RV.Net Open Roads Forum: 1979 dodge mobile traveler 360cl wont pass emissions
 > 1979 dodge mobile traveler 360cl wont pass emissions
zerxyx
north salt lake, utah
Posted: 07/12/19 12:57pm Link  |  Quote  |  Print  |  Notify Moderator
Hi guys, I have a 1979 dodge mobile traveler with a 360cl engine, and i cant get it to pass emissions. The CO2 level is the issue.
I have changed the oil and the spark plugs and things improved but it still fails on co2.
any ideas on what to try next?
Scott
newman fulltimer
louisiana
Posted: 07/12/19 01:03pm Link  |  Quote  |  Print  |  Notify Moderator
Very doubtful with today's emission standards if you put everything new on that motor it will pass.But if you want to put money into it a new carb and catalytic converter and new exhaust system will help
2oldman
New Mexico
Posted: 07/12/19 01:04pm Link  |  Quote  |  Print  |  Notify Moderator
Wow.. a vehicle that old still has to pass emissions? I wonder how all those old stinky-ass pickups I get behind are allowed on the road. And those jackasses who blow black smoke, on purpose.
Monterey, California
Posted: 07/12/19 01:33pm Link  |  Quote  |  Print  |  Notify Moderator
Per California DMV at https://www.dmv.ca.gov/portal/dmv/detail/vr/smogfaq
"Currently, smog inspections are required for all vehicles EXCEPT diesel powered vehicles 1997 year model and older or with a Gross Vehicle Weight (GVWR) of more than 14,000 lbs, electric, natural gas powered vehicles over 14,000 lbs, motorcycles, trailers, or gasoline powered vehicles 1975 and older."
2015 Winnebago 2101DS TT & Tahoe LTZ, 300 watts WindyNation solar-parallel & MPPT, Trojan T-125s. TALL flagpole for US flag. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - old MOS 1542 & 1560.
shastagary
minnesota
Posted: 07/12/19 01:43pm Link  |  Quote  |  Print  |  Notify Moderator
when we had emissions testing here on my camper van i had to adjust my idle mixture screws on the carburetor in until the engine just started to stumble at idle a bit to get it to pass. there was a one year exemption issued if it would not pass after several tries to give you time to get it fixed.
enblethen
Moses Lake, WA
Posted: 07/12/19 01:44pm Link  |  Quote  |  Print  |  Notify Moderator
Common problem with 360 is the exhaust cross over passage in the intake manifold. Ackward job to clean without taking manifold off.
Odd that the vehicle needs emission testing!
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
D.E.Bishop
Eagle Rock, CA
Posted: 07/12/19 01:47pm Link  |  Quote  |  Print  |  Notify Moderator
1984 was the first year for mandatory use of converters, prior to that it was optional but if the vehicle came with one it is required. Test on vehicles are a little schety to beging with.
A cat actually makes C02.
Check and see if you can get a vintage vehicle exemption at that age you just might.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
Back to a 2006 Suzi GV
Roadmaster 5000
Roadmaster backplates
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 07/12/19 01:59pm Link  |  Quote  |  Print  |  Notify Moderator
No exemptions for commercial vehicles.
DATA allows perspective. List HC, CO, and NOX data. it will have max/min + your numbers listed. One such example a VACUUM LEAK will raise CO numbers. Can we see some numbers, please?
time2roll
Posted: 07/12/19 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
CO is the air/fuel mixture. Need a good carburetor adjustment or better just get a new one.
675w Solar pictures back up
markchengr
Seattle
Posted: 07/12/19 02:37pm Link  |  Quote  |  Print  |  Notify Moderator
The OP said CO2 not CO. Emission tests require CO2 OVER a certain level, not less.
