RV.Net Open Roads Forum: Refrigerator has quit working on elec./ where is fuse?
 > Refrigerator has quit working on elec./ where is fuse?
mcilvaniej
Nipomo, CA
Posted: 07/12/19 10:02pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 94 Rexhall Airbus, refrigerator worked fine when I plugged into electric 2 weeks ago, now it does not, just goes to gas. Does anyone know where the fuse is, if there is one. Thank You
Martha
1492
Arlington, VA
Posted: 07/13/19 11:30pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from Forum Posting Help and Support
Ivylog
Blairsville, GA and WPB, FL.
Posted: 07/14/19 06:13am Link  |  Quote  |  Print  |  Notify Moderator
Probably on the control board assuming you have power to the 120V outlet.
08 HR Navigator 45'
Sold 04 Dynasty after 14 great years.
[url=https://i.
tropical36
Southwest Florida_USA
Posted: 07/14/19 07:24am Link  |  Quote  |  Print  |  Notify Moderator
Martha
12vdc is required for gas operation as well, so I'd be looking for a loss of 120vac power.
Be sure it's still plugged in in the back of the fridge, accessible from the outside panel. A meter or small appliance can be checked for power at the outlets there.
There could be a 120v fuse back there, inside a panel, so do take a look there, while you're at it.
Reset all breakers in the main panel.
Check the breakers on your inverter, if you have one.
"We are often so caught up in our destination that we forget to appreciate the journey."
07 Revolution LE 40E_Spartan MM_06 400HP C9 CAT_Allison 3000.
Dinghy_2010 Jeep Wrangler JKU ISLANDER.
1998 36ft. National Tropi-Cal Chevy Model 6350 (Sold)
MountainAir05
New Mexico
Posted: 07/14/19 09:26am Link  |  Quote  |  Print  |  Notify Moderator
The heating element also could be bad.
John Wayne
Long Beach, Ca
Posted: 07/14/19 12:54pm Link  |  Quote  |  Print  |  Notify Moderator
do you have a gfi that needs to be reset. The outside refrigerator. plug should be connected to a gfi.
John & Carol Life members
01 31'Sea View single slide, F53 V-10 with 134,000 miles and counting.
2012 Jeep Liberty Smi brake system
Security by Bentley
God Bless
KF6HCH
Fleet Man
Western WA
Posted: 07/14/19 04:48pm Link  |  Quote  |  Print  |  Notify Moderator
When we had a similar problem, refrigerator would run on propane only, the problem turned out to be a bad converter/charger. Have you considered that?
2007 Winnebago Journey 34H
Toad, '08 Ford Taurus X
Blue OX, Aventa
US Gear UBS
ArchHoagland
Clovis, CA, USA
Posted: 07/14/19 10:09pm Link  |  Quote  |  Print  |  Notify Moderator
Make and model of refrigerator would help.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
Wherever I happen to park
Posted: 07/15/19 04:20am Link  |  Quote  |  Print  |  Notify Moderator
I have a dometic Fridge
You have a circuit breaker in your breaker box Visually inspect it
Now go outside and you will find a plug and outlet in the outside compartment behind the fridge. Unplug and test with a test light or other electrical device (Fan for example)
on Dometics there is a circuit board with the old 3-ag Glass fuses bottom center
Additional fuses in the black box to the left DO NOT KNOW which ones are 120vac
And the board someone else mentioned. also that black box
If the board is bad Consider Dinosaur boards. they are superior in my opinion .
Home is where I park it.
10forty2
North Carolina
Posted: 07/15/19 12:18pm Link  |  Quote  |  Print  |  Notify Moderator
X2 - Happened to me a few weeks ago when washing the rig. I left her plugged into shore power to keep the A/Cs running and apparently I shot water into the refer's vent, hitting the electrical outlet and tripping the gfi. Reset the gif outlet upstream, and everything is back to working.
1999 Holiday Rambler Endeavor, 36' Gasser
Triton V10, Ford F53 Chassis
