RV.Net Open Roads Forum: Tech Issues: Dead battery so quickly?
 > Dead battery so quickly?
swimmer_spe
Sudbury, Ontario, Canada
Posted: 07/08/19 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
One of the trailers that I own is a 1975 model. I bought a brand new Code 24 battery. I was told it was fully charged. I hooked it up, and ran a fluorescent light for a few hours. The next day, the battery was stone dead.
What would cause this?
It does not have a fan running HVAC. It does not have any monitors. It only was used for 1 light for a few hours.
I am definitely bringing the battery back and getting them to help figure out of the battery is the problem.
BB_TX
McKinney, Texas
Posted: 07/08/19 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
What is the amp draw of that fluorescent light?
swimmer_spe
Posted: 07/08/19 07:40pm Link  |  Quote  |  Print  |  Notify Moderator
Honestly, I don't know, but when I had another battery that was the same, I could easily get a week or more without having to charge it.
rk911
Wheaton IL
Posted: 07/08/19 07:43pm Link  |  Quote  |  Print  |  Notify Moderator
- did you check the state of the charge after purchade?
- have you attempted to re-charge?
- current state of charge?
'73,
rich, n9dko
If Jimmy cracks corn and nobody cares then why does he keep doing it?
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
swimmer_spe
Posted: 07/08/19 07:45pm Link  |  Quote  |  Print  |  Notify Moderator
No
Not yet
dead.
I am learning not to trust someone when they say it is charged. I will have them do a load test prior to taking it.
Lone Pine, CA
What is the advertised amp hour capacity of the Code 24 battery?
“I was told it was fully charged.” That’s worth nothing.
Winnebago 2101DS TT & 2019 Chevy Silverado LTZ Z71, 300 watts solar-parallel & MPPT, Trojan T-125s. TALL pole for flags. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - old MOS 1542 & 1560.
rk911
Wheaton IL
Posted: 07/08/19 08:10pm Link  |  Quote  |  Print  |  Notify Moderator
me? i'd hook it to a charger and go from there. after charging let it rest for abt 15-min and then check the cells with a hydrometer.
it's one of three things..
- battery is defective. re-charging should answer that.
- battery wasn't fully charged when you bought it. re-charging should answer that.
- you had more of a draw than you thought.
* This post was edited 07/08/19 08:26pm by rk911 *
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 07/08/19 08:27pm Link  |  Quote  |  Print  |  Notify Moderator
You need more than guesswork to diagnose a problem. When I was testing batteries and rebuilding alternators customers went wild when I explained what failed.
Almost new 21 SI Delco alternator.
Stopped charging
Broken brush
Why?
Delco used pure carbon brushes. Super long and they were brittle
Replaced with St Mary's USA carbon copper brushes. Lasted longer no breakage ever.
Cost $0.09 more per brush than Delco.
Do something like that today?
LEARN how to troubleshoot or suffer fools. Your choice.
Shirley you jest.
swimmer_spe
Posted: 07/08/19 08:31pm Link  |  Quote  |  Print  |  Notify Moderator
Stopped charging
Broken brush
Why?
Shirley you jest.
Ok, so, what on a more than 40 year old trailer could kill a battery in one evening?
I am trying to isolate whether or not it is the battery. If it isn't the battery, then out comes the multimeter to find the problem.
Lone Pine, CA
Posted: 07/08/19 09:08pm Link  |  Quote  |  Print  |  Notify Moderator
“I am definitely bringing the battery back and getting them to help figure out of the battery is the problem.“
And if it’s not the battery, why should them figure out anything?
