RV.Net Open Roads Forum: Class C Motorhomes: Curb weight
 > Curb weight
dbertheau
Scott's Valley, CA
Posted: 08/01/19 05:37pm Link  |  Quote  |  Print  |  Notify Moderator
We have a Thor Siesta 24SS. Also has the Mercedes Sprinter 3500 chassis with the 3L turbo diesel. We tow our 2 door wrangler...it weighs in at just under 5,000. We are a bit over combined GVWR, but take it easy.
The vehicle has enough power and with the braking shared between the Mercedes and the Jeep (via the ReadyBrake system of the toad setup) I don't feel any issues with braking. The tranny temps do rise quicker on mountain inclines with the toad compared to no toad, but I take it slow and easy monitoring the temps (using ScanGauge to monitor). Towing on flat highways the rig is great with the Jeep in tow.
* This post was edited 08/01/19 05:59pm by dbertheau *
2019 Thor Siesta 24SS
2009 Jeep Wrangler Rubicon
2006 Dodge Ram Long Bed -Cummins 5.9L
SOLD 1994 Lance 195 Squire Lite
zb39
slippery rock
Posted: 08/02/19 08:11am Link  |  Quote  |  Print  |  Notify Moderator
What do you have on your wrangler that makes it weigh so much. I have a 2 door JL myself.
Tiffin Zephyr(sold)
2017 Host mammoth, sold
49 states, 41 National Parks, 7 Provinces
2019 2 door Rubicon 6 spd.
2019 Berkshire XLT 45B
way2roll
Wilmington NC
Posted: 08/02/19 08:38am Link  |  Quote  |  Print  |  Notify Moderator
With a GCWR of 15,250 and a GVWR of 11,030 that is a net of 4,200 lbs capacity. That's before you add a drop of water, fuel, a single person - anything. After adding everything you need to travel my guess would be it's overloaded by a 1-2k lbs with the toad. To each his own but I wouldn't feel good about being over capacity by 10-20%. Not trying to be the weight police, but there are reasons the capacities exist. If you are over capacity 1-2k on a DP the percentage is much smaller, but due to the low weight to start with on the sprinter - (and thus smaller brakes, motor (188 hp) smaller frame rails) small variances make up a much larger percentage of the total combined weight. That said, people ignore these capacities all the time without issue. But, know the facts. If you choose to ignore them and have an issue or an accident because of it, well that's on you. I would expect a warranty claim related to a frame/chassis, engine, tranny, brake or receiver issue would be denied.
* This post was edited 08/02/19 12:57pm by way2roll *
dbertheau
Scott's Valley, CA
Posted: 08/02/19 01:37pm Link  |  Quote  |  Print  |  Notify Moderator
Steel bumpers front and back, winch, steel armor under, beefier drag link, tie rod, track bars, control arms, 8-lug wheels and slightly larger tires (full float axles with locking hubs up front), roof rack, etc... This weight also includes the tow bar.
* This post was edited 08/04/19 01:43am by dbertheau *
dbertheau
Scott's Valley, CA
Posted: 08/02/19 01:40pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for your concern.
Torque is 325ftlb. Sprinter braking system is not under designed. Rating for towing is 5,000. GVWR is 11,030. CGVWR is 15,250.
I have scales and I know my weights. Curb weight is significantly less than 11,030. Loaded combined weight is about 250lbs over CGVWR - 15,500.
* This post was last edited 08/02/19 04:05pm by dbertheau *   View edit history
irishtom29
San Antonio
Posted: 08/02/19 05:31pm Link  |  Quote  |  Print  |  Notify Moderator
Lwiddis wrote:
This “getting older” stuff is mental, not physical.
Nonsense. It's very physical for many people.
Racine96
Racine
Posted: 08/02/19 07:31pm Link  |  Quote  |  Print  |  Notify Moderator
You need a different car. Too much weight to make the trip enjoyable.
way2roll
Wilmington NC
Posted: 08/03/19 08:54am Link  |  Quote  |  Print  |  Notify Moderator
Your telling me that despite the specs from the manufacturer and your toad weighing in at 5k lbs, that you are only over by 250lbs? That means the specs on GVWR must be off by a LOT. Like 1,000 lbs. Not sure why they would fudge the numbers to make it worse for the consumer but ok...Or do you weigh like 50 lbs and you travel dry with no food water - well anything really??
dbertheau
Scott's Valley, CA
Posted: 08/04/19 12:10am Link  |  Quote  |  Print  |  Notify Moderator
GVWR is a max load rating...it's not the actual weight of the vehicle.
zb39
slippery rock
Posted: 08/07/19 08:48am Link  |  Quote  |  Print  |  Notify Moderator
Well, OK You have loaded it right up. But I bet it is fun to drive off road. Lots of protection.
 > Curb weight
