RV.Net Open Roads Forum: Tow Vehicles: Jake vs Exhaust Brake
Search only in Tow Vehicles
 > Jake vs Exhaust Brake
Trixie47
Orlando, Fl
Posted: 07/08/19 12:25pm Link  |  Quote  |  Print  |  Notify Moderator
Pulling a 2012 39 ft. 5th wheel with a 2008 Chevy Silverado 3500 dwd. Question is: what is best ? Jake brake or Exhaust brake ?
2008 Chevrolet Silverado Crew Cab DW
2012 Keystone Avalanche...4 Slides
Ivylog
Blairsville, GA and WPB, FL.
Posted: 07/08/19 12:33pm Link  |  Quote  |  Print  |  Notify Moderator
A Jake Brake is better but I doubt they make one for your engine.
08 HR Navigator 45'
Sold 04 Dynasty after 14 great years.
[url=https://i.
ShinerBock
SATX
Posted: 07/08/19 12:36pm Link  |  Quote  |  Print  |  Notify Moderator
Jake, but it is more expensive and I doubt they make one for your engine as Ivylog stated. You might have to go the exhaust brake route
rhagfo
Portland, OR
Posted: 07/08/19 12:45pm Link  |  Quote  |  Print  |  Notify Moderator
What most refer to as a Jake Brake is an engine brake that alters valve timing, the only one I have seen offered for HD pickups is from PacBrake for the Cummins engine.
RoyJ
Vancouver, BC
Posted: 07/08/19 01:05pm Link  |  Quote  |  Print  |  Notify Moderator
A "Jake brake" is technically an engine brake, which opens the exhaust valve during TDC to purge the compressed air. It turns your engine into a giant air compressor.
Jacobs as a company also make exhaust brakes, which operate similar to the variable geometry turbo induced braking on OEM setups.
With light duty trucks, you only have one choice - exhaust. An engine brake is better, the best can produce almost as much retarding hp as the engine hp rating.
ib516
Canada - soon to be Costa Rica
Posted: 07/08/19 02:33pm Link  |  Quote  |  Print  |  Notify Moderator
You will find an actual exhaust brake (valve that goes in the exhaust and creates back pressure) for about $1000 and one that uses a computer box to close down your factory turbo like the new ones do for about $500.
Check out BD Diesel and Banks as two examples of the above.
Prev: 2010 Cougar 322QBS (junk)
02 Dodge 2500 4x4 5.9L CTD 3.55
07 Dodge 3500 4x4 SRW Mega 5.9L CTD 3.73
14 Ram 2500 4x4 Crew 6.4L Hemi 4.10
06 Chevy 1500 4x4 E-Cab 3.73 5.3L
All above are sold
Current: 07 Dodge 1500 5.7L Hemi 3.55 / 2010 Jayco 17z
Posted: 07/08/19 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
^ LMMs are not recommended to use a conventional inline butterfly valve exhaust brake. (Guessing other VVT diesels have a similar recommendation)
Not saying it wouldn't work, but everything I've seen in the past says no inline butterfly valve brakes with the emissions systems intact.
Either way, a $600 plug n play module like ib516 mentioned gets you a turbo brake without even getting your hands dirty or busting out a wrench!
Old-Biscuit
Verde Valley
Posted: 07/08/19 03:00pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2007 3500 with 5.9L Cummins --- tow a 14K 5th wheel
Have an 'exhaust brake'====4" electric solenoid actuated butterfly with a 2" spring loaded bypass butterfly that controls backpressure
GCVWR 22,000 (truck/trailer)....6% grade exhaust brake will hold downhill speed at 50 mph
BEST add on device I have done!!!!
4x4ord
Alberta
Posted: 07/08/19 03:24pm Link  |  Quote  |  Print  |  Notify Moderator
The exhaust brakes used on pick up trucks are all utilizing back pressure in the exhaust system. They create a little more reverse horsepower than what downshifting alone does. This little bit of added reverse horsepower is enough to make a huge difference on grade braking in an application when you are only holding back about 25000 lbs (combined weight of truck and trailer) on a typical highway grade. So for your application a simple exhaust brake consisting of a programer that controls the vanes on your turbo is all that is required. There is an exhaust brake made for the Ram that holds the exhaust valve off its seat during the compression stroke which is more effective than a standard exhaust brake but it is not the same as an engine decompression brake ... which is what has been traditionally referred to as a "Jake Brake".
2017 F350 SRW Platinum short box 4x4.
B&W Companion
KD4UPL
Swoope, VA
Posted: 07/08/19 04:08pm Link  |  Quote  |  Print  |  Notify Moderator
I would get the Banks Speed Brake. You just plug it in and it uses your turbo vanes as an exhaust brake. True Jake brakes are not available for pick-up trucks.
