RV.Net Open Roads Forum: 18,000 BTU Suburban heater for a 30'x 8' cargo trailer?
 > 18,000 BTU Suburban heater for a 30'x 8' cargo trailer?
doublereefed
Midway, UT
Posted: 07/11/19 01:54pm Link  |  Quote  |  Print  |  Notify Moderator
Greetings,
I haul steam engines around in a 3 axle 30'x8' cargo trailer. I think the walls have foam insulation, but they are thin. The walls are carpeted. The floor is 3/4" plywood right on the steel frame.
Question: when we unload the steam engines we often camp in the trailer. We are doing our first cold weather trip... it could get down to freezing at the low. Do you think a 18,000 BTU Suburban heater would be able to heat that space?
***Link Removed***
Thanks,
Near USFS Glass Creek CG, Inyo County, CA
Posted: 07/11/19 02:13pm Link  |  Quote  |  Print  |  Notify Moderator
18000 BTUs will keep you warm but with marginal insulation it will run a bunch. Cold weather trip in July?
Winnebago 2101DS TT & 2019 Chevy Silverado LTZ Z71, 300 watts solar-parallel & MPPT, Trojan T-125s. TALL flagpole for flags. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - old MOS 1542 & 1560.
Old-Biscuit
Verde Valley
Posted: 07/11/19 02:26pm Link  |  Quote  |  Print  |  Notify Moderator
Nope...too wide open of a space.
No 'mass' to help absorb/retain heat (furniture, cabinets etc.)
No insulation under floor
18K btu would do OK for heating an area directly in front of discharge
IB853347201
Eastern Ontario
Posted: 07/11/19 02:28pm Link  |  Quote  |  Print  |  Notify Moderator
A 35000 btu model might do it
Roger10378
Goodrich, MI.
Posted: 07/11/19 02:47pm Link  |  Quote  |  Print  |  Notify Moderator
Sure it will heat that space, but only to about 20 deg above ambient. If you are looking for 65 deg or more you need twice that.
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
DFord
Near St Louis, MO
Posted: 07/11/19 03:05pm Link  |  Quote  |  Print  |  Notify Moderator
You could try insulating it. Just make sure to cover any exposed foam with something flame resistant for safety. Another thing to try would be to hang a curtain in your sleeping area to avoid heating the whole space.
Don Ford
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
AllegroD
Outdare
Posted: 07/11/19 04:04pm Link  |  Quote  |  Print  |  Notify Moderator
You could also remove the plywood, add some Dynamat style insulation to the floor and restore the plywood.
doublereefed
Midway, UT
Posted: 07/11/19 04:39pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you all for all the input and experience. I will look at larger units, and the idea of using a heavy curtain/partition will go a long way I think.
Posted: 07/11/19 04:55pm Link  |  Quote  |  Print  |  Notify Moderator
Twenty degrees above ambient is fine. We are camping!
ktmrfs
Portland, Oregon
Posted: 07/12/19 08:35am Link  |  Quote  |  Print  |  Notify Moderator
35K unit barely works in our TT down near freezing. IMHO 18K isn't going to make you happy. May keep you from freezing, but not be comfortable.
2011 Keystone Outback 295RE
