RV.Net Open Roads Forum: Class A Motorhomes: Newmar Ventana LE Recommended Tire Pressures
 > Newmar Ventana LE Recommended Tire Pressures
HighwayJunky
Kissimmee
Posted: 07/13/19 09:14am Link  |  Quote  |  Print  |  Notify Moderator
Running Michelin tires 275/75R22.5. Listed pressures seem high to me at 130PSI in Front and 120 PSI on rear...Is there an opinion as to what weights are best both for smooth driving/safety and diesel mileage??
Presently actual pressures on the unit vary from 105-120....Comments appreciated...
2017 Newmar Ventana LE Diesel Pusher
2012 Fiat Pop Toad
One wife
No pets
No complaints
No Worries (except keeping wife happy!!)
Fulltime jobhttps://www.rv.net/SharedContent/cfb/images/rolleyes.gif
fyrflie
Martinez, CA. USA
Posted: 07/13/19 09:54am Link  |  Quote  |  Print  |  Notify Moderator
Pressures listed in RV are maximum pressures.
The only way to know the correct pressure is to weigh the RV then use Michelin’s inflation table to determine correct pressure.
When you weigh the RV, you need the front axle weight and the rear axle weight. Then calculate pressures accordingly.
With my RV, it worked out that all my pressures on all tires are the same which makes it easy to remember, but your results may be different.
Bill.Satellite
Full-timer
Posted: 07/13/19 10:36am Link  |  Quote  |  Print  |  Notify Moderator
The above post is correct other than you should actually try to get each wheel weighed for an accurate determination of tire pressure. If you are just weighing front and rear you can use the Michelin pressure guide but you should add 5# to try to accommodate one side being somewhat heavier than the other. No one on the forum can tell you the correct pressure. No one. You must know the RV weights before making any adjustments. Never exceed the pressure listed on the tire sidewalls and be sure your tires are cold when you set the pressure.
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
FloridaRosebud
Melbourne
Posted: 07/13/19 10:58am Link  |  Quote  |  Print  |  Notify Moderator
This....my tires say 110psi on the sidewall, but my weights gave me 80psi front, 85 rear. MUCH better ride and handling.
Al
CA Traveler
The Western States
Posted: 07/13/19 11:24am Link  |  Quote  |  Print  |  Notify Moderator
Weight each side and use the heavy side for the axle.
Also useful for deteriming that you have a significant side to side imbalance.
2014 Grand Cherokee Overland
Bob
wildtoad
Blythewood, SC
Posted: 07/14/19 05:27am Link  |  Quote  |  Print  |  Notify Moderator
I’ll add in tire wear, tire longevity
The pressures on the placard are your best bet to achieve your stated goals. Lowering your pressures can give you a better ride, but may affect other objectives. Keep in mind the tire chart simply states the minimum pressure required to support the weight. No other factors included.
Tom Wilds
Blythewood, SC
JoeH
Apollo Beach,FL
Posted: 07/15/19 11:27am Link  |  Quote  |  Print  |  Notify Moderator
I suggest you plan a little trip to Bushnell ( about 1 hour from Kissimmee) and for $45 they will weigh each wheel and measure your height. Once you have the weights, refer to the Michelin chart to see what the proper PSI is.
Here's a link with the info
Joe
2013 Dutch Star 4338- all electric
Toad is 2015 F-150 with bikes,kayaks and Harley aboard
