RV.Net Open Roads Forum: Beginning RVing: Battery Chargers
 > Battery Chargers
Golferdude21
Illinois
Posted: 07/24/19 02:57pm Link  |  Quote  |  Print  |  Notify Moderator
I will be buying 2-6 volt golf cart batteries and wiring in series. For Standalone chargers what do you recommend? There’s 750 MA and one, two, three, four, five amp chargers....etc Noco, Battery Tender, Minder...etc. I don’t care how fast they recharge the batteries because this will be more for winter storage to have them sit on the charger 24/7 throughout many months to keep them topped off. Otherwise during the camping season if you’re using your camper every few weeks I’ve heard the regular on board converter is enough to keep fully charged Without the need of a standalone charger. Aslong as u have a battery shutoff switch. Is this correct? Or do some of you guys use a standalone charger connected to ur batteries on camper 24 seven 365 to keep the batteries topped off?? As I’ve heard that some onboard converters plugged in All the time will fry your batteries
Quartzsite AZ
Posted: 07/24/19 03:02pm Link  |  Quote  |  Print  |  Notify Moderator
Does the regular onboard converter you are considering charge at the battery manufacturer’s recommended voltage for bulk, absorption and float charging? Does it have equalization capacity?
I suggest you don’t guess at how many battery amp hours you need. Do an energy survey. Easiest way to keep your batteries charged is a solar system.
Wherever I happen to park
Posted: 07/24/19 03:50pm Link  |  Quote  |  Print  |  Notify Moderator
Are you talking about maintenance chargers or Camping rechargers or both?
For "Every day recharging" a Progressive Dynamics 9260 is fantastic That is a 3 stage converter and a good size for the GC-2 Pairs. Stage 3 is maintenance
For a slower recharge. (one shot manual restart) and maintenance
I have a big (And I mean BIG) Deltran Battery Tender.
This is not the one I have but... Looks like similar specs
Auto Zone
Home is where I park it.
Golferdude21
Illinois
Posted: 07/24/19 04:00pm Link  |  Quote  |  Print  |  Notify Moderator
Smart battery tender maintainers is what i was getting at. For long winter storage to keep on 24/7 and in between camping trips to keep batteries topped off
Latner
Indiana
Posted: 07/24/19 04:09pm Link  |  Quote  |  Print  |  Notify Moderator
If you have a modern 3 stage converter, you can leave it plugged in year round and not worry about destroying your batteries. Just keep an eye on your water level.
Lynnmor
Red Lion
Posted: 07/24/19 04:16pm Link  |  Quote  |  Print  |  Notify Moderator
I use the Battery Tender Plus 1.25 amp charger on eight seasonal batteries. I am too frugal to buy one for each, so I rotate the one about every three days. I have had exceptional life from those batteries so I'll stay the course. I use the connectors that mates with the Battery Tender on each battery making the change quick and easy.
I don't like to keep an RV plugged in all the time due to possible power problems and lightening strikes.
theoldwizard1
SE MI
Posted: 07/25/19 06:15am Link  |  Quote  |  Print  |  Notify Moderator
Duplicate
theoldwizard1
SE MI
Despite what everyone says, batteries really don't like to be plugged in to a maintainer 24/7 for weeks on end. Your rotation helps extend battery life.
* This post was edited 07/25/19 06:22am by theoldwizard1 *
Matt_Colie
Southeast Michigan
Posted: 07/25/19 07:25am Link  |  Quote  |  Print  |  Notify Moderator
Golfer,
What has not been said here is that the Progressive Dynamics 92XX line were designed to be left powered on and on your bank for as long as you have power available. Though they call it a Three Stage, if you read their documentation, they are actually Four Stage. That fourth stage is a resting maintenance stage that regularly "Burps" the battery to promote electrolyte circulation and prevent sulphation.
This system will not just keep the bank as close to 100% SOC, but will extend the usable life of the bank. After 10 seasons, the house bank (2ae-GC2) were still about 80~90% of original capacity (as determined by my bank monitior). The only reason I replaced them was that I was offered a deal on a pair of new big name jars.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs going to see some dry places that have Geocaches in a coach made the year we married.
Sandia Man
Rio Rancho, NM
Posted: 07/25/19 10:22am Link  |  Quote  |  Print  |  Notify Moderator
Lots of aftermarket battery tender type chargers available which work well for many. I like to just keep it simple and rely on our onboard Iota IQ4 smart converter, with 4 stages it really knows how to keep our batteries very healthy. Our rig is always plugged into shore power while stored in our sideyard, of course I routinely check water levels although they only require watering once a year. Last set of GC2 batteries went 8 years and still had plenty of life in them when we traded them in for another pair that had 30 more amphours.
 > Battery Chargers
