RV.Net Open Roads Forum: General RVing Issues: Axle Weight
 > Axle Weight
Wherever I happen to park
Posted: 07/09/19 06:51am Link  |  Quote  |  Print  |  Notify Moderator
THat sounds like a good design to me (Combined axle weight greater than max vehicle weight) Gives you a bit more flexibility in loading the rig.
I'd be worried if the combined axle weight was LESS.
Home is where I park it.
DrewE
Vermont
Posted: 07/09/19 08:30am Link  |  Quote  |  Print  |  Notify Moderator
rk911 wrote:
DrewE wrote:
...For a car or truck or motorhome, the sum of the axle weight ratings should not be less than the GVWR. Often but not always they will be higher, giving some flexibility in weight balance when loading to the maximum rated load.
I've seen up to a 500-lb difference between the GVWR and sum of the GAWRs on a MH. the difference is almost always the max tongue weight.
This has me a bit befuddled...
A motorhome has no tongue to carry some of its weight. If there's a hitch, any tongue weight of the attached applied to the hitch would "count" as vehicle weight, and needs to be accounted for in the GVWR and the GAWRs. The rest of the weight of the trailer is, of course, carried on the trailer's wheels.
I would be quite surprised to see any motorhome where the GVWR is greater than the sum of the GAWRs. There would be no safe way to load it to the maximum GVWR (or, more precisely, no way to do so without overloading an axle), which suggests that rating is improperly assigned.
Vinman02
Okotoks, Alberta
Posted: 07/09/19 10:34am Link  |  Quote  |  Print  |  Notify Moderator
The combined axle weight IS less than the GVW.
2011 Ram 6.7 Cummins
2006 Arctic Fox 26X
Honda E2000i
Honda EU3000i
1L243
Oregon
Posted: 07/09/19 11:41am Link  |  Quote  |  Print  |  Notify Moderator
The last time I weighed in the trailer axles came in at 8150. The rest of the weight sits on the truck as tongue weight of 1450.
That gets me just under the the rated axle combined weight of 8800 and just under the 9680 Gross trailer weight. I was thinking originally that the axles should exceed the combined trailer weight but I was not taking into account the tongue weight.
Good thing I only carry one bike or I would have to leave the beer at home...
2017 Coleman 300tq by Dutchman Toy Hauler. 34.5 feet long and under 10k Gross. 1999 Ford F250 2WD 7.3 4R100 DP Tuner, S&B Cold Air Intake, Gauges, 6.0 Trans Cooler, Air Bags.
 > Axle Weight
