RV.Net Open Roads Forum: General RVing Issues: Renting out your RV nightmares.
 > Renting out your RV nightmares.
colliehauler
Mc Pherson KS USA
Posted: 07/20/19 06:04am Link  |  Quote  |  Print  |  Notify Moderator
Hope you made enough money to make it worth it.
westernrvparkowner
montana
Posted: 07/20/19 09:19am Link  |  Quote  |  Print  |  Notify Moderator
I believe the shop doesn't want to repair the tank because there is absolutely no upside for them. If they repair it and the repairs fail down the road, they are going to be blamed. Best option may be to have the shop remove the tank, the customer take it and get it repaired by someone other than the shop and have the shop reinstall it. They would probably have to sign a disclosure that relieved the shop of any liability. Realistically, a plastic tank that is not pressurized should be a fairly easy repair, especially if aesthetics are not a consideration. However, if it was shattered and major sections are missing, forget everything I just wrote.
souraider
Rogue Valley, OR
Posted: 07/20/19 09:36am Link  |  Quote  |  Print  |  Notify Moderator
I find it very hard to believe that there is not a replacement tank available for your RV. With a simple google search I found tons of black tank replacements in every configuration,and size conceivable. The price ranged from $75 on up. I cannot imagine it would be cheaper to take it to a specialty shop that would charge shop rates to remove-assess-repair-reinstall.
I would suggest you become familiar with simple fixes so you save some money. Nowadays you can Youtube just about any type of repair, and go from there.
'17 F350 STX 6.7
'15 Stealth WA2313
'20 Can Am Maverick Sport 1000R
opnspaces
San Diego Ca
Posted: 07/20/19 11:21am Link  |  Quote  |  Print  |  Notify Moderator
roadtrek_in_DC, If you can describe or post pictures of the "damaged" tank we might be able to give a better suggestion. If you tank is made out of black ABS plastic take a look at the Plastimend web site. The stuff isn't cheap, but I can tell you from experience that it works and it works well. I did something stupid to my black tank and put a three inch slit into it. Plastimend and some fiberglass (only use fiberglass not aluminum screen) window screening sealed the tank. The patch basically melts itself into the tank and then dries and makes the tank whole again. If the repair shop isn't sure if the tank is ABS have them scrape some shavings off the outside of the tank and drop the shavings into acetone. If the shavings melt the plastimend should work.
Plastimend
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
MWJones
Posted: 07/20/19 11:26am Link  |  Quote  |  Print  |  Notify Moderator
Roadtrek,
Your tank CAN BE REPAIRED!! I have repaired mine twice. Take the tank out or have it taken out. Take it to a boat repair place.
PS: It takes different risen than fiberglass or clear poly. They will know that. Your tank is ABS material NOT fiberglass.
M Jones
American and Texan by birth
Christian by the Grace of God
Retired and enjoying Traveling and Camping
Spending part of summers in South Fork, Co
steelhunter
North Dakota
Posted: 07/20/19 02:09pm Link  |  Quote  |  Print  |  Notify Moderator
Just cut a hole in the bottom.
Chances are the renters won't notice.
BobsYourUncle
Calgary Alberta Canada
Posted: 07/20/19 02:42pm Link  |  Quote  |  Print  |  Notify Moderator
In an old TT I was rebuilding, I needed the black tank due to a fracture around the neck at the toilet attachment point.
Old trailer, no parts available.
I went to my local RV service / parts store. People there were always helpful and great to deal with.
They had a catalog of generic tanks, made by some aftermarket company. I removed my old tank, took some careful measurements of the exact size, location of toilet flange, vent pipe and drain along with the desired sizes of all that and took this info to them.
They handed me the catalog to browse and I found a tank that was close to the same size. I gave them the diagram of where the holes needed to be and ordered the tank.
They took a generic off the shelf size tank and custom made it for my application. When it came back, it fit perfectly.
And it didn't break the bank to order. Don't remember what I paid for it but it was quite reasonable.
Dmax/Allison
1997 Triple E Topaz 27' Bunkhouse TT
I do
Precision Guesswork
based on
Vague Assumptions
Unreliable Data of Dubious Accuracy
provided by persons of
Questionable Intellectual Capacity
Now, What would you like done?
West & above Bishop, California
Posted: 07/20/19 04:39pm Link  |  Quote  |  Print  |  Notify Moderator
Look, Gulfcoast, I’m sure...positive...OP has insurance that covers him for loss, major damage, liability etc. and that he/she factored that all into his price to make the big bucks.
et2
MI.
Posted: 07/20/19 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
I find it hard to understand an insurance company will even cover you if your renting it out. Most insurance will drop you or your rates will go thru the roof.
Why aren't you just charging the people who rented and broke your stuff instead of claiming on your insurance.
Do you keep a substantial security deposit until you can get a look at any damage?
Sounds like owning a RV isn't something that fits your lifestyle. Why not just sell it and forget about all the worries.
navegator
San Diego CA.
Posted: 07/20/19 09:50pm Link  |  Quote  |  Print  |  Notify Moderator
I wold like to know the ratio of proffit versus the expenses of the repairs? And that includes the deductibles and insurance premiums.
I will not lend the RV to anyone even my brother is a NO, NO.
navegator
