RV.Net Open Roads Forum: Tow Vehicles: 2017+ Powerstroke 6.7 Fuel Filter
Search only in Tow Vehicles
 > 2017+ Powerstroke 6.7 Fuel Filter
Page of 6
Lynnmor
Red Lion
Posted: 07/13/19 07:27pm Link  |  Quote  |  Print  |  Notify Moderator
StirCrazy wrote:
the under hood filter is the same as on my 14, one of the eaisest fuel filters I have changed in a newer vehical. no special tools needed and very easy to get off. the only issue I have come up with is it hanging up in the bracket at times.
Steve
I believe that a 2014 has two fuel lines attached to the filter and the 2017 has three, with the added fuel line being the tiny fragile one.
4x4ord
Alberta
Posted: 07/14/19 03:36am Link  |  Quote  |  Print  |  Notify Moderator
I certainly don't have any interest in ordering and stocking spare parts that I will likely never use. I might change the primary filter once in the time I own a truck but it's unlikely I'll ever change the under hood filter.
2017 F350 SRW Platinum short box 4x4.
B&W Companion
harmanrk
Michigan
Posted: 07/14/19 06:15am Link  |  Quote  |  Print  |  Notify Moderator
When you buy the kit, it comes with both filters (You may be able to buy them individually, but I did not see that as an option when I ordered mine), so I don't know why you would not replace them together.
That said, I have the replacement filter in front of me, and it certainly appears that all three lines are sturdy. Yes, one is half the diameter as the others, but the plastic is nearly the same thickness.
2017 Ford F250 CC-SB SRW PSD
2013 Solaire 190x
rhagfo
Portland, OR
Posted: 07/14/19 07:16am Link  |  Quote  |  Print  |  Notify Moderator
Remind me never to buy a used vehicle from you!
Me Again
Sunbird(Wa)/snowbird(Az)
Posted: 07/14/19 08:00am Link  |  Quote  |  Print  |  Notify Moderator
Did you actual watch the video?
It is not the fitting in the filter that is the issue, it is with the quick disconnect fitting on the return hose that attaches to the filter.
StirCrazy
Kamloops, BC, Canada
Posted: 07/14/19 09:20pm Link  |  Quote  |  Print  |  Notify Moderator
Lynnmor wrote:
Steve
I will have to check, you might be right. I need to do my filters again in a couple weeks.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
4x4ord
Alberta
Posted: 07/14/19 10:36pm Link  |  Quote  |  Print  |  Notify Moderator
When I bought mine they came in kits as well but I don't change fuel filters unless i feel there is some reason to. So on one truck I changed the primary when I had a problem with the fuel gelling. Changing the primary was enough to get me going again. The other truck had its primary filter changed after putting DEF into the fuel tank. I disconnected the fuel line at the under hood filter and pumped all the fuel out of the truck through the low pressure side. After emptying the tank I changed the primary filter just to be sure I had gotten all the DEF out of the system. So far I haven't come across any need to change the fuel filter on my latest truck..... it only has about 25000 miles on it.
ksss
Eastern Idaho
Posted: 07/15/19 12:12am Link  |  Quote  |  Print  |  Notify Moderator
That is surprising you have not had an issue. I have had mine go into limp mode with a plugged fuel filter. I change it when the computer says to and use a GM filter that I have them install, easy enough to do, especially with the filter location on the L5P, but I want it documented. May be wasting some money on an install that I wouldn't have to, but it might pay me back some day.
2006 GMC 3500 CC 4X4 DRW D/A
2013 Fuzion 342
2011 RZR Desert Tan
2012 Sea Doo GTX 155
2018 Chevy 3500HD CC LB SRW 4X4 D/A
2015 Chevy Camaro ZL1
4x4ord
Alberta
Posted: 07/15/19 12:48am Link  |  Quote  |  Print  |  Notify Moderator
We order 65000 liters of fuel at a time and let it settle in the tank for a day after delivery before pumping it. We seldom see a fuel filter require changing on any of our equipment.
ksss
Eastern Idaho
Posted: 07/15/19 12:56am Link  |  Quote  |  Print  |  Notify Moderator
Still amazes me you get away with no filter changes.
Page of 6
