RV.Net Open Roads Forum: Tech Issues: 15/30/50 SHORE POWER PLUG IN ?
 > 15/30/50 SHORE POWER PLUG IN ?
Page of 5
time2roll
Posted: 07/26/19 04:58pm Link  |  Quote  |  Print  |  Notify Moderator
If the 50 amp outlet is a standard NEMA 14-50 then you can use a standard 50-30 RV adapter.
Look for the "NEMA 14-50" right on the face of it.
Otherwise do not force anything in or the magic smoke comes out.
675w Solar pictures back up
Dutch_12078
Winters south, summers north
Posted: 07/26/19 08:00pm Link  |  Quote  |  Print  |  Notify Moderator
rk911 wrote:
fj12ryder wrote:
Just get a 50 amp to 30 amp adapter. You plug your 50 amp plug into it and then into the 30 amp pedestal. Easy peasy.
and no, a 50-amp RV pedestal is not 220-volts. it is two separate legs of 120-volts, each leg capable of supplying 50-amps. you can safely connect your 30-amp RV to the 50-amp RV pedestal using the 30-female/50-male dogbone adapter
Maybe you should take a look at the next RV park pedestal you see with a 50 amp outlet. Notice that it has "120/240V" embossed or molded on it. Newer outlets may have "125/250V" on them. You may even notice that it's exactly the same NEMA 14-50 format that 120/240 volt residential ranges plug into. There is nothing special about the outlet or how it's wired for RV use compared to normal residential use.
Dutch
2001 GBM Landau 34' Class A
DSteiner51
Wooster, Oh
Posted: 07/28/19 12:41pm Link  |  Quote  |  Print  |  Notify Moderator
My house has 2 120 volt wires come into my main breaker box and a double 200 amp breaker. Farther down are several double breakers, 1 for the dryer, 1 for the range, 1 for the well pump, and 1 for my 5th wheel. In my 5th wheel the main breaker is again a 50 amp double breaker. If in fact my house is 240 volts and my dryer, range, and well pump, then my 5th wheel is also 240 volts. When I use a volt meter and jump between my two hot bars in my RV it reads 240 volts. Horrors!
D. Steiner
The sooner I fall behind, the more time I have to catch up.
fj12ryder
Platte City, MO
Posted: 07/28/19 12:50pm Link  |  Quote  |  Print  |  Notify Moderator
So if I'm reading this right, if I plugged my RV into the dryer outlet, if it fit of course, no harm would come to my RV because they're both 240 volts? Correct?
Howard and Peggy
"Don't Panic"
rk911
DuPage County
Posted: 07/28/19 12:57pm Link  |  Quote  |  Print  |  Notify Moderator
[emoticon]
Rich
Ham Radio, Sport Pilot
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
philh
Belleville MI
Posted: 07/28/19 06:50pm Link  |  Quote  |  Print  |  Notify Moderator
As a mechanical engineer, I don't deal well in imaginary numbers...
Are RV pedestal 50a circuits single phase or two phase?
vermilye
Oswego, NY, USA
Posted: 07/29/19 08:21am Link  |  Quote  |  Print  |  Notify Moderator
Single phase 120/240V
Jon Vermilye My Travel Blog
My Photo & RV link blog
SoundGuy
S Ontario
Posted: 07/29/19 08:44am Link  |  Quote  |  Print  |  Notify Moderator
Your RV is wired for 120 vac main service, NOT 240 vac. What do you think will happen if you plug your 120 vac trailer into 240 vac source power? [emoticon]
wnjj
Cornelius, Oregon
Posted: 07/29/19 10:20am Link  |  Quote  |  Print  |  Notify Moderator
If your dryer outlet has 4 wires to include a neutral, your RV plug has 4 pins and the plug fits, you are correct.
The trouble starts when people plug 30A 3-pin RV’s into 240V 3-pin dryer outlets.
time2roll
Posted: 07/29/19 10:52am Link  |  Quote  |  Print  |  Notify Moderator
I think the common term is split phase since you can use either the 240v between the hots or 120v from hot to neutral. Although single phase would be correct based on the single coil source. Some call it two phase since the two hots are 180 out of phase from each other. Definitely not three phase.
Page of 5
