RV.Net Open Roads Forum: Class C Motorhomes: Class C steering stabilizer
 > Class C steering stabilizer
marty1300
florida
Posted: 07/12/19 05:24am Link  |  Quote  |  Print  |  Notify Moderator
Hello,
Inquiring as to what brand of steering stabilizer most choose. I see the two most common are by Roadmaster and Safe-T-Plus. We are getting a new Rv on the E450, chassis length is 31 feet
Thanks Marty
Marty
ron.dittmer
North-East Illinois
Posted: 07/12/19 05:39am Link  |  Quote  |  Print  |  Notify Moderator
Hi Marty,
Class-Cs that benefit most from a heavy duty steering stabilizer, are shorter rigs. Your rig being 31 feet long, will still benefit, but the problem is less prominent to begin with, especially if your wheel base is longer than average (for your length) and your rear overhang is less than average.
With that said, our short under-24 class B+ has a Safe-T-Plus and it is effective. I cannot speak of other lower priced options.
Two negatives for our Safe-T-Plus are...
1) high purchase price
2) no life-time warranty (just a one year warranty)
2007 Phoenix Cruiser model 2350, with 2006 Jeep Liberty in-tow
MDKMDK
Canada
Posted: 07/12/19 06:46am Link  |  Quote  |  Print  |  Notify Moderator
marty1300 wrote:
Hello,
Thanks Marty
All they are is a "return to center" set of helper springs that don't "stabilize" anything. I wouldn't waste my time or money on them. They're a gimmick, like those stovepipe things for your generator exhaust.
Just pay attention to where you're aiming the rig, with the factory steering, and you'll be fine.
Mike.
2018 (2017 Sprinter Cab Chassis) Navion24V + 2016 Wrangler JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
Desert Captain
Tucson
Posted: 07/12/19 07:22am Link  |  Quote  |  Print  |  Notify Moderator
Any quality new Class C should need absolutely nothing right off of the showroom floor with the possible exception of proper tire inflation and perhaps an alignment... both of which are the dealers fresponsibility. If it needs anything else it is the wrong Class C... keep shopping.
Think of it this way, would you spend $100,000 or likely much more on a nice Mercedes, BMW or Range Rover SUV if the salesman said "Well it will need a couple of thousand dollars worth of suspension improvements, an alignment and the tires need to be properly inflated"??? [emoticon]
A serious, think 1 hour minimum test ride in a wide variety of road conditions to include some freeway time {see how it responds to passing trucks and how much fun merging is or isn't} should be a nonnegotiable condition of sale. If after making your best deal the dealer balks at the test drive Run Forrest Run! Go find a dealer who is willing to earn your business.
As always... Opinions and YMMV.
[emoticon]
Harvard
51.6N 114.7W
Posted: 07/12/19 08:56am Link  |  Quote  |  Print  |  Notify Moderator
Research E450 caster alignment before investing in steering stabilizers.
pianotuna
Regina, SK, Canada
Posted: 07/12/19 11:00am Link  |  Quote  |  Print  |  Notify Moderator
How many inches is the wheelbase?
Regards, Don
BSWS19
Tucson AZ
Posted: 07/12/19 11:12am Link  |  Quote  |  Print  |  Notify Moderator
Harvard knows what he's talking about and I appreciate the advice he has provided about the caster adjustment in earlier posts. The "correct" alignment made a huge improvement in the handling of my new MW 31K. Better sway bars in the front and rear not only greatly improved handling but also stabilize the movement in the coach while parked. I don't feel I have a need for a new stabilizer bar, and I just completed my second 4000 mile trip.
2017 Minnie Winnie 31K
2003 Wrangler
bobndot
Posted: 07/12/19 03:06pm Link  |  Quote  |  Print  |  Notify Moderator
x2. When I called the company researching to buy one and explained my class c symptoms, I was told the steering stabilizer had a lot less bang for the buck than the alignment described above.
I operated medium duty ambulances all my working life on highways at 80 mph and never had to add any of this aftermarket stuff. A correct alignment was always most helpful.
AJR
Close to Madison Wisconsin
Posted: 07/12/19 07:15pm Link  |  Quote  |  Print  |  Notify Moderator
The Safe-T- Plus gives you control if a steer tire blows out. It also minimizes drift on the road. I really liked that addition when I had a Ford chassis.
Harvard’s recommendation is a must in my mind. It made a world of difference in my used Ford class C.
2014 Leprechaun 290QB
Chevy 2400 6.0
2015 GMC Terrain AWD
marty1300
florida
Posted: 07/12/19 07:27pm Link  |  Quote  |  Print  |  Notify Moderator
OP here, the wheel base is 220" (18.33'). Seems the alignment is the biggest factor. So I will drive it first to see how it hanldes. Our old Rv was about 23-25' total and it did have the steering stabilizer . It drove nice but a semi would push it every now and then
Marty
