RV.Net Open Roads Forum: General RVing Issues: Axle Weight
 > Axle Weight
1L243
Oregon
Posted: 07/06/19 07:43pm Link  |  Quote  |  Print  |  Notify Moderator
Should combined axle weight be greater than rated GVW? In my case my axles are rated at 4400(x2) 8800 and my GVW is 9680.
2017 Coleman 300tq by Dutchman Toy Hauler. 34.5 feet long and under 10k Gross. 1999 Ford F250 2WD 7.3 4R100 DP Tuner, S&B Cold Air Intake, Gauges, 6.0 Trans Cooler, Air Bags.
DrewE
Vermont
Posted: 07/06/19 08:03pm Link  |  Quote  |  Print  |  Notify Moderator
For a trailer, some of the weight is carried by the tongue. Your axles would appear to be a little bit under their weight ratings when the trailer is at its gross vehicle weight rating.
For a car or truck or motorhome, the sum of the axle weight ratings should not be less than the GVWR. Often but not always they will be higher, giving some flexibility in weight balance when loading to the maximum rated load.
12th Man Fan
Flower Mound , Texas
Posted: 07/06/19 08:05pm Link  |  Quote  |  Print  |  Notify Moderator
You have to take your tongue weight off of that amount. Not sure the % of GVW on a TT.
2014 GMC Duramax 4X4 DRW Crew
2015 DRV Tradition
Mojave, Kern County, California
Posted: 07/06/19 08:36pm Link  |  Quote  |  Print  |  Notify Moderator
Too close for my comfort.
ppine
Northern Nevada
Posted: 07/07/19 07:29am Link  |  Quote  |  Print  |  Notify Moderator
YOu have a problem.
phillyg
SWFL
Posted: 07/07/19 08:43am Link  |  Quote  |  Print  |  Notify Moderator
If your tongue weight is 880lbs or less you should be okay WRT GVW. You still need to weigh your axles, then just tongue, to make sure. TT tongue weight should be within 9-15% of your actual towed weight.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
1L243
Oregon
Posted: 07/07/19 09:56am Link  |  Quote  |  Print  |  Notify Moderator
My tongue weight runs around 1400#
rk911
Wheaton IL
Posted: 07/07/19 12:57pm Link  |  Quote  |  Print  |  Notify Moderator
DrewE wrote:
...For a car or truck or motorhome, the sum of the axle weight ratings should not be less than the GVWR. Often but not always they will be higher, giving some flexibility in weight balance when loading to the maximum rated load.
I've seen up to a 500-lb difference between the GVWR and sum of the GAWRs on a MH. the difference is almost always the max tongue weight.
Rich
Ham Radio, Sport Pilot
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
ppine
Northern Nevada
Posted: 07/08/19 07:29am Link  |  Quote  |  Print  |  Notify Moderator
What happens when you park the trailer and disconnect it from your Tow Vehicle ? Then your exceeding the GVW for sure.
Vinman02
Okotoks, Alberta
Posted: 07/08/19 10:31pm Link  |  Quote  |  Print  |  Notify Moderator
Not really since the tongue is still supported independently of the axles.
2011 Ram 6.7 Cummins
2006 Arctic Fox 26X
Honda E2000i
Honda EU3000i
 > Axle Weight
