RV.Net Open Roads Forum: Best Location for MaxxAir Covers?
 > Best Location for MaxxAir Covers?
DFord
Near St Louis, MO
Posted: 07/08/19 08:47pm Link  |  Quote  |  Print  |  Notify Moderator
The original vent covers don't hold up - the sun destroys them in short order. Save yourself some grief and put covers over all the vents. Like has been said, they're cheap - and a lot cheaper than opening up your RV only to find the vent cover cracked open and let the rain in while it was in storage. Many RVs are ruined with this scenario and it happens way too often.
Don Ford
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
Lantley
Ellicott City, Maryland
Posted: 07/08/19 09:14pm Link  |  Quote  |  Print  |  Notify Moderator
Mickeyfan0805 wrote:
I don't want to cover every vent,
So, thoughts? Where would you locate them?
Why don't you want to cover every vent? Surely not the cost of the covers?
The simple solution is to get 2 more covers. If money is the issue use the 2 you have in your most used locations and save up for 2 more.
2019 Duramax w/hips,2012 Open Range,Titan Disc Brake
H-head TPMS,BD3,RV safepower,17" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps
Correct Trax,Splendide
Mickeyfan0805
SE Wisconsin
Posted: 07/09/19 11:26am Link  |  Quote  |  Print  |  Notify Moderator
Wiscampsin wrote:
so every time someone uses the toilet when its running, it sucks the stink right from the black tank when the toilet is flushed.
That's the problem. Turn the fan off when using the toilet. Turn it back on after flushing only after the flapper is closed.
If I didn't have 3 kids that seemed impossible to train in this area, I would - but no such luck! Believe me, we tried. They always forget.
Mickeyfan0805
SE Wisconsin
Posted: 07/09/19 11:28am Link  |  Quote  |  Print  |  Notify Moderator
No - it's a matter of blocking out the sunlight. I want to put a couple in to be able to travel with the air flowing and try to reduce the 'hotbox' factor when we arrive. That said, we like having the daylight come through from above, and I'm reluctant to cover all of the fans.
beemerphile1
Ohio
Posted: 07/09/19 01:58pm Link  |  Quote  |  Print  |  Notify Moderator
Cover all of them. The original vent lids have short lives if not covered.
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
mobeewan
Hampton, Va
Posted: 07/09/19 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
Exactly why you should cover all the vents. so you don't have to try to figure out which kid left the vent open whenever you open the trailer door and find the floor and everything around the vent soaked.
B.O. Plenty
Minnesota
Posted: 07/16/19 08:56pm Link  |  Quote  |  Print  |  Notify Moderator
Talked to a insurance adjuster one day about possible roof damage from a storm. He referred to them as "hail guards". Makes good sense to have them on all. The white ones let in a lot of light.
B.O.
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
2016 Cedar Creek 36CKTS
