RV.Net Open Roads Forum: Class A Motorhomes: 100 amp service
 > 100 amp service
Page of 5
Bill.Satellite
Full-timer
Posted: 07/14/19 05:43am Link  |  Quote  |  Print  |  Notify Moderator
down home wrote:
Nothing to reply. Listening to answers, trying to figure out how hard it might be to find RV Parks/Resorts with 100 amp service. I hadn't thought about load center, perhaps shedding some load, if only one 50 amp is available, like our 50 amp does when on 30 amp pedestal.
We don't have that coach yet. As I said two years or so down the road, Lord willing. Don't know which coach builder or anything. Looked at some fellow RVers Newmars,a Marathon Coach, Liberty, I think and a couple of others brands.
None of the coaches you list need 100 amp service so we are all curious what coach you might be looking at that does need 100 amp service.
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
down home
south
Posted: 07/14/19 07:01am Link  |  Quote  |  Print  |  Notify Moderator
We've looked at several coaches and two or three or so of them did. We didn't just look at coaches based on whether they were 100 amp coaches or not. Don't ask me the year of mfg but they were not more than a couple years old. Which ones I don't remember.
The coaches I posted were not the only coaches we looked at just a few that I remember.
* This post was edited 07/14/19 07:15am by down home *
down home
south
Posted: 07/14/19 07:32am Link  |  Quote  |  Print  |  Notify Moderator
Wife says she thinks the Liberty coach was one had two cords.
Reisender
NA
Posted: 07/14/19 07:49am Link  |  Quote  |  Print  |  Notify Moderator
I have no doubt they exist but they will certainly also be configurable to run with a single 50 amp 240 service. I wouldn’t worry about finding dual 50 amp sites. Just enjoy the journey and adapt.
I do think dual 50 amp sites will become more common as on site EV charging will become in demand. EV tow vehicles and small motorhomes will become more common in the next decade or two and there will be a market for campgrounds that provide on site charging.
Cheers.
Mr.Mark
Out West and Mid South
Posted: 07/14/19 08:20am Link  |  Quote  |  Print  |  Notify Moderator
I'm going to ask Liberty as I've never seen two 50 amp cords and I've looked at a lot of their coaches.
We do have a second cord that comes with the coach that I can connect to a socket at the passenger side rear in the event the shore cord on the driver's side is not working. It is a fairly long cord so it would be heavy to maneuver.
Our regular shore cord is very long (75 feet) so I 'could' connect where ever the 50 amp plug is located.
I'm not sure the reason why a regular full size electric coach would need a second cord unless there was a very special electrical device needing a lot of power.
I can run all four air units (13,500 btu) if I have good power at the pole. I have done that before on a very hot day but I was near the max on amps (about 85 amps). Some converters will put four 15,000 btu roof units which will be difficult to run all at the same time. Liberty has designed the ceiling venting to have no hard turns and run quiet and efficiently. You can certainly hear the air units but the volume of air coming out is amazing. Normally, 2 air units running is fine and 3 will freeze you out, 4 is really over-kill. But, its good to have redundancy.
Safe travels,
MM.
Mr.Mark
2015 Prevost Liberty Coach, 45 ft, 500 hp Volvo w/1,750 lb. ft. of torque, 1.5 baths, 4 slides.
2017 Lincoln MKX AWD V6 335 hp twin turbo.
Bill.Satellite
Full-timer
Posted: 07/14/19 02:50pm Link  |  Quote  |  Print  |  Notify Moderator
I still think you are confusing 50 amp coaches (which can utilize 100 amps) with a 100 amp coach (2 separate 50 amp cords). Unless the coach had 4-5 AC's on the roof and/or 240 cooktop(s) there would not be a need for a 100 amp coach.
Even Mr Marks' new 2 million dollar Prevost uses 50 amp shore power. If he runs his generator (or inverters from battery) he can utilize additional power but it would still be considered a 50 amp coach.
Mr.Mark
Posted: 07/14/19 03:27pm Link  |  Quote  |  Print  |  Notify Moderator
Bill, we cannot tap into the battery bank when on shore or generator power. The choices are shore, genny or inverting.
With the engine running, I will run an air or two as we have four alternators. But, the genny needs exercise and why not run that baby! At 4.5 yrs. of ownership, we have about 380 hrs. on it.
On the new Liberty's, my understanding that the power sources can be shared if needed. The new ones have the Volta Lithium Ion system which allowed them to reduce the size of the genny to a 12.5K Onan.
Safe travels!
MM.
mtofell1
Oregon
Posted: 07/14/19 03:29pm Link  |  Quote  |  Print  |  Notify Moderator
The way the RV industry has historically listed electric service size is very misleading to the average person. Any new person (and probably most experienced RVers) is going to automatically assume a 30A service is 3/5 as much as a 50A service.
The problem is the voltage is not listed right after it. Reading it like 30A @ 120V vs. 50A @ 240V is much more clear but I guess that takes to long to read and write.
down home
south
Posted: 07/14/19 04:15pm Link  |  Quote  |  Print  |  Notify Moderator
30 amp is 30 amp. 50 amp is two legs of fifty amps and a common ground not 100 amps total.
Mr.Mark
Posted: 07/14/19 05:41pm Link  |  Quote  |  Print  |  Notify Moderator
Well, 30 amp is really not 30 amp either. You get close to that and you will pop a breaker or the system will start shedding if it has that capability.
MM.
Page of 5
 > 100 amp service
