RV.Net Open Roads Forum: Beginning RVing: Dumb mistake
 > Dumb mistake
opnspaces
San Diego Ca
Posted: 07/22/19 12:32pm Link  |  Quote  |  Print  |  Notify Moderator
it sounds like you believe the water is from the overflowing toilet that you have cleaned up. I would go further and investigate it from the bottom to see if there is any wet insulation. You may be able to determine if there is insulation under the floor by simply pushing your finger up against the covering under the trailer and see if you hit solid wood or if there is some give. Anything wet will need to be cut out and removed or it will cause rot.
After it is all dried out I would fill the black tank until it's full and see if there are any leaks. If nothing leaks then drain the tank and go about your life.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
Deb and Ed M
SW MI & Space Coast, FL USA
Posted: 07/22/19 01:53pm Link  |  Quote  |  Print  |  Notify Moderator
Since white hoses are pretty cheap - I would invest in a new hose, too. If any of that tank backed up into the hose, you will regret it next time you fill :-(
stevemorris
ontario
Posted: 08/02/19 05:47am Link  |  Quote  |  Print  |  Notify Moderator
Lwiddis wrote:
“and we didn't want to leave it hooked up so it would get wet everywhere”
Staying hooked to city water is always taking a chance leaky hose or not. Fill the FW tank and use it. Safer.
we just shut the water off at the campground pedestal when not in use
2017 Ram 1500 4door, 4x4, 5.7 l hemi, 8 speed
2008 KZ Spree 260
rvshrinker
Beautiful Pacific Northwest
Posted: 08/04/19 04:35pm Link  |  Quote  |  Print  |  Notify Moderator
Why is city water risky?
drsteve
Michigan
Posted: 08/05/19 07:59am Link  |  Quote  |  Print  |  Notify Moderator
If the water is hooked up while you aren't around and a plumbing leak happens, you can return to a flooded camper. You should shut off city water (or turn off the pump) when you leave for any length of time.
1991 Palomino Filly PUP
philh
Belleville MI
Posted: 08/05/19 09:17am Link  |  Quote  |  Print  |  Notify Moderator
Campground water pressure can vary all over the map... up to the point of breaking water pipes. I've taken to just filling up the onboard tank and running off the internal pump
campigloo
Baton Rouge, La
Posted: 08/05/19 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
Just the first of many to come brother. I’ve been doing this for decades and still pull bonehead stunts. All you can do is admit it and move on.
Happy travels!
LiamBlack
Canada
Posted: 08/16/19 12:34am Link  |  Quote  |  Print  |  Notify Moderator
If possible, send a photo to give more detailed recommendations.
 > Dumb mistake
