RV.Net Open Roads Forum: Tech Issues: What gauge wire do I use
 > What gauge wire do I use
Page of 5
Campin LI
Long Island
Posted: 07/10/19 05:35pm Link  |  Quote  |  Print  |  Notify Moderator
Hello,
I want to place a 30 amp breaker in the panel of my house and then run about 200 ft of uf-b cable to a 30 amp rv outlet that I will place near my travel trailer. I would like to have the ability to use my travel trailer the same way as I would if I were at a full hookup campground.
What gauge wire should I use?
Thank you!
GordonThree
Northern Michigan
Posted: 07/10/19 06:06pm Link  |  Quote  |  Print  |  Notify Moderator
6/3 or heavier for the future.
2013 KZ Sportsmen Classic 200, 20 ft TT
2017 Ram 2500 4x4, 6.4 HEMI, 4.10 / Auto
Lone Pine, CA
Posted: 07/10/19 06:09pm Link  |  Quote  |  Print  |  Notify Moderator
Within reason no determent to using a larger gauge wire than the minimum.
Winnebago 2101DS TT & 2019 Chevy Silverado LTZ Z71, 300 watts solar-parallel & MPPT, Trojan T-125s. TALL pole for flags. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - old MOS 1542 & 1560.
Boomerweps
Hills of PA
Posted: 07/10/19 06:18pm Link  |  Quote  |  Print  |  Notify Moderator
Wonderful calculator at calculator.net. Voltage Drop Calculator. Plug in Amperage used, distance and wire gauge and it will tell you the voltage drop in volts and percent. If you drop to 105vac, you will be on the edge of damaging electric controls in your appliances. Voltage loss will depend on actual amperage used on that length and gauge wire.
Having an Electrical Management System like a Progressive Industries one will tell you actual voltage and protect from out of spec power. Even a Kil-a-watt via a 15-30 amp adapter will let you know of power variations as you turn on different appliances.
2019 Wolf Pup 16 BHS Limited
2019 F150 SCrew STX SB 5.0 factory tow package
Sam Spade
North Central Florida
With ground.
4 total conductors.
One spare unused with the 30 amp application.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
DFord
Near St Louis, MO
Posted: 07/10/19 06:38pm Link  |  Quote  |  Print  |  Notify Moderator
A search took me to: http://www.paigewire.com/pumpWireCalc.aspx where they recommended 4 AGW copper or 2 AGW aluminum for a 120 volt, 30 amp circuit at 200 ft with 3% tolerance. Change the tolerance to 5% and you can get by with 6 AGW copper wire.
http://wiresizecalculator.net/ came back with 3 AGW copper wire with a 3% tolerance or 6 AGW for 5% tolerance for direct burial.
3% of 120 = 3.7 volts - 120v - 3.7 = 116.3v
5% or 120 = 6 volts - 120v - 6 = 114v
I'd use the 5% tolerance figures.
https://www.calculator.net/voltage-drop-........0&distanceunit=feet&eres=30&x=48&y=29 Agrees with these figures.
* This post was edited 07/10/19 06:48pm by DFord *
Don Ford
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
Campin LI
Long Island
Posted: 07/10/19 06:39pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks. I was thinking 8, thinking 6 is a bit overkill. Why 6? Does 6 fit in a 30 amp breaker?
Campin LI
Long Island
Posted: 07/10/19 06:49pm Link  |  Quote  |  Print  |  Notify Moderator
I looked at calculators like what you described. The internet seems to complicate this subject with load calculations. My house was built having 15 amp circuits with 14 gauge wires and 20 amp circuits with 12 gauge wires. Nobody calculated any loads for each circuit - It's just standard code. I was thinking 30 amp circuit gets 10 guage but because my run is longer than 100 ft move up a size to get 8 gauge wire. The above poster mentioned 6 gauge which I also read but I also read the wire would need to be trimmed to fit in a 30 amp breaker. That's what makes me think that 6 guage is overkill. I just want to do it right. Thanks for all the input. I do appreciate it.
Campin LI
Long Island
Posted: 07/10/19 06:51pm Link  |  Quote  |  Print  |  Notify Moderator
https://www.calculator.net/voltage-drop-........=200&distanceunit=feet&eres=30&x=48&y=29 Agrees with these figures.
I just finished typing my response above and now see your. This is all to complicated for me to understand. There must be some kind of code or standard as I do not know what the load will be but I know it will be less than 30 amps since thats where my camper breaker will trip.
RJsfishin
Winston Or.
Posted: 07/10/19 07:02pm Link  |  Quote  |  Print  |  Notify Moderator
I have an RV pad at 100 feet, works great on 10 ga,.........I'd go 8 ga for 200 ft
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
Page of 5
