RV.Net Open Roads Forum: Class A Motorhomes: 120 volt electrical outlets, no power.Help!
 > 120 volt electrical outlets, no power.Help!
captron33
usa
Posted: 07/13/19 10:32pm Link  |  Quote  |  Print  |  Notify Moderator
Iwill try the inverter reset next.
captron33
usa
Posted: 07/18/19 08:27am Link  |  Quote  |  Print  |  Notify Moderator
Ok ,i did a inverter reset, all power off for 20. Minutes and no help. Maybe a broken or disconnected wire. Any other ideas.
enblethen
Moses Lake, WA
Posted: 07/18/19 09:52am Link  |  Quote  |  Print  |  Notify Moderator
Do you have one of the small receptacle testers? Little yellow plug in device. This will help telling whether it is getting power or whether one of the legs is open.
Use a volt meter and check to insure you have power out of the inverter(s)
Remove the gfci recptacles from the wall, test with voltmeter to verify that you have 120 volts AC on the load terminals. GFCI receptacles protect down stream devices with this function.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
captron33
usa
Posted: 07/22/19 01:14am Link  |  Quote  |  Print  |  Notify Moderator
Still no help
enblethen
Moses Lake, WA
Posted: 07/22/19 12:14pm Link  |  Quote  |  Print  |  Notify Moderator
Have you checked at the inverter circuit breakers for 120 volt power?
Have you checked each circuit brekers at 120 volt AC distribution panel for 120 volt output?
Use the small three light plug in tester at all other 120 volt receptacles to see if any others are dead
devildog1971
Rome
Posted: 07/22/19 09:58pm Link  |  Quote  |  Print  |  Notify Moderator
could be a bad G F I plugs both of mine went out at the same time bought three from home depot bad out of the box. do you have power with the generator on?
2019 Northern Lite 10-2 EXCDSE Dry Bath 2007 G M C dually crew cab and 2018 Harley Davidson Limited Low
captron33
usa
Posted: 07/22/19 10:32pm Link  |  Quote  |  Print  |  Notify Moderator
Have,t tried with only the gen. On. All other ideas have been verified.
enblethen
Moses Lake, WA
Posted: 07/23/19 07:03am Link  |  Quote  |  Print  |  Notify Moderator
Is thus an onboard genset or a portable?
If you have tried operating rig with onboard genset set only, you need to check for proper output from genset going to transfer switch.
Make and model of genset?
AllegroD
Outdare
Posted: 07/23/19 12:02pm Link  |  Quote  |  Print  |  Notify Moderator
* This post was edited 07/23/19 12:14pm by AllegroD *
captron33
usa
Posted: 08/20/19 02:32pm Link  |  Quote  |  Print  |  Notify Moderator
Ok. Good news!!! After 4 knowledgeable friends looked at and researched the problem, one made a second visit and in the breaker box happened to touch the wire and noticed it was loose. Sooooo
Tightened the set screw and fixed the issue. One loose screw caused several 120 volt outlets to not have power.
