RV.Net Open Roads Forum: Fifth-Wheels: Tool Box
 > Tool Box
gdhoffman51
Posted: 07/10/19 05:38pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2019 Silverado 2500HD 4-Wheel Drive Crew Cab with a 6'6" bed. I want to install a 5th Wheel Pullrite #2700 Slider Hitch. Is there enough room to put a tool box behind the cab? If so what kind, make and model please.
Thanks
Greg
Ed9824v
Agua Dulce, Calif. 70 mi N.E. of Los Angeles
Posted: 07/10/19 05:43pm Link  |  Quote  |  Print  |  Notify Moderator
I have a toolbox behind my pullrite with a 6.5 foot Ram bed. You will have to test it out turning the hitch both directions.
Ed So.Calif
1950 Ford F1 street rod
1968 Baha Bug with 2.2 ecotec motor 170 hp, kingcoil
2000 National Sea Breeze 5th wheel trailer
1998.5 Dodge 2500 4x4 Cummins,4.10 gears,turbo,trans,injectors,oil cooler,lockers,edge EZ, 35" BFG's, air dog lift pump etc.
gdhoffman51
Posted: 07/10/19 05:45pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the info.....I haven't bought a tool box yet, just trying to see if it is possible.....
* This post was edited 07/10/19 05:53pm by gdhoffman51 *
Hearst San Simeon State Park
Posted: 07/10/19 06:15pm Link  |  Quote  |  Print  |  Notify Moderator
To paraphrase our former governor, the tools you wIll want to take will overfill whatever size tool box you install. A lathe and drill press are nice to have BTW.
Winnebago 2101DS TT & 2019 Chevy Silverado 1500 LTZ Z71, 300 watts solar-parallel & MPPT, Trojan T-125s. TALL pole for flags. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - (MOS 1542 & 1560)
Ed9824v
Posted: 07/10/19 06:33pm Link  |  Quote  |  Print  |  Notify Moderator
mine sits flush height with the fenders.
gdhoffman51
Posted: 07/10/19 06:47pm Link  |  Quote  |  Print  |  Notify Moderator
How deep is the box?
Ed9824v
Posted: 07/11/19 09:56am Link  |  Quote  |  Print  |  Notify Moderator
20.5 wide 19.5 tall
rhagfo
Portland, OR
Posted: 07/11/19 10:06am Link  |  Quote  |  Print  |  Notify Moderator
Install the hitch and measure the room you have to put one in.
Allworth
Orlando, FL
Posted: 07/11/19 10:52am Link  |  Quote  |  Print  |  Notify Moderator
If you search for tool "chest" rather than tool "box" you will find the ones that fit entirely down below the rails. No "wings" raising it above the truck box.
I first bought a winged version and it made visibility from the driver's seat a real problem. Luckily my son could use that one and a chest down in the bed made things better. Still some sightlines blocked, but much better.
Also, you can fit a soft tonneau cover over a chest. Not so with a winged box.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
2008 Titanium 30E35SA; EZ-Lube axles; wet bolts; spring hanger gussetts; BFG Commercial TAs
"Real Jeeps have round headlights"
bpounds
Sophmore Brain...
Posted: 07/11/19 11:40am Link  |  Quote  |  Print  |  Notify Moderator
Just went through a toolbox search. You can definitely fit a chest style, which does not extend up above the truck bed rails. The only question is what size will fit.
Take a look at this link below. This particular one would fit, but more importantly, scroll down to the bottom of the page and see the list of all their chest style sizes. Other brands have similar sizes.
Weatherguard Tool Chest
I think you could also use a low profile cross-bed saddle style, since you have a slider, and some of those are even narrower, as small as 16" wide and 13" deep. That shallow depth might be helpful to avoid the front hitch mounting rail or puck.
You'll be in a better position to search once you get your hitch mounted, but the short answer is you can definitely fit a toolbox.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
 > Tool Box
