they are terrible, they want $500 when the seal might be $50 at most, and they can’t guarantee delivery date because if their shop need it they will use the one they got for you and order another. As the scam EVERYBODY into replacing the seals weather needed or not, the only way to get it is to have them install it. Pretty good scam, isn’t it?
Their national distributors also have high prices. I am sure somebody makes them for them and sells them for a couple of bucks per foot, not $20 per foot...
bobndot
Posted: 07/06/19 10:06am Link  |  Quote  |  Print  |  Notify Moderator
I have never done that but I would think you have to identify the type of seal and identify the mfg. of the slide. Put the slide out about 1/2 way and look at it.
Like a two sided bulb seal with a squeegee . It installs over the framework.
or a double bulb seal, with a bulb inside and one outside, those I think glue on .
2 places to start looking :
getrvparts.com
Trimlock.com
77rollalong
Brighton Ontario
Posted: 07/06/19 11:21am Link  |  Quote  |  Print  |  Notify Moderator
check with a company called steel rubber.. https://www.steelerubber.com/ and see what they have
pushtoy 2
texas
Posted: 07/07/19 09:15am Link  |  Quote  |  Print  |  Notify Moderator
good thought STEEL RUBBER PRODUCTS good source
DREAMER ">
