RV.Net Open Roads Forum: Beginning RVing: Dumb mistake
 > Dumb mistake
dhulin
Home
Posted: 07/21/19 06:18pm Link  |  Quote  |  Print  |  Notify Moderator
New RV owner. Was at a campsite and wanted to put fresh water in the tank cause the hose was leaky and we didn't want to leave it hooked up so it would get wet everywhere. Well, put the hose in the wrong spot (flush out). It probably only ran a few minutes, cause I was wondering why it wasn't raising the level in the tank, when water started running out from under the trailer and the membrane underneath bulged out! Luckily inside there was no mess. Toilet just filled the bowl. Nothing leaked after that so do you think everything will be okay or should I get it checked out? Lol - I found out the fresh water fill valve is on the other side of the trailer near the front door!
midnightsadie
ohio
Posted: 07/21/19 06:29pm Link  |  Quote  |  Print  |  Notify Moderator
if possible open up what you can under the rv and run some fans. if you need help? call a local rv tech ,they come to you,,smarter than the MCdonald mechanics at the dealership, and cheaper.
Quartzsite AZ
Posted: 07/21/19 07:09pm Link  |  Quote  |  Print  |  Notify Moderator
“and we didn't want to leave it hooked up so it would get wet everywhere”
Staying hooked to city water is always taking a chance leaky hose or not. Fill the FW tank and use it. Safer.
dhulin
Home
Posted: 07/21/19 07:11pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you! It will definitely be a mistake I won't make again!!
BB_TX
McKinney, Texas
Posted: 07/21/19 08:47pm Link  |  Quote  |  Print  |  Notify Moderator
I would be looking to see where that water was coming from. Water should not leak into the belly even from the black tank flush line. Could be a leak in the flush line, or a leak somewhere from the black tank. Needs to be corrected. Otherwise it will likely be an on going problem.
Old-Biscuit
Verde Valley
Posted: 07/21/19 09:36pm Link  |  Quote  |  Print  |  Notify Moderator
Remove underbelly.....
Mold/Mildew issues
Bulging....lot of water in that area
Black Tanks do NOT have overflows so you may have popped the vent or toilet pipe grommet out of cutout if grommets were used. If pipes where glued to tank inlets then you broke something.
Airdaile
On The Road
Posted: 07/22/19 06:11am Link  |  Quote  |  Print  |  Notify Moderator
Up the vent pipe and around it into the basement. There's usually a gap at the top that will allow this to happen.
Jayco-noslide
Galesburg,Il., USA
Posted: 07/22/19 08:46am Link  |  Quote  |  Print  |  Notify Moderator
Funny how we enjoy reading about other's goof ups. We've all done something like that.
Jayco-noslide
John Wayne
Long Beach, Ca
Posted: 07/22/19 11:43am Link  |  Quote  |  Print  |  Notify Moderator
You may want to spray the whole area that got wet with bleach. You are now camping in a hazmat area. Everything came out of the black tank.
John & Carol Life members
01 31'Sea View single slide, F53 V-10 with 134,000 miles and counting.
2012 Jeep Liberty Smi brake system
Security by Bentley
God Bless
KF6HCH
Lynnmor
Red Lion
Posted: 07/22/19 12:07pm Link  |  Quote  |  Print  |  Notify Moderator
That is the only possibility if the rest of the black tank and system is intact. You should pull the vent cap and inspect, if it looks like there should be little or no flow back down outside the pipe, you need to find the issue and correct it.
 > Dumb mistake
