RV.Net Open Roads Forum: Best Location for MaxxAir Covers?
 > Best Location for MaxxAir Covers?
Mickeyfan0805
SE Wisconsin
Posted: 07/08/19 12:26pm Link  |  Quote  |  Print  |  Notify Moderator
We have a 35' bunkhouse with 4 vent locations. There is a vent in the front bedroom, one in the main cabin, and a third in the rear bunkhouse. The fourth is a fantastic fan in the bathroom.
I've picked up 2 MaxxAir covers and am trying to decide where to mount them. I will put one in the rear bunkhouse. I can't decide if the other should go in the main cabin or the front bedroom. I'd like to put it up front so that the cross-ventilation covers the entire rig, but I'm worried that the bedroom wall would interrupt too much of the flow (air could only flow through the two door). If I put it mid-cabin, however, the bedroom won't get any of the ventilation flow. I don't want to cover every vent, so I want to keep it to just the two (at least for now).
So, thoughts? Where would you locate them?
Ivylog
Blairsville, GA and WPB, FL.
Posted: 07/08/19 12:30pm Link  |  Quote  |  Print  |  Notify Moderator
Buy 2 more or put it over the Fantastic fan so you can run it when it rains.
08 HR Navigator 45'
Sold 04 Dynasty after 14 great years.
[url=https://i.
wildtoad
Blythewood, SC
Posted: 07/08/19 12:45pm Link  |  Quote  |  Print  |  Notify Moderator
Why not cover every vent? Helps cut down on heat, keep them open more often, helps keep the vent covers from damage.
Tom Wilds
Blythewood, SC
Mickeyfan0805
SE Wisconsin
Posted: 07/08/19 12:46pm Link  |  Quote  |  Print  |  Notify Moderator
Unfortunately, we don't run our fantastic fan much. It was installed in the bathroom (right above the toilet), so every time someone uses the toilet when its running, it sucks the stink right from the black tank when the toilet is flushed.
Oceano Dunes, CA
Posted: 07/08/19 01:02pm Link  |  Quote  |  Print  |  Notify Moderator
I agree. Buy two more.
IAMICHABOD
Sunny So Cal 90713
Posted: 07/08/19 01:03pm Link  |  Quote  |  Print  |  Notify Moderator
If only going for 2 I would put them on the ones that you open the most often.If not then get another one [emoticon]
Former El Monte RV Rental
Buying A Rental Class C
Chevrolet Based Class C
Wiscampsin
Wisconsin USA
Posted: 07/08/19 02:08pm Link  |  Quote  |  Print  |  Notify Moderator
That's the problem. Turn the fan off when using the toilet. Turn it back on after flushing only after the flapper is closed.
rrupert
NW PA
Posted: 07/08/19 03:23pm Link  |  Quote  |  Print  |  Notify Moderator
If you want to cover the Fantastic Fan vent you should get the cover made for the fan. It provides more venting area than the standard covers. I believe Maxair still handles them.
Rich and Joyce
2018 Jayco Jay Flight 21QB
2012 Ford F150 4X4 Supercrew EcoBoost
Reese Strait-Line Dual Cam Hitch
Amateur Radio K3EXU
maddog348
Bakersfield,CA
Posted: 07/08/19 06:28pm Link  |  Quote  |  Print  |  Notify Moderator
WILDTOAD x 2
philh
Belleville MI
Posted: 07/08/19 07:55pm Link  |  Quote  |  Print  |  Notify Moderator
Covers are cheap
