RV.Net Open Roads Forum: Class A Motorhomes: RV Tank Maintenance
 > RV Tank Maintenance
kdk
usa
Posted: 07/15/19 08:30pm Link  |  Quote  |  Print  |  Notify Moderator
Google " GEO " method, Dawn dish soap and Calgon water softener. Been using this for years with good success. Lasts about 6 months then do it again. I do this every time I move.
06 Holiday Rambler Ambassador
2015 Wrangler Sahara 4 door
Airdaile
On The Road
Posted: 07/16/19 06:34am Link  |  Quote  |  Print  |  Notify Moderator
Another vote for the Geo method.
valhalla360
No paticular place.
Posted: 07/16/19 06:36am Link  |  Quote  |  Print  |  Notify Moderator
If you are on a sewer site...don't worry about. All it takes is 30 seconds to walk around and pull the valve.
So do that once every 3-4 days of use (if you find it's getting full sooner drop to 2-3 days).
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
10forty2
North Carolina
Posted: 07/16/19 07:03am Link  |  Quote  |  Print  |  Notify Moderator
It might be overkill, but I flush the tanks and use Dawn/Calgon after every trip. I have a built-in tank flusher so I hook that up and let it do its thing. I also allow the black tank to fill almost full several times and then dump it. Once I have only clear water coming out of the black tank, I let it empty as much as it will, and then close the valves, and put in two gallons of hot water mixed with a box of Calgon and 1 small bottle of Dawn. So far, so good.....no smells inside, and everything appears to be working properly. Unfortunately, my tank sensors were out of service long before I got the rig.
1999 Holiday Rambler Endeavor, 36' Gasser
Triton V10, Ford F53 Chassis
viajante
Plumas Lake, CA, (near Yuba City) USA
Posted: 07/16/19 11:38am Link  |  Quote  |  Print  |  Notify Moderator
DFord wrote:
The best holding tank treatment available is "Happy Campers"
It's available from better RV supply stores, Amazon, Ebay and several dealers websites. Here's a link to one of those dealer's websites where you can learn more about it: https://www.happycampersworld.com/
Amazon: https://www.amazon.com/Happy-Campers-Organic-Holding-Treatment/dp/B007S0H5DU
I agree with the Happy Camper recommendation. Have tried various products over the years and Happy Camper is the best I have found.
Dave & Brenda
Shadow (Sheltie), and Zoe (Shih Tzu)Faithful Companions
2008 Itasca Sunrise 35L
Executive
Posted: 07/16/19 12:14pm Link  |  Quote  |  Print  |  Notify Moderator
Tank sensors are a sales 'gimmick'. None work as intended. If it starts to get full, you'll notice a different sound as you flush. If needed, put a sticky in the bathroom as to when you last emptied it. More reliable than the sensors. I've only used water in our tanks and in 40 years of camping, never had an issue with smells. IMO, everything else is a waste of money.....Dennis
A Simple Act of Caring Creates an Endless Ripple
Dennis and Debi Eleven Years Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
DFord
Near St Louis, MO
Posted: 07/16/19 01:58pm Link  |  Quote  |  Print  |  Notify Moderator
By adhering to recommended practices with every RV I've owned over the past 45 years, I've never had any issues with my sensors not reading properly. On the hand, if you get lazy and sloppy and don't follow those recommended practices, sensors are useless. It's one of those pay me now or pay me later scenarios.
Don Ford
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
sgfrye
north carolina
Posted: 07/17/19 06:26am Link  |  Quote  |  Print  |  Notify Moderator
x2 on happy camper. about once every 3 months or so after dumping and backflushing i will use 1 scoop in black tank and 2 grey tanks. fill and let sit overnight. next day dump and flush again. works for us.
One scoop per tank is all that's needed. Fill your toilet 3/4 full of water after flushing your tank, swish it around with your bowl brush, flush the toilet and fill it again with enough water to rinse the brush.
It was recommended to me by some Trek friends and I've been hooked ever since. We use Charmin Ultra tissue and don't have any problems with out tank sensor. It does a great job of killing the odors too.
Disclaimer - I have no connection to the company but when I find something that works, I share it with others.
With all that being said, nothing will ever be any better than flushing your black tank with a wand hooked to a hose and stuck down through the toilet. Blasting a good stream of water around the tank a couple times a years is a good practice that should be followed no matter what tank treatment is used.
MetalGator
Posted: 07/17/19 06:34am Link  |  Quote  |  Print  |  Notify Moderator
So what are the recommended practices?
2018 Miramar 35.3
2005 Dodge Ram Quad Cab 1500
4 fur kids (Murphy, Monty, Lola and Pinto)
BillyBob Jim
US
Posted: 07/17/19 07:37am Link  |  Quote  |  Print  |  Notify Moderator
What I would like to know is if the folks who insist on having squeaky clean poop tank after dumping and before taking the next dump also pull one of these through their sanitary lateral at the sticks and bricks on a dedicated schedule?
