RV.Net Open Roads Forum: Floor damage - water rot - What can I do!
 > Floor damage - water rot - What can I do!
mwb521
So. Cal
Posted: 07/21/19 04:32pm Link  |  Quote  |  Print  |  Notify Moderator
I didn’t weatherize my Pop Up and the water heater burst. Now the floor has water rot under the floor tile. It seems to be getting worse. The floor continues to get softer. I’m so sad!
What can I do??
Tyler0215
Iowa
Posted: 07/21/19 05:27pm Link  |  Quote  |  Print  |  Notify Moderator
Replace the floor
Merrykalia
Appalachian (apple at chun) Mtn in the GREAT SW Va
Posted: 07/21/19 05:57pm Link  |  Quote  |  Print  |  Notify Moderator
Pull everything out of the box, pull out the rotted wood, replace wood, lay some linoleum down, put stuff back in......TAAAADAAAA, new camper.
2017 Ford F350 Crew Cab 6.7L 4x4 DRW
midnightsadie
ohio
Posted: 07/21/19 06:32pm Link  |  Quote  |  Print  |  Notify Moderator
theres a deal.. or call a local rv tech . not a bad job just some time needed.
mwb521
So. Cal
Posted: 07/21/19 08:48pm Link  |  Quote  |  Print  |  Notify Moderator
I was told it isn’t easy to replace the floor because of the way they are constructed. Is it really that simple?
I would love to bring it to AZ. The PUP is in northern Utah now.
galexander
Omaha,Nebraska
Posted: 07/22/19 05:24am Link  |  Quote  |  Print  |  Notify Moderator
As with any repair job, you really don't know what you have until you get into it. Can be an easy job or it can be a can of worms. If you are handy with tools, then go for it. Take your time, take pictures as you take things apart for when you put things back together and do the best you can. Use a good quality floor replacement, you only want to do this once. Good Luck on whatever you decide on.
2017 Chevy Colorado ZR1 3.6L 4X4 Crew Cab
2020 Cherokee Wolf Pup 14CC
Tekonsha Brake Controller
JRscooby
Indepmo
Posted: 07/22/19 06:39am Link  |  Quote  |  Print  |  Notify Moderator
While it is true everything, including the walls set on top of the floor, and to build as new would need strip to frame. But how big is the soft area? If it is a limited area, get underneath, find a place near the area where you can drill, and measure how thick it is. Now set the depth of skill saw to cut just above the steel, make a hole that removes the rot, and patch the hole.
Acampingwewillgo
Posted: 07/22/19 09:47am Link  |  Quote  |  Print  |  Notify Moderator
I've had the unfortunate pleasure of working on this exact problem a couple of times in a Motorhome. I can't speak to the design in a tent trailer but the fix I did last time was a winner. I did not pull all the furnishings out to accomplish the task although I was able to expose at least two metal cross members in which to start the mending process.
Pull out as much rotten wood as possible, in a tent camper removing large items and cabinets may be an easier task? Make a long story short, I used steel uni strut along with dimensional lumber as my new outriggers thus eliminating all sag. Laid down exterior plywood(3/4" in my case) and since I was going to tile some area's, I put Hardy board down in other area's I used wood flooring. Six years later and all is still SOLID with no cracked time.
96 Vogue Prima Vista
The Kid's: Humphrie, the Mini Schnauzer and Georgie,wire haired dachshund, Senior Cavalier Rosie and Potter
Rainbow Bridge: Laddie,Scoutie,Katie,Cooper,Kodie,Rubie,Maggie, Cassie and Mollie, Elvis Love You!
Rally's and get togethers-Lots
opnspaces
San Diego Ca
Posted: 07/22/19 10:22am Link  |  Quote  |  Print  |  Notify Moderator
What year is the trailer? Is it the Jayco 1206 in your profile? Are you able to crawl under it and see the damage and possibly any kind of structural members near it? If the bottom is covered with a fabric I would try to determine if there is any wet insulation between the fabric and the floor. If there is you're going to have to cut the fabric and get the wet stuff out to stop the rot. I'll bet it's not that hard to repair. But do you have a place to store it and work on it? A garage would be ideal, but at the very least you want to be able to cover it when you're not working on it.
Probably the hardest part of the whole project is going to be documenting disassembly and storing all the nuts bolts and screws in well labeled zip-loc baggies so you are able to put it back together when you are done repairing.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
