RV.Net Open Roads Forum: Truck Campers: 2005 Lance 1191 Need Opinions
 > 2005 Lance 1191 Need Opinions
P Colahan
Pacific Norhtwest
Posted: 07/14/19 11:18am Link  |  Quote  |  Print  |  Notify Moderator
We are looking at a 2005 Lance 1191 and would like you opinions and known things to look for.
Also, how would you compare the Lance to the Artic Fox Silvers? Both have aluminum framing.
Thanks much for your input.
Patrick
2003 Ford F350 DWR 4x4 7.3L
Camper TBD still shopping
1991 Bayliner 4588
2012 Endeavor 12ft RIB, Honda 4-stroke 9.9hp
burningman
Seattle, WA USA
Posted: 07/14/19 12:01pm Link  |  Quote  |  Print  |  Notify Moderator
The aluminum framing is kind of a farce. They don’t weld it properly they just tack-weld them.
I’ve read a few stories about the AF water tanks busting out of the floor while off the truck.
Any camper, leaks and rot are the biggest issue.
I’d be most attracted to one that had photos of it being stored inside a shop in the ad, and/or located somewhere in the dry southwest.
2017 Northern Lite 10-2 EX CD SE
99 Ram 4x4 Dually Cummins
A whole lot more fuel, a whole lot more boost.
4.10 gears, Gear Vendors overdrive, exhaust brake
Built auto, triple disc, billet shafts.
Kelderman Air Ride, Helwig sway bar.
joerg68
St. Ingbert, Germany
Posted: 07/14/19 01:11pm Link  |  Quote  |  Print  |  Notify Moderator
At almost 15 years, the camper that is in better shape is the better camper.
Look into every compartment and every corner.
Test every feature of the camper. Try to put it on the jacks alone. See how stable it stands. A little bit of sway is normal. Are there any previous repairs, e. g. to the front jack mounts? Do slideouts open and close smoothly, close fully, and sit square in their opening?
Try to bring someone with RV experience with you if you don't have any.
Any rot / leak issues that you find frequently turn out to be much worse once you start disassembly. Are there delamination bubbles or wrinkles on the outside walls?
TCs are very good at hiding issues. Usually, there is no smell that could give a leak issue away.
If the camper passes all checks and fits your needs and wants well enough, buy it regardless of the manufacturer.
