RV.Net Open Roads Forum: Xantrex vs Magnum
GordonThree
Northern Michigan
Posted: 07/08/19 07:58am Link  |  Quote  |  Print  |  Notify Moderator
Sensata only seems to have a 24 volt hybrid, the MSH4024M ... their 48v products are all the standard without load support
2013 KZ Sportsmen Classic 200, 20 ft TT
2017 Ram 2500 4x4, 6.4 HEMI, 4.10 / Auto
GordonThree
Northern Michigan
Posted: 07/08/19 10:59am Link  |  Quote  |  Print  |  Notify Moderator
Another nock on Magnum, the internal fans are low quality and custom designed. Same size as a computer fan but the internal electronics are matched to the proprietary speed control that Magnum uses. A drop in replacement doesn't seem possible. This is from studying the subject watching repair videos.
I've noticed some bearing noises from mine, so I know a time bomb is ticking now.
pianotuna
Regina, SK, Canada
Posted: 07/08/19 11:27am Link  |  Quote  |  Print  |  Notify Moderator
Hi,
Here is a link to the manual:
https://www.magnum-dimensions.com/sites/........ner%20Manual%2C%20MSH3012RV%20Series.pdf
GordonThree, I looked online and the fans are $15 each.
https://inverterservicecenter.com/Shop-B........pair-Parts/MAGNUM-MS4448PAE-REPAIR-PARTS
Regards, Don
rickhise
home
Posted: 07/08/19 02:28pm Link  |  Quote  |  Print  |  Notify Moderator
Yes on pure sine wave. My neighbor is on his second frig they were both so new
Warranty was still there to save the day
I guess neither repair person realized the issue was a result of the inverter
Houseboat use.
When out most bounce 1/2 the day on inverter other half on Red Honda
In the day 2000 or so boat builders didn’t install pure sign waves in moderate range HB
rickhise
home
Ps did I miss the reply what is Hybrid mode? Thanks
rickhise
home
Posted: 07/08/19 02:50pm Link  |  Quote  |  Print  |  Notify Moderator
IMarine list just 28-12 at 1400$ plus
Amazon about 100$ higher
The 3000 12 volt pure sine wave Amazon 800$
GordonThree
Northern Michigan
Posted: 07/08/19 03:18pm Link  |  Quote  |  Print  |  Notify Moderator
Missed two replies, both Piano and I explained it on page one.
GordonThree
Northern Michigan
Posted: 07/08/19 03:19pm Link  |  Quote  |  Print  |  Notify Moderator
That's some sort of used unit or a scam.
KD4UPL
Swoope, VA
Posted: 07/08/19 04:18pm Link  |  Quote  |  Print  |  Notify Moderator
Magnum is a solid unit but probably on the lower end as far as features. Outback is nearly indestructible and has some fancier programming options. I have no experience with Victron.
Hybird mode:
If you're running a small generator and it won't power your load the inverter will "help" the generator by providing additional power to the load. It pulls this power from the batteries which are not being recharged while doing this. So, it only works for so long. Eventually, theoretically, your load drops to where the generator can handle it alone and the inverter recharges the batteries.
Itinerant1
Itinerant
Posted: 07/08/19 05:01pm Link  |  Quote  |  Print  |  Notify Moderator
My Magnum 3012 hybrid has been trouble free for the past 39 months using it everyday, never been turned off. No noisy bearings and no magic smoke. No complaints.
