RV.Net Open Roads Forum: Fifth-Wheels: Cheater adapter to run 50 amp
 > Cheater adapter to run 50 amp
ceasare
staten island
Posted: 07/11/19 03:54pm Link  |  Quote  |  Print  |  Notify Moderator
We are at a campground that only has 30 amp. I tries one of those Chester adapters that have a 30 amp and 15 amp going into a 50 amp. Every time I plugged the 15 amp in it blew the surge protector on the outlet, Any ideas?
IB853347201
Eastern Ontario
Posted: 07/11/19 04:13pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah, those cheater adapters don't really work.
Touring in our 2010 Suncruiser, beaches, site seeing, national parks, chillaxing..
RobWNY
Jamestown, NY
Posted: 07/11/19 04:45pm Link  |  Quote  |  Print  |  Notify Moderator
I use a 30A to 50A adapter that works
but I've never used what you tried.
You can't put a porcupine in a barn, set it on fire, and expect to make licorice.
Life is a lot like a baseball pitch. Sometimes you get a fast ball down the middle of the plate and sometimes you get a curve ball in the dirt.
pianotuna
Regina, SK, Canada
Posted: 07/11/19 05:12pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
It depends on how the pedestal is wired. It won't work on a GFCI outlet, for example.
Regards, Don
frankwp
Calgary, AB, Canada
Posted: 07/11/19 05:25pm Link  |  Quote  |  Print  |  Notify Moderator
Some campground pedestals have the load side of the 30A breaker connected to the 30A receptacle as well as the line side of the 15A breaker. So a cheater cord won't gain you anything. All the load goes through the 30A breaker anyway.
2010 Cruiser CF30QB
2003 GM 2500HD, crew cab, SB, 8.1, Allison
naturist
Lynchburg, VA
Posted: 07/11/19 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah. No matter the wires or the plug, you can't draw 50 amps off a 15 amp circuit. Ain't gonna happen.
redhooker
Posted: 07/11/19 07:43pm Link  |  Quote  |  Print  |  Notify Moderator
The cheater does not advertise 50 amps. It simply connects 1 of your legs to the 30 amp and the second leg to a 15 or 20 amp. Obviously not 50/50amp legs as normal, but better than 15/15 off a dog bone. Enough to run 2 air conditioners IME.
Downfall is it trips ANY gfci protected outlet, which is at almost every campsite pedestal. Which is the OPs problem.
TXiceman
Full Time RVer
Posted: 07/11/19 08:13pm Link  |  Quote  |  Print  |  Notify Moderator
The cheaters don't work, especially if there is a GFCI. An energy management system will also fault.
Ken
Amateur Radio Operator.
Lantley
Ellicott City, Maryland
Posted: 07/11/19 08:51pm Link  |  Quote  |  Print  |  Notify Moderator
If you are just trying to connect to a 30 amp circuit use a simple 50 amp to 30 amp adapter.
If your trying to take advantage of the additional 20 amp outlet I suggest:
RV safe power transfer switch. Works with GFI outlets
The RVsafepower switch allows me to use both A/C's on 30 amp sites.
2019 Duramax w/hips,2012 Open Range,Titan Disc Brake
H-head TPMS,BD3,RV safepower,17" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps
Correct Trax,Splendide
RickLight
Washington
Posted: 07/11/19 09:41pm Link  |  Quote  |  Print  |  Notify Moderator
Their web site is malfunctioning. But from what I can see I wouldn't dream of using one of those. 2 AC's drawing 10-15A each can run on 30A, assuming you can get them started.
If a pedestal has only 30A of 120V then nothing can get more power. You can cheat the safety margins, overheat the wires, and risk damaging the entire campground system.
There are no techno devices to get around the laws of physics.
Rick,
2019 Grand Design Reflection 150 273MK
2015 Ford F350 CC SB Lariat Powerstroke
PullRite Superglide
