RV.Net Open Roads Forum: Truck Campers: My new to me camper.
 > My new to me camper.
Page of 9
specta
utah
Posted: 08/29/19 06:44am Link  |  Quote  |  Print  |  Notify Moderator
I got my Gorilla Grip shelf lining in yesterday and started stocking the camper.
I haven't installed the new generator yet. Its a "direct replacement" of the original Onan but I'm sure it was made in China.
Wiring is different and the exhaust comes out the opposite end as the original.
I'll get that installed next week.
I work out of town this weekend and I'll be using my camper so this will be my maiden voyage. [emoticon]
Kenny
2011 Chevy 2500 HD 6.0L 4wd
6580 lb truck 10540 fully loaded
Carolnma
Santa Rosa, CA
Posted: 08/29/19 01:56pm Link  |  Quote  |  Print  |  Notify Moderator
Wow, you are giving me many ideas for improvements to my 2000 Angler. Thank you for the information and photos!
specta
utah
Posted: 08/29/19 02:51pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks.
Not sure if you call them improvements or upgrades.
I just found nicer stuff to replace all the old worn original stuff.
It has turned out pretty nice to me.
specta
utah
Posted: 09/10/19 09:08pm Link  |  Quote  |  Print  |  Notify Moderator
New generator, its alive!!
I got my new generator installed today.
I replaced the original Onan with a new Onan. I'm pretty sure the new one was made in China but not by Onan.
The exhaust is caddy corner to where the original exhaust was and the electrical connectors are different. Onan does make a harness adapter that connects the old to the new.
The new generator cost double what it would have cost to repair the original one and because the original was 25 years old I just went new.
I'm quite pleased with how everything has turned out.
specta
utah
Posted: 09/14/19 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
Looks like the CAT-Scale didn't know I was towing a trailer. [emoticon]
RobG
Mesa, AZ
Posted: 09/17/19 12:21pm Link  |  Quote  |  Print  |  Notify Moderator
Your camper looks awesome! You've done a great job cleaning it up.
I'm looking at your weight slip... 8060 on the drive axle. Look at the sidewalls of your new tires and see what the weight rating is. I looked it up on Tire Rack and it's 3415 per tire at 80 psi. That's 6830 lbs for both tires. You're 1200 lbs overweight.
It's one thing to be over your axle weight (I do that every time I load my camper), but I NEVER exceed the tire ratings. I hate to be the one to break the news, but you need a dually or a much smaller/lighter camper. Your tires are overloaded, and despite being Michelins, will eventually blow out even if you keep them at 80 psi. They aren't meant for that kind of weight.
2019 Arctic Fox 992 Truck Camper
2006 Keystone Raptor 3814SS 5th Wheel Toyhauler (live in it fulltime)
2005 Dodge RAM 3500 Quad Cab Dually 4x4 SLT 6sp
A quad, a few motorcycles, and a dog.
Bedlam
PNW
Posted: 09/17/19 02:05pm Link  |  Quote  |  Print  |  Notify Moderator
RobG - The scale weighed the rear truck axle and trailer axle together to get that 8K lb result.
Chevy Sonic 1.8-Honda Passport C70B-Host Mammoth 11.5-Interstate Car Carrier 20-Joyner SandViper 250-Kawasaki Concours ZG1000-Paros 8' flatbed-Pelican Decker DLX 8.75-Ram 5500 HD-Tank Urban Touring 150SE-VW TransBuggy 1200
adamis
Northern California
Posted: 09/17/19 03:43pm Link  |  Quote  |  Print  |  Notify Moderator
My first camper was a Lance with almost the same layout (except a Dry bath). I didn't end up creating a lot of memories in it as it ended up having a lot of dry-rot damage. I put $3000 into her before giving up and selling it for something different.
I see that you are working on sealing the roof which is the right place to start. Seal it all and also check the seems on between the roof and the walls (that is where my water damage came in mostly). Also check the skirts at the rear / bottom of the camper to make sure they are sealed well. It is just a piece of plywood that I think had a metal trim piece covering up the leading edge. It didn't fully protect the edge of the plywood from spray from the tires when it was raining.
Lastly, not sure if it matters to you or not but the upper cabinets above the dinette do turn into a bunk, or at least did on mine. A feature I wish I had on my Bigfoot today (apparently it was an option???).
Happy trails and keep the pictures coming!
1999 F350 Dually with 7.3 Diesel
2000 Bigfoot 10.6 Camper
specta
utah
Posted: 09/17/19 11:18pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you. My last camper was full of of dry rot so its going in the garbage as soon as I'm done taking what I want and need off it.
A close friend was a Lance distributor and walked me thru my inspection via phone. I'm very pleased with what I bought and have ended up with.
Yep, the cabinet above the dinette folds down into a bed, something I'll never use as its just me.
The skirts already have some water damage and I'll be addressing that soon.
Its needed a lot of "updating" but its structurally sound.
It does have a wet bath but that's OK with me. It has a lot more room in there than the shower in my other camper did.
specta
utah
Posted: 09/17/19 11:20pm Link  |  Quote  |  Print  |  Notify Moderator
11,640 lbs, 4-6500 ft, 72 mph - 9.72 mpg. I'm happy. [emoticon]
Page of 9
