RV.Net Open Roads Forum: Class A Motorhomes: turn signals
Tom/Barb
Oak Harbor, Wa
Posted: 07/14/19 03:36pm Link  |  Quote  |  Print  |  Notify Moderator
My right hand turn signal will only work when the head lights or parking lamps are off.
turn off the lights and it works great.
77rollalong
Brighton Ontario
Posted: 07/14/19 04:51pm Link  |  Quote  |  Print  |  Notify Moderator
Check for a bad ground on the turn signal bulbs
D.E.Bishop
Eagle Rock, CA
Posted: 07/14/19 05:11pm Link  |  Quote  |  Print  |  Notify Moderator
Actually I'd check the sockets.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
Back to a 2006 Suzi GV
Roadmaster 5000
Roadmaster Invisibrake
Tom/Barb
Oak Harbor, Wa
Posted: 07/14/19 08:43pm Link  |  Quote  |  Print  |  Notify Moderator
Took me all day to figure it out..checked every bulb and socket in the system. most needed cleaning, but it turns out to be a bad bulb in the front right parking light, which doubles as a signal light.
It was on with the parking lights so I didn't notice it was not blinking.
Cleaned the socket, changed the bulb = good to go.
Funny it's always the last one you work on that fixes it. [emoticon]
zigzagrv
Nazareth, PA
Posted: 07/15/19 06:51am Link  |  Quote  |  Print  |  Notify Moderator
Good to hear someone other than me, uses their turn signals. I was under the impression they were optional on newer vehicles since so few use them. [emoticon]
Ron
2003 Gulf Stream Ultra Supreme 33'
F53 Class A
Master Tow dolly
Toyota RAV4
D.E.Bishop
Eagle Rock, CA
Posted: 07/15/19 07:25am Link  |  Quote  |  Print  |  Notify Moderator
Quite right, my wife's usual comment is $150,000 for a DP and it doesn't have turn signals, what a shame.
Tom/Barb
Oak Harbor, Wa
Posted: 07/15/19 08:55am Link  |  Quote  |  Print  |  Notify Moderator
Our Newmar gives you the most irritating beeeeeeeeeeeeeeep when you have a bulb out, and the lights on.
Wherever I happen to park
Posted: 07/15/19 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
I have had that issue on the LEFT side a couple times
FIrst time it was the front left turn signal (not sure if it was the side or front lamp) removed and replaced (Same bulb) and all good
2nd time it only happened when towing.. I Improved the ground connection at the tow connector (Motor home end. don't know why I tried that one first.. and last) and all good.
In all cases the "Bad Ground" is the answer.. Full explanation is more than I care to type today. >Been a long day and 2 more coming.. Only fun thing is I'll grab a free hotdog Wed [emoticon].
Home is where I park it.
