RV.Net Open Roads Forum: Travel Trailers: Foam in tires
 > Foam in tires
Page of 5
Jackathan
Nebraska
Posted: 07/24/19 05:48pm Link  |  Quote  |  Print  |  Notify Moderator
In the dirt bike world, it's called a Bib Mousse. Never thought about something like that for a trailer tire, and I've had many blowouts with ST tires.
ktmrfs
Portland, Oregon
Posted: 07/24/19 08:17pm Link  |  Quote  |  Print  |  Notify Moderator
yup and see what a Bib Mouse looks like and does after an length of time at 60mph or so..... They don't like it. Great for lower speeds, but not high speeds. it give equivalent to about 12-13 psi, so you can imagine what happens as higher speeds.
AFAIK they don't make one for street bikes or other tires other than off road riding.
2011 Keystone Outback 295RE
Bumpyroad
Virginia
Posted: 07/25/19 06:15am Link  |  Quote  |  Print  |  Notify Moderator
consumers reports reported their study showed a 1.3 PSI reduction in air loss for Nitrogen filled tires.
1) it works
2) It's meaningless
3) take it if it is free.
bumpy
CFerguson
on the road
Posted: 07/25/19 09:31am Link  |  Quote  |  Print  |  Notify Moderator
lol. Consumer Reports. lol again.
Science Matters.
BadgerMcAdams
Phoenix, AZ
Posted: 07/25/19 10:45am Link  |  Quote  |  Print  |  Notify Moderator
My question is, if the tires were filled with foam (theoretically to replace the need for air in the tire) then what happens when the tread wears out and you have to get new tires? Would you have to get new rims as well? Seems to me to be a much bigger hassle not to mention greater expense.
Bumpyroad
Virginia
Posted: 07/25/19 11:55am Link  |  Quote  |  Print  |  Notify Moderator
Science Matters.
I am no CR fan myself but I have found their various studies to be fairly well controlled, etc. please quote some studies from your LOL sources proving contrary to their findings.
bumpy LOL
ktmrfs
Portland, Oregon
Posted: 07/25/19 02:22pm Link  |  Quote  |  Print  |  Notify Moderator
IMHO unless it is something like a bib mousse foam is going to quickly disinigrate and you'll have a real flat tire. It has to be able to flex as the tire rolls and compresses on the pavement contact patch. so whatever it is can't be very rigid, it needs to be something that will compress and then relax.
I just can't see anything that will do that and take the heat and last very long.
GrandpaKip
Flat Rock
Posted: 07/25/19 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
Science Matters.
I’ve always found CR to be scientific in most cases. Very little subjective tests other than ones involving taste and hearing.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
GrandpaKip
Flat Rock
Posted: 07/25/19 04:40pm Link  |  Quote  |  Print  |  Notify Moderator
Wind River wrote:
Has anyone heard of or have foam sprayed in your TT tires? Dealer convinced a friend of mine this is the way to go because he will never have a flat tire.
What was that quote from PT Barnum?
whjco
Lexington, KY
Posted: 07/25/19 05:34pm Link  |  Quote  |  Print  |  Notify Moderator
I wouldn't use it. First, the foam could affect the balance of the wheel & tire. Also, if it's a latex base, you're actually adding moisture to the air space in the tire. Some years ago I used Fix-A-Flat on a tire that had a slow leak and, several years later, ended up really regretting it. The moisture that I had injected that was in the latex compound stayed trapped and literally rotted out the rim.
Bill J., Lexington, KY
2006 Starcraft 2500RKS 25' Travel Trailer
2015 Ram 2500 Big Horn 6.7 Cummins.
Page of 5
 > Foam in tires
