RV.Net Open Roads Forum: Tech Issues: Disappointed in Disc Brakes
 > Disappointed in Disc Brakes
lenr
Indianapolis, IN
Posted: 07/17/19 08:24pm Link  |  Quote  |  Print  |  Notify Moderator
Sure wish I had TBC Effort--it sounds like it is just what I need. But, I don't have it. I'm going to check with a dealer to see if there is an upgrade available. Thanks for that informative post.
lenr
Indianapolis, IN
Posted: 07/27/19 06:50pm Link  |  Quote  |  Print  |  Notify Moderator
A Titan BrakeRite actuator will be installed next Thursday replacing the Dexter unit. The folks at Titan confirmed that their initial voltage for turn on is less than one volt—much less than the stated 3 volts for Dexter. The trailer dealer that I’m switching to called his contact at Dexter technical who confirmed that the higher turn on voltage is probably the root cause of my problems. I also noticed that the wire gauge requirement for the control line for the Titan is smaller than the Dexter. That tells me that the amperage draw by the Titan from the truck controller is lower than the Dexter—that’s good. I’ll also be using the Ford/Chevy adapter since Titan recommends it and the success stories seem to use it. Big thanks to Planning for posting the price at Eastern Marine—ground delivery in 3 days for $20. By the way the price match at ETrailer is more of a stall technique than anything else. I’ll post results after installation.
Planning
Idaho
Posted: 07/27/19 10:49pm Link  |  Quote  |  Print  |  Notify Moderator
I am rooting for your success with this. Also, ensure really good bleeding of all of your calipers. E/H disc systems are very sensitive to air in the lines, and the first symptom is increased lag time from stepping on the brakes until trailer brakes actually produce brake effort.
If I had thought of it the last time I had mine worked on, I would have had Earl's Solo bleeders installed.
Also, be careful of the length of the installation bolts that you use. Too long and they will penetrate the base housing. I don’t remember the specified length, but there is at least one video that speaks to the issue on YouTube.
* This post was edited 07/27/19 11:44pm by Planning *
2016 AF 29-5K; 2016 F350 6.7, 4x4, CCLB DRW
Planning
Idaho
Posted: 08/04/19 05:39pm Link  |  Quote  |  Print  |  Notify Moderator
Any good news on your project?
lenr
Indianapolis, IN
Posted: 08/06/19 09:20pm Link  |  Quote  |  Print  |  Notify Moderator
Final report—maybe. Warning—long!
The Titan BrakeRite EHB was installed last Thursday. It is definitely smoother in its operation (than the Dexter actuator was). Voltage check in the driveway confirms why. The Titan starts running with as little as 1 volt on the control line. So it starts pumping on light braking from the truck, and then ramps on up. Also, the Titan is a 1500 psi actuator compared to 1600 from the Dexter. That allowed me to change the gain on the truck controller from 6.0 to 7.0 without wheel lockup. That in turn will cause the truck controller to output just a little more voltage on light braking getting the actuator turned on just a bit sooner and smoother. Despite the lack of the aggressiveness setting in my truck, it seems like the Titan turns on at a low enough voltage that it may be fine with the Ford IBC eliminating the need for an after market controller. We start a trip soon, and we’ll see how it feels after some miles.
Issues along the way:
It seemed like everyone (and his brother) recommended using the Titan Ford/Chevy adapter with the adage that it wouldn’t hurt if you don’t need it, and it may help. In addition, Titan documentation seems to indicate that it is needed on Fords after 2006 ½. So, the adapter arrived, and I installed it on Saturday. Next time I tried the truck IBC, it threw a wiring fault. When I checked the adapter, it measured less than .2 ohms regardless of the polarity of the meter. That’s a short circuit, so out it came. Not wanting to start a long trip with any chance of problems, I bought 2 drum brake magnets and wired them in. The actuator cranks up fine at this point—road test tomorrow.
