RV.Net Open Roads Forum: Reliability of propane and water in slide
 > Reliability of propane and water in slide
janstey58
Glenwood, IA
Posted: 07/16/19 12:41pm Link  |  Quote  |  Print  |  Notify Moderator
The only issue is fall/winter camping, the water lines are exposed and you would need to worry about that if temps dipped below freezing.
Jeff and Kim
2015 Fleetwood Discovery 40E
Freightliner Chassis 380HP DP
2012 Ford Escape Limited Toad
2oldman
Ca
Posted: 07/16/19 03:54pm Link  |  Quote  |  Print  |  Notify Moderator
Not mine. The lines are all inside.
gme105
Spokane, WA
Posted: 07/16/19 11:13pm Link  |  Quote  |  Print  |  Notify Moderator
Wow! I sincerely appreciate all the rapid responses and your collective experience.
I was talking to the dealer's service manager today about this and other issues and he said his experience was there were more often problems with stationary kitchen appliances with less flexibility. I can see that argument as well. Of course there are more stationary appliances (from what I can see) than those in slides so I suppose that would also mean more repair shop incidents.
It sounds like this is not the big concern I thought it might be. Again, my sincere thanks to all of you!
Greg
rhagfo
Portland, OR
Posted: 07/16/19 11:24pm Link  |  Quote  |  Print  |  Notify Moderator
opnspaces wrote:
Been on this forum for many years and I can only remember one posting where the 120 volt romex to a wall outlet was damaged by the constant movement of the slide. Other than that the slide issues have always been about the slide damaging the floor as it moves in and out.
The slide should not use romex for the flexible connection, that should be SOOW 12-2 with ground.
mike brez
Unknown
Posted: 07/18/19 09:50am Link  |  Quote  |  Print  |  Notify Moderator
Mine is a 1998 so 21 years no issues with electric,water or propane going in and out a few times. [emoticon]
1998 36 foot Country Coach Magna #5499 Single slide
Gillig chassis with a series 40
02 Ford F250 7.3 with a few mods
2015 Wrangler JKU
SailingOn
Central Texas
Posted: 07/20/19 08:44pm Link  |  Quote  |  Print  |  Notify Moderator
If the fridge is in the slide, then the upper outside vent is on the vertical side of the rig, rather than the roof, and therefore less efficient.
Buck: 2004 Wilderness Yukon 8275S, now memories.
Star: Open range LF297RLS. 2 air conditioners!
Togo: 2014 Winnebago View Profile, 2013 Sprinter chassis; 16 mpg
AJ: 2010 F150 ExtCab, 2WD, 6.5' bed, 5.4L V8, 6A, Max Tow: 2030# payload.
AD5GR
ron.dittmer
North-East Illinois
Posted: 07/20/19 09:56pm Link  |  Quote  |  Print  |  Notify Moderator
I have heard of this too. The chimney for the fridge offers a better draw when going straight up through the roof. With a slide out, the chimney exhaust is in the wall near the top and is less efficient because of it. When camping in hotter temps, the fridge sometimes can't keep up. The remedy is to install a 12V fan in a strategic place behind the fridge done through the outside lower access panel.
The problem is more prominent with lower profile rigs with shorter chimneys. Tall rigs with high ceilings seem to do better because their slide out is taller and therefore have a taller chimney.
2007 Phoenix Cruiser model 2350, with 2006 Jeep Liberty in-tow
