RV.Net Open Roads Forum: Fifth-Wheels: Bedroom AC?
 > Bedroom AC?
Super_Dave
Harrisville, UT
Posted: 07/19/19 03:32pm Link  |  Quote  |  Print  |  Notify Moderator
Does the bedroom AC feed the whole trailer or just the bedroom? Living room AC doesn’t come close to keeping up?
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 2003 Jetcraft 2125 - Yamaha 150 HP & 8 HP Kicker
pianotuna
Regina, SK, Canada
Posted: 07/19/19 03:48pm Link  |  Quote  |  Print  |  Notify Moderator
Often the two may share some duct work.
Regards, Don
MFL
Midwest
Posted: 07/19/19 03:52pm Link  |  Quote  |  Print  |  Notify Moderator
Some bedroom ACs are direct to bedroom, with overhead controls. If yours is ducted, it likely uses same as living room ducts.
Jerry
Gearitis
Waco TX
Posted: 07/19/19 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
Mine is not ducted. So we place a fan and blow it down the hall and stairs. Makes a BIG difference.
2015 F-350 King Ranch
2015 Sabre Silhouette Select 312RKDS
padredw
East Texas
Posted: 07/19/19 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
It really depends on your trailer whether it is ducted or not. As for ours, we are with Gearitis:
Nv Guy
Reno NV
Posted: 07/19/19 09:50pm Link  |  Quote  |  Print  |  Notify Moderator
Yep, we have common ducting. When running only one at a time BR A/C is felt more in L/R than L/R A/C is felt in the BR.
Toolguy5
Columbia Station, Ohio
Posted: 07/20/19 05:29am Link  |  Quote  |  Print  |  Notify Moderator
X3
Dan & Patty
Miss Pickles the Pomeranian Princess
2020 GMC 3500 Sierra Denali 6.6 Duramax / Allison tranny
2018 Jayco Northpoint 387 RDFS
BWRVK 3710 companion
Maddy the Pampered Pom @ Rainbow Bridge 12-3-2013
Happytraveler
Capistrano Beach, Ca. USA
Posted: 07/20/19 09:10am Link  |  Quote  |  Print  |  Notify Moderator
My sister and her husband has a 5th wheel and they replaced one of their vents in their living area with a DOMETIC ATWOOD AIRCOMMAND
13,500 BTU, NON-DUCTED A/C, NON-DUCTED It made a huge difference in their RV. They spend a lot of time in Parker, AZ. on the river. We did the same thing with our motorhome, best thing we ever did.
Charlie, a male Soft Coated Wheaten Terrier
Katie, a female Soft Coated Wheaten Terrier
pennysmom09
Delaware
Posted: 07/20/19 01:36pm Link  |  Quote  |  Print  |  Notify Moderator
Ours shares ducting, so if we run the bedroom AC, it does a reasonable job cooling the LR, and vice versa.
Nancy and Doug
2015 KZ Durango 325RL FW
jffnkrn
peoria
Posted: 07/20/19 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
weather it is ducted or not, make sure your return inside the unit is sealed as it should be. take the filter off and look at the duct area just inside. sometimes the tape inside is not sealing where it needs to. if not, get some aluminum duct tape, the good stuff and seal it up. If it is ducted take a vent off at each end of the trailer and make sure you don't have any obstruction. For us, i had an issue with both, took care of them and my 15k unit takes care of the 33 foot fifth wheel. Also make sure you set your fan to on, not auto so it circulates the air all the time and it also helps it from freezing up. another option that helps is bubble foil for the windows.good luck
 > Bedroom AC?