A second issue is that the Titan makes noise and clicks about every 3 seconds. This is, no doubt, the Ford IBC pinging the trailer to see if it is still connected. The noise changed and got quieter after I installed the magnets. In fact, it is currently so quiet that some folks might not notice it on their trailers. However, it concerns me that it will put premature wear on the actuator. At the time I discovered this, I wondered if a properly functioning adapter would have drained off enough current flow from the ping to stop the actuator from clicking. Further research will be needed including getting specs from Titan engineering, and getting a scope on the brake control line to measure the ping (don’t have a scope yet.) However, see additional information in the paragraph below.
Rant:
On three prior occasions, I spoke with a fellow (name omitted to protect the ??) at Titan Customer Service and Warranty. This fella was unable to answer any tough questions like “how can I test the Ford/Chevy adapter to confirm that it is defective?” He wanted to blame the actuator noise on a defective Ford IBC (just put in a P3 and everything will be fine). Today this guy left work early—lucky me. And, I was referred to another person (Randy) who was very knowledgeable. This individual confirmed that the adapter was defective. In addition, he stated that the small noise from the actuator would be no problem. He also stated that a properly functioning Ford/Chevy adapter would have drained off the current from the ping, and thus the actuator wouldn’t be clicking.
* This post was edited 08/07/19 06:30am by lenr *
lenr
Indianapolis, IN
Posted: 08/11/19 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
Trip report:>
We made a 550 mile trip--mostly Interstate but enough stopping to test the new Titan Actuator. The Titan actuator is smooth and strong. The pairing with the Ford IBC is very adequate. The combination will definitely stop the combined rig. Having the Ford aggressiveness adjustment (or a Prodigy P3) would allow me to tune the combination a little better, but it is just fine the way it is. Although it is a tad light on light braking, it does come on pretty quick, and is fairly well matched to the truck.
Groover
Pulaski, TN
Posted: 08/12/19 08:42am Link  |  Quote  |  Print  |  Notify Moderator
I am glad to here that you seem to be where you want to be with the brakes. I just purchased a utility trailer with hydraulic over electric brakes and have only towed it empty. After I get it loaded I may be going back and reading some of these posts more carefully if I have issues.
lenr
Indianapolis, IN
Posted: 09/11/19 09:19am Link  |  Quote  |  Print  |  Notify Moderator
The thread lives--maybe all this will help someone, someday. After returning the defective Ford/Chevy adapter, I purchased one from a different source to avoid problems from a manufacturing batch. The new one tested fine with a meter and works fine after installation. Its main job is to provide load to fool brake controllers that don't have a hydraulic setting. However, especially desirable for Fords (don't know about Chevys) is a secondary effect of draining off the short voltage spike that Ford uses to ping the trailer to see if it is still there. Without something connected the Titan actuator makes a clicking sound that "Randy" said doesn't hurt a thing. When I added a couple of brake magnets, the noise reduced by half. When I removed the magnets and added the working Ford/Chevy Adapter the noise completely went away. So, a Titan hydraulic actuator is the best one for an RV IMHO, but one definitely needs to install the Ford/Chevy adapter on ALL Fords (and maybe others as well.)
The experience with the Ford built in brake controller and the Titan actuator is satisfactory. However, at some point I will likely try a P3 (since I don't have the Ford aggressive setting) to see if I can get a better balance between truck and trailer on light braking. Thanks to all for the input.
Cummins12V98
on the road
Posted: 09/11/19 10:04am Link  |  Quote  |  Print  |  Notify Moderator
eHoefler wrote:
On that year Ford truck, you need an adaptor to use the factory brake contoller for electric/hydralic brakes.
https://www.etrailer.com/Accessories-and-Parts/Titan/T4846000.html
Correct answer, it's the truck not the RV.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Learjet
Louisiana
Posted: 09/11/19 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
no issues with my Ram in the EOH mode and the Titan Brake pump
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2015 Wildcat 317RL, MoRryde rubber pin box, Titan Disc Brakes, Trojan T105
B&W Ram Companion
Yamaha EF2600c tri-fuel generator
Champion Model 46595- 3000/3500w
