RV.Net Open Roads Forum: Fridge On Propane Battery Amp Hr Draw??? How Much
 > Fridge On Propane Battery Amp Hr Draw??? How Much
Golferdude21
Illinois
Posted: 07/09/19 07:21am Link  |  Quote  |  Print  |  Notify Moderator
I have heard soo much regarding this its funny...Some say by running a fridge on propane only...that the circuit board and igniter should use very very lil of battery a day if running 24hrs on propane...others say it will take 20+AH a day...i am looking at boondocking and dry camping and wondering what the TRUE answer is. So I can buy batteries accordingly. I have a standard Dometic 2652 Fridge/Freezer. Is it 1-2ah a day or 20+AH a day? TIA
RobWNY
Jamestown, NY
Posted: 07/09/19 07:43am Link  |  Quote  |  Print  |  Notify Moderator
It can be either depending on your camping conditions. I just boondocked over the 4th of July and following weekend in temps that were in the low 90's during the day and low 70's at night. I used around 14-15 AH a day due to the fridge fan never shutting off. If I boondock when temps are in the 50's, I use a lot fewer AH to run the fridge. The fan alone will use about a .5 amp draw. Add that to what the circuit board and igniter power draw and you get to the numbers I saw.
You can't put a porcupine in a barn, set it on fire, and expect to make licorice.
Life is a lot like a baseball pitch. Sometimes you get a fast ball down the middle of the plate and sometimes you get a curve ball in the dirt.
wanderingaimlessly
SOBOVA
Posted: 07/09/19 07:53am Link  |  Quote  |  Print  |  Notify Moderator
Go with the best and largest battery bank you can reasonably afford and install.
Few if any are the complaints of,,,,,
Too much truck
Too much solar
Too much power
You may be able to find the rare instance of one, but in general the complaints are going the other way.
DrewE
Vermont
Posted: 07/09/19 08:21am Link  |  Quote  |  Print  |  Notify Moderator
It depends on the fridge (and its installation). Some have fans, some don't, for one thing.
If memory serves my fridge (whcih is a similar Dometic model) uses about 0.5A when the burner is operating, and maybe 0.2A when it is not. That works out to somewhere around 5-10 Ah per day. (That is without the "climate control" switch being on, which operates a little heating element around the door seals in case of excess condensation there; I never use it.)
If the fridge is in a slide, there are very often fans used in the installation that will consume additional power.
Sandia Man
Rio Rancho, NM
Posted: 07/09/19 09:29am Link  |  Quote  |  Print  |  Notify Moderator
Never measured daily amphour draw from our similar sized Dometic fridge, but on several occasions we have left our rig for a week and our pair of GC2 6 volt batteries had no problem keeping the fridge going, and that includes an interior fridge fan I wired in that runs 24 hours a day.
Sure, batteries were getting drained but still had more than half of their reserve capacity left, I have never considered our fridge much of a DC draw when boondocking. This type of RVing is all about restoring consumed amphours and requires a multipronged approach to successfully run your rig as if connected to the power grid.
SoundGuy
S Ontario
Posted: 07/11/19 06:10pm Link  |  Quote  |  Print  |  Notify Moderator
No such thing as a "standard" Dometic 2652 - could be an older RM2652 which does allow turning off the power robbing climate control heating element OR a newer DM2652 like that in my Coachmen Freedom Express that did still have the heating element but no switch to turn it off even though the schematic may show it does exist. If yours is one of the latter then you can add your own switch just as I did.
2012 Silverado 1500 Crew Cab
2014 Coachmen Freedom Express 192RBS
2003 Fleetwood Yuma * 2008 K-Z Spree 240BH-LX
2007 TrailCruiser C21RBH * 2000 Fleetwood Santa Fe
1998 Jayco 10UD * 1969 Coleman CT380
bsinmich
Holland, MI
Posted: 07/12/19 01:37pm Link  |  Quote  |  Print  |  Notify Moderator
In my 25 year old Roadtrek the frig runs on gas with no electricity involved. Itg is a 3 way frig. 110v, 12V, and LP. On 12V it will kill my lone battery in half the night. On LP it will run all summer on next to nothing.
Roadtrek Versatile. Old enough to vote and drink (gas)
time2roll
Posted: 07/12/19 01:50pm Link  |  Quote  |  Print  |  Notify Moderator
My trailer draws 500 milliamps at idle including the fridge cycled on, propane detector and radio memory. That would be 12 amp hours per day. Get at least twice what you need to avoid going under 50% when possible.
If you have a fridge humidity switch... that needs to be off.
Could always get a meter and measure what your RV draws. We can only estimates and guesses.
675w Solar pictures back up
allen8106
Burrton. KS
Posted: 07/16/19 11:05am Link  |  Quote  |  Print  |  Notify Moderator
I have 520 watts of solar and a battery monitor on my 5ver. My actual testing shows the refrigerator running on propane has such a small affect on the battery that it doesn't even register a change on the battery monitor.
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 36
steveh27
Grosse Pointe Woods, MI
Posted: 07/17/19 05:01am Link  |  Quote  |  Print  |  Notify Moderator
I wish Dometic would still make a fridge without electronic controls which draw electricity. My 22 year old RM2310 draws no power when on propane. It's new replacement draws around 2.5 amps which would kill my battery when boondocking.
