RV.Net Open Roads Forum: Ford F-150 what do I need for towing?
 > Ford F-150 what do I need for towing?
supercub
Modesto CA
Posted: 07/15/19 09:32pm Link  |  Quote  |  Print  |  Notify Moderator
I thinking of downsizing from a 38 ft Diesel Pusher to a smaller travel trailer. I have a driveway that is 25 feet deep. I'm thinking a TT around 23-25 feet. (I have to currently store my motor home at a lot. One reason I'm thinking of downsizing. Just me and my border collie travel 95% of the time anyway.
I won't be buying a new truck, thinking of something around the 2015-2018 year models. I also don't want/need 4 wheel drive. So what should I be looking for as far as towing capacity and set up? Should I be looking at a certain size engine/ transmission, are there certain tow packages? I'm just trying to learn this stuff. Been camping for years, just has always been in a motor home. Thanks for your help.
valhalla360
No paticular place.
Posted: 07/16/19 12:28am Link  |  Quote  |  Print  |  Notify Moderator
Look at all the ratings.
1/2 ton trucks can vary wildly in terms of capabilities.
Some of the light duty 1/2 ton pickups run out of payload (to hold up the hitch) before they run out of tow ratings.
Realistically most 1/2 tons will be fine with such a small trailer but avoid the really low capacity ones.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
jfkmk
NJ
Posted: 07/16/19 03:50am Link  |  Quote  |  Print  |  Notify Moderator
As stated, look at the payload capacity of the particular truck being considered. Generally, the higher trim levels with all the options have the lowest payload.
I tow a similarly sized tt with a 2018 F150 with the 3.5 eb andd max tow package and it pulls, and stops, great.
Jebby14
Windsor Ontario
Posted: 07/16/19 03:59am Link  |  Quote  |  Print  |  Notify Moderator
my 2016 f150 s'crew xlt with 5.0 handles my 23 footer like a champ with a reese wd hitch and a friction sway bar im comfortable. My truck will have less capacity with the super crew back seat and the 4x4 than what your looking at. stay 2015 or newer if you want the aluminum body. the 10 speed came in 2017 (I have a 6 speed which works fine) I also have a 331 rear end for fuel mileage. going to a 355 would get you a bit more grunt.
If it moves and it shouldn't..... duct tape
if it doesn't move and it should.....WD40
if all else fails .....BFH
Bumpyroad
Virginia
Posted: 07/16/19 07:25am Link  |  Quote  |  Print  |  Notify Moderator
find the TT that you want/need. size truck to fit.
bumpy
GrandpaKip
Flat Rock
Posted: 07/16/19 08:10am Link  |  Quote  |  Print  |  Notify Moderator
bumpy
This first.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
trail-explorer
NM
Posted: 07/16/19 08:46am Link  |  Quote  |  Print  |  Notify Moderator
bumpy
Ditto.
Pick the cart then get the horse to match what it weighs.
Bob
philh
Belleville MI
Posted: 07/16/19 12:50pm Link  |  Quote  |  Print  |  Notify Moderator
pick the cart... and with 1/2 Ton, cargo capacity will be your limiting number, not trailer wt.
2manytoyz
Central FL
Posted: 07/16/19 01:04pm Link  |  Quote  |  Print  |  Notify Moderator
When I bought our new 2010 F150 FX4 (4x4) Super Crew Cab, I chose the Max Tow Package.
It included a built-in brake controller, with trailer sway control. A tighter turning radius, wider rear springs, different gearing, a transmission cooler, a larger (36 gallon) fuel tank, an 11,100# tow capacity, an 1810# bed capacity, a Class IV hitch, and a 4 & 7 pin towing receptacles.
I have always used an Equalizer hitch when towing our travel trailer, which is an excellent addition.
Because I sized my truck to fit my needs, I was able to also carry a 900 lb golf cart in the bed of the truck. Notice no squatting of the rear springs.
In a couple of weeks, our TT will go to our niece. I have 105K miles on my truck, and have no regrets. It's still my daily driver.
Whatever F150 setup you choose, make sure it has the Max Tow Package. Can't add it after the fact. FWIW, the 2018 F150 with this package is rated at 13,200#. Not too shabby!
Robert
Merritt Island, FL
2015 Forest River Georgetown 328TS
2006 Jeep Wrangler Unlimited TOAD
Falcon 2 Towbar, Roadmaster 9400 Even Brake System
http://www.2manytoyz.com/
the bear II
Torrance CA.
Posted: 07/16/19 02:29pm Link  |  Quote  |  Print  |  Notify Moderator
I would get an F250 to allow for more options in the trailer you choose plus future choices.
