RV.Net Open Roads Forum: Class A Motorhomes: 120 volt electrical outlets, no power.Help!
 > 120 volt electrical outlets, no power.Help!
captron33
usa
Posted: 07/10/19 12:59pm Link  |  Quote  |  Print  |  Notify Moderator
2006 travel supreme motorhome, i have checked all gvi plugs and they have power. The problem is no power to all our three tv areas. All other outlets have power.
enblethen
Moses Lake, WA
Posted: 07/10/19 01:15pm Link  |  Quote  |  Print  |  Notify Moderator
They could be powered through an inverter, if equipped.
Is it on?
Are the breakers on and not tripped?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
rgatijnet1
Posted: 07/10/19 01:24pm Link  |  Quote  |  Print  |  Notify Moderator
Don't some coaches have an interlock between the ignition and the TV's?
MountainAir05
New Mexico
Posted: 07/10/19 01:33pm Link  |  Quote  |  Print  |  Notify Moderator
Yes our 99 did. If the switch is on no power, It goes down to a relay located in the dash.
enblethen
Moses Lake, WA
Posted: 07/10/19 02:16pm Link  |  Quote  |  Print  |  Notify Moderator
Power disconnect for TVs are normally only for the ones that the driver can see.
captron33
usa
Posted: 07/10/19 03:15pm Link  |  Quote  |  Print  |  Notify Moderator
We are set up at rv park. Cb’s are in on the inverter. All other circuit breakers are in.
captron33
usa
Posted: 07/10/19 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
I took the box that disconnected the tv when the key was on the first day i had it.
Wherever I happen to park
Posted: 07/10/19 05:06pm Link  |  Quote  |  Print  |  Notify Moderator
I will go with the inverter option If you have an inverter it may be off. Fuse blown (DC) or circuit breaker (AC) tripped.
As others have said usually the ignition interlock (It's a relay in the outlet box the TV is plugged into) only applies to the FRONT TV where the driver can contort to see it.
Now I'm fond of saying many RVers have a few screws loose.... I had some A/C issues when my rig was new.. One of the screws in the power distribution center (Breaker box) took over 3 FULL TURNS before it was tight.> A/C worked much better after that.
Home is where I park it.
howdy35
Athens, Texas
Posted: 07/10/19 07:19pm Link  |  Quote  |  Print  |  Notify Moderator
I have two gfci breakers that will shut down power if tripped. Check to see if you have them and if they are tripped, reset them. That is a possibility. Please post the answer when you find it.Happy travels.
1999 National Tradewinds 7370
2014 Honda CR-V--Toad
Fulltime
MrWizard
Traveling
Posted: 07/10/19 09:10pm Link  |  Quote  |  Print  |  Notify Moderator
I knew one person with a travel supreme, lovely coach, all electric
It had 2 inverters running in tandom aka synced together
Do you have this option ?
Make sure both are turned on and operating correctly
Might try turning it/them off for ten minutes to do a reset
Radiate The Happy
1997 F53 Bounder 36s
