RV.Net Open Roads Forum: Class A Motorhomes: 100 amp service
 > 100 amp service
Page of 5
wolfe10
Posted: 07/10/19 10:59am Link  |  Quote  |  Print  |  Notify Moderator
Reisender wrote:
wolfe10 wrote:
Please tell us what RV you have/are considering that will not operate on 50 amp RV power???
I have seen some Bus chassis motorhomes with 5 AC’s. But even they are served by a 50 amp spit phase 240 volt pedestal. Other than “other than motor home needs” like an Electtic vehicle or portable grow op I can’t see the need for 100 amp service. Our townhouse is only 100 amp service and we have an electric range, electtic dryer, central air and two electric vehicle chargers. 100 amp would be a lot for a Motorhome.
Yup, without knowing what RV the OP has, we can only speculate if has one of the very rare, HUGE RV's with 3-4 roof A/C's, etc OR if he has a "regular" 50 amp coach (where 2 hots @ 50 amps each= 100 amps).
Inquiring minds want to know.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
CA Traveler
The Western States
Posted: 07/10/19 01:48pm Link  |  Quote  |  Print  |  Notify Moderator
Reisender wrote:
RV resorts (RV country club) in Indio (the new one) has 70 amp service pedestals. That’s the most I have seen. I would think it will get more common as people are starting to trailer Electric Vehicles. Nice to have an extra 16 amps available for overnight charging. Many portable EVSE’s are either 16 amp or setable to 16 amps.
A 50A pedestal implies 50A + 20A plugs - right?
I was under the impression that EVs require a 240V connection for faster charging rates. And most have non RV plugs but perhaps adapters are available.
Just curious.
2014 Grand Cherokee Overland
Bob
westernrvparkowner
montana
Posted: 07/10/19 02:02pm Link  |  Quote  |  Print  |  Notify Moderator
Have seen a couple of Newells that were 100 AMP service, that is with two 50 amp pigtails.. However, they were wired to accommodate standard 50 amp service should two 50 amp services not be available.
To answer the OP's question. You will likely seldom see a park with two 50 amp services at the site. It is much too expensive to run a second series of 50 amp services that will likely never, ever be used. Even if a park wired only one or two sites, they would likely to already be renting them to regular 50 amp rigs. No way would they consider keeping such a site vacant just hoping a white elephant showed up. ( it would have to be a very large site since any 100 Amp rig would be a 45 foot bus and all those are towing something). And no way would most parks allow running your generator. Unless you are in the $1,000,000 plus market, you aren't going to find a 100 amp RV. I will leave the gobblety-goop about 50 Amp service delivering 100 amps at 120 volts to others.
westernrvparkowner
montana
Posted: 07/10/19 02:09pm Link  |  Quote  |  Print  |  Notify Moderator
There is no such thing as a 70 amp pedestal in RV park terminology. Standard 50 amp service pedestals have a 50 amp outlet, a 30 amp outlet and a 15 or 20 amp duplex outlet (normal US home outlet with GFCI) You do not add together those outlets to get a different amperage rating. There may be a few boxes for home usage where there is an additional main breaker in the box that protects the entire circuit, but RV park wiring protects the main circuits at main breaker panels, not at the pedestals.
And, as always mentioned by me, most parks are not going to welcome charging of electric vehicles. Park wiring is not designed for such high amperage, long term draws in addition to the power demands of the RVs. We will make you unplug your electrical vehicles should we find them plugged in and so will many other parks.
Reisender
NA
Posted: 07/10/19 02:50pm Link  |  Quote  |  Print  |  Notify Moderator
Just curious.
In this case nope. The pedestals has true 70 amp service. 50 amp 240 volt for the coach via a Nema 14-50 outlet. As well as another 20 amp 240 volt to accomadate the small casita that is built on each site. Most folks have a washer and dryer in the casita.
