RV.Net Open Roads Forum: Tow Vehicles: Jake vs Exhaust Brake
Search only in Tow Vehicles
 > Jake vs Exhaust Brake
ACZL
UPstate,NY
Posted: 07/09/19 02:09am Link  |  Quote  |  Print  |  Notify Moderator
Would take a heck of a lot of modding to stuff a engine that uses a Jake brake in a pick up. If I'm not mistaken, I think Cummins invented the Jake Brake and granted it's use for all semi engines but some mfr's may offer their own version of a Jake to which (IMO) aren't as good. A true Jake requires the engine to be between 1600-2000 to get the best retarding power. Exhaust brakes offered by Ford, GM & Ram are better than nothing and from what I gather, folks seem to be quite happy w/ them.
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
Allamakee1
Iowa
Posted: 07/09/19 01:32pm Link  |  Quote  |  Print  |  Notify Moderator
You can easily add a exhaust/turbo brake to an LMM with just a grounded wire from your ECM and switch to turn it on and off. No tune or delete needed. Programming is already there.
2010 Chevy D/A (LMM) CC-LTZ-Z71
Previous - 2014 Ram Ecodiesel Laramie
ktmrfs
Portland, Oregon
Posted: 07/09/19 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
ACZL wrote:
Would take a heck of a lot of modding to stuff a engine that uses a Jake brake in a pick up. If I'm not mistaken, I think Cummins invented the Jake Brake and granted it's use for all semi engines but some mfr's may offer their own version of a Jakeibetween 1600-2000 to get the best retarding power. Exhaust brakes offered by Ford, GM & Ram are better than nothing and from what I gather, folks seem to be quite happy w/ them.
Clessie Cummins, one of the founders of what became Cummins engine is credited with the invention of the jake brake in the late 50's. It was granted a patent in the early 60's. I think by that time he was not associated with Cummins and when he went looking for someone to market it, Jacobs mfg was the only taker, which, relates to how it got it's name, Jake brake. Jacobs started mfg it in about 1961 IIRC. BTW it's the same Jacobs that makes 3 jaw drill chucks.
2011 Keystone Outback 295RE
4x4ord
Alberta
Posted: 07/09/19 09:34pm Link  |  Quote  |  Print  |  Notify Moderator
It's hard to believe something more efficient such as electric motors and batteries haven't replaced it yet.
2017 F350 SRW Platinum short box 4x4.
B&W Companion
rhagfo
Portland, OR
Posted: 07/09/19 10:31pm Link  |  Quote  |  Print  |  Notify Moderator
Not so, PacBrake makes an engine brake for the Cummins 6.7 that is a bolt on kit. Looks like it raises the valve cover about 1-1/2”.
* This post was edited 07/09/19 11:22pm by rhagfo *
4x4ord
Alberta
Posted: 07/10/19 03:59am Link  |  Quote  |  Print  |  Notify Moderator
The PacBrake exhaust brake is not a compression release brake such as a "Jake Brake". It is a little more effective than a standard exhaust brake but both the PacBrake and a standard exhaust brake utilize the turbo vanes to create back pressure in the exhaust system to provide the engine braking. The engine brakes on the bigger diesels are far more effective. A pick up truck doesn't really have need for the level of braking provided by a "Jake".
Lynnmor
Red Lion
Posted: 07/10/19 07:05am Link  |  Quote  |  Print  |  Notify Moderator
So what is this thing?
wilber1
Abbotsford B.C.
Posted: 07/10/19 10:08am Link  |  Quote  |  Print  |  Notify Moderator
The Pacbrake LoadLeash holds the exhaust valve open on the compression stroke, allowing the exhaust brake to work on both the exhaust and compression strokes and eliminating the rebound effect of the power stroke. Only for the 6.7 Cummins though.
"Never trust a man who has not a single redeeming vice" WSC
2011 RAM 3500 SRW
2015 Grand Design Reflection 303RLS
4x4ord
Alberta
Posted: 07/10/19 10:45am Link  |  Quote  |  Print  |  Notify Moderator
They want us to believe it is similar to a "big rig" engine brake. It is more effective than a standard exhaust brake but it is still nothing like a jake brake. If you think of an engine as an air pump you can imagine how restricting the exhaust raises the pressure at which the volume of air is being pumped at and creates more braking. Downshifting speeds the engine up which causes the engine to pump more air which also creates more braking. The Packbake holds the exhaust valve off its seat during engine braking. So with the Pac brake the piston pushes air past the slightly opened exhaust valve causing braking on the compression stroke. The pressure on the piston would be equal to the exhaust back pressure created by the restriction at the turbo. The cylinder would refill through the slightly opened exhaust valve on the power stroke and then offer the same braking as a typical exhaust brake on the exhaust stroke. Again it is the power require to force the air past the turbo that is creating the braking.
A Jake brake uses a camshaft or hydraulic pressure to pop the exhaust valve open near top dead centre on the compression stroke preventing the energy in that compressed air from pushing down on the piston during the power stroke. The pressure on the top of the piston during the compression stroke is used to accomplish the engine braking and is much higher than the 60 psi or so that a PacBrake or typical exhaust brake utilize for braking.
LIKE2BUILD
Decatur
Posted: 07/10/19 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
Trixie47 wrote:
Pulling a 2012 39 ft. 5th wheel with a 2008 Chevy Silverado 3500 dwd. Question is: what is best ? Jake brake or Exhaust brake ?
I can't say what is 'best' on a Duramax. But I can attest that the factory exhaust brake on my Cummins works fantastic. I have pulled my 14,000lbs 5th wheel down a curvy, 9.5 mile long 10% grade. The OEM exhaust brake is rated at 230HP and it definitely did the job extremely well. I barely had to use the service brakes to keep my speed down and a few times had to give it throttle because the EB slowed me down too much.
KJ
2012 Sandpiper 32QBBS
'14 Ram 2500 | Crew Cab Long Bed| 4X4 | Cummins TurboDiesel
Curt Q20 with Ram 5th Wheel Prep
2000 Crownline 205BR
1997 Ranger Comanche 461VS
'96 Polaris SLT780 PWC
'94 Polaris SLT750 PWC
3 Wonderful Sons (18, 11, & 10)
1 forgiving wife!!!
