RV.Net Open Roads Forum: Fifth-Wheels: MORryde step question
 > MORryde step question
Toolguy5
Columbia Station, Ohio
Posted: 07/10/19 06:32am Link  |  Quote  |  Print  |  Notify Moderator
We have the MORyde steps. We are staying at a park that has a concrete patio but gravel spot. The patio sits up higher then the gravel spot 4 to 6 inches. I could not park so steps are on the patio because I could not get steps adjusted to be able to close the door.
Next time is there something I can do to make this work?
I thought about replacing them but I would have to cut the skirting directly under the door not wanting to do that.
Dan & Patty
Miss Pickles the Pomeranian Princess
2015 GMC 3500 Sierra Denali 6.6 Duramax / Allison tranny
2018 Jayco Northpoint 387 RDFS
B&W companion slider.
Maddy the Pampered Pom @ Rainbow Bridge 12-3-2013
Cummins12V98
on the road
Posted: 07/10/19 08:33am Link  |  Quote  |  Print  |  Notify Moderator
Sports Fans another negative to a compromise product!
Is it a quality made product, yup!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
ependydad
Here and there
Posted: 07/10/19 08:38am Link  |  Quote  |  Print  |  Notify Moderator
Sadly there's nothing you can do in this situation. All steps that contact the ground have a hard time accommodating this. However, I think the Torklift GlowSteps are a bit more forgiving.
Torklift does make a fold-up step similar to the MorRyde to make replacement easier. I'd guess you could get decent money for your MorRyde steps.
2017 Spartan 1245 by Prime Time
2012 Ram 3500 Crew Cab DRW w/ 4.10 gears and 8' bed
FW Hitch: B&W Turnover Ball + Companion
Learn to RV- learn about RVing - Towing Planner Calculators - Family Fulltiming FB page
laknox
Arizona
Posted: 07/10/19 09:13am Link  |  Quote  |  Print  |  Notify Moderator
x2! As I posted on the KZ forum, that's a deal-breaker for any brand that I might consider in the future...unless there's a delete option.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 61 Year Member
lee worsdell
elmvale
Posted: 07/10/19 09:19am Link  |  Quote  |  Print  |  Notify Moderator
I carry a 3ft piece of wood to put under legs,then I also have a small 24x24 platform I bring. Its made of 2x6 so works great
fj12ryder
Platte City, MO
Posted: 07/10/19 09:22am Link  |  Quote  |  Print  |  Notify Moderator
That wouldn't help the OP, his issue is his steps are too high and block the door from closing, not too low and need shimming up.
Howard and Peggy
"Don't Panic"
Toolguy5
Posted: 07/10/19 09:26am Link  |  Quote  |  Print  |  Notify Moderator
Ok I don’t understand how that will help!
The concrete pad is higher then the ground so if I park so steps come out on concrete they do not come out far enough to be able to close door.
Only solution I can see is to put boards under tires to raise coach higher before using auto level.
tom3171
Bayfield, Co USA
Posted: 07/10/19 09:42am Link  |  Quote  |  Print  |  Notify Moderator
We have a 2018 Flagstaff 526KSWC that came with MOR/ryde steps with strut assist. This is another example of an interesting idea that was not investigated for real-life use. As you know, unless you are parked on a perfectly straight spot and can fully adjust the steps and the feet, the door will probably not close. Not being able to close the door would not be good in a rainy or snowy situation. We used these steps for three trips and decided that we had enough of this nonsense, so we replaced them with a MOR/ryde two-step model without strut assist. This fit in our door opening without any skirt cutting. The height of our 5th wheel required that we add some plastic leveling blocks under the feet which is fine with us. This may be extreme to some people, but the positives outweighed the negatives.
opnspaces
San Diego Ca
Posted: 07/10/19 10:01am Link  |  Quote  |  Print  |  Notify Moderator
My only suggestion is one you've already arrived at. Put some blocks down to lift the whole coach off the ground. Well that is assuming you can't just park the RV another foot away from the concrete patio so the steps can come out fully.
1996 Suburban 4x4. 350, 4.10 3/4 ton
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
Toolguy5
Posted: 07/10/19 10:20am Link  |  Quote  |  Print  |  Notify Moderator
That is what I have done. But it would be nice to step out of coach onto the patio.