Re the EVSE for electtic vehicle charging. They are sized from 120 volt 12 amp to 80 amp 240 volt. Many folks (us included) carry a 16 amp 240 volt portable EVSE that can plug into a Nema 14-50 with adapters that allow it to plug into almost anything including 20 amp, 30 amp, etc. The vast majority of EV’s can charge at a max rate of 32 amps or 7.7 KW and many charge at 6.6 KW (like ours). However there are some like the model S and X as well as long range model 3’s that can charge up to 48 amps using a hard wired EVSE. The highest power portable EVSE’s are 40 amp as they can plug into a Nema 14-50. Some EVSE’s are dipswitch or software setable from 8 amps to 40 amps.
As well, in the past, but there were some model S and X Tesla’s with 72 and 80 amp on board chargers. But those were rare and are no longer made. The new ones are either 32 amp for standard range or 48 amp for long range. Tesla’s charge rates are also adjustable on the car via the main screen.
Hope that helps . I’m not a very good explainer. Sorry.
Reisender
NA
Posted: 07/10/19 02:54pm Link  |  Quote  |  Print  |  Notify Moderator
Yah I get that. It should be up to the discretion of the park owner who knows his system best. However. Many RV parks are adding themselves to the plugshare APP. So at least some feel they are capable of carrying an extra 12 or 16 amps or whatever.
time2roll
Posted: 07/12/19 11:28pm Link  |  Quote  |  Print  |  Notify Moderator
I thought "50 amp" pedestals were commonly wired on a 200 to 400 amp loop. Each outlet is protected per rating at the pedestal. Loop is protected at the main panel.
675w Solar pictures back up
Mr.Mark
Out West and Mid South
Posted: 07/13/19 02:59pm Link  |  Quote  |  Print  |  Notify Moderator
way2roll wrote:
Do the all new Prevost/Newells etc electric coaches require 100 A service? Perhaps Mr Mark can chime in, I think his Prevost has a huge LI battery bank making his coach pretty much all electric.
FWIW - outside of winning the lottery - this is an issue I likely will never have to solve for.
Hello Way2roll!
Our coach, and as far as I know, all Liberty coaches are set-up with one 50 amp cord (100 amp which is 50 on each leg like all 50 amp coaches).
I do have to watch our power usage since we are all electric. We do have a diesel fired Espar furnace. Liberty does a good job balancing the legs so that I can use most items. With our 20K generator, I can run EVERYTHING plus I have a 30 amp connection for a 'buddy' coach if needed.
We do have 3 lithium Ion batteries that I can control the charging rate. I can pick from the following:
-220v/50amp
-110v/50amp
-110v/30amp
Currently I have the inverter/chargers (4 inverters) set on 110v/50amp as I'm in a huge storage garage with many other coaches. If all the coaches are 'sucking' power I didn't want the voltage to fall too much.
If we lose power and the batteries reach a 30% charge, I have the generator set to come on to recharge the batteries back to 100%. Once that is reached, the generator will cut off and start the process all over again until power is restored.
I did find out our house in CA has 200 amps. Since I had solar installed in March of 2017, we have not received a power bill and I've been paid back a little for 'over producing'. We have 63 roof panels.
Safe travels,
MM.
* This post was edited 07/13/19 03:18pm by Mr.Mark *
Mr.Mark
2015 Prevost Liberty Coach, 45 ft, 500 hp Volvo w/1,750 lb. ft. of torque, 1.5 baths, 4 slides.
2017 Lincoln MKX AWD V6 335 hp twin turbo.
Ivylog
Blairsville, GA and WPB, FL.
Posted: 07/13/19 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
OP has 9 posts after this one without bothering to reply. Why posting anything else?
08 HR Navigator 45'
Sold 04 Dynasty after 14 great years.
How I tow.
Towing a Prius without a dolly
How I spend the winter.
down home
south
Posted: 07/13/19 09:53pm Link  |  Quote  |  Print  |  Notify Moderator
Nothing to reply. Listening to answers, trying to figure out how hard it might be to find RV Parks/Resorts with 100 amp service. I hadn't thought about load center, perhaps shedding some load, if only one 50 amp is available, like our 50 amp does when on 30 amp pedestal.
We don't have that coach yet. As I said two years or so down the road, Lord willing. Don't know which coach builder or anything. Looked at some fellow RVers Newmars,a Marathon Coach, Liberty, I think and a couple of others brands.
Page of 5
 > 100 amp service
