RV.Net Open Roads Forum: Weighing Fifth Wheel at CAT Scale with Weigh My Truck App
 > Weighing Fifth Wheel at CAT Scale with Weigh My Truck App
ependydad
Here and there
Posted: 07/26/19 09:57am Link  |  Quote  |  Print  |  Notify Moderator
Cummins12V98 wrote:
Why is your front axle weight so heavy? Do you have a large Diesel tank in the bed?
Light pin, Toy Hauler?
You still have a couple thousand pounds before you hit your RAWR.
Not sure why the front axle is so heavy, though the truck bed is quite full. Nothing super heavy back there, though. A good portion will be people weight in the cab. My front axle weights have always come in like that- just barely under FAWR. I was glad when my 2018 had a higher FAWR than the 2012 had (by 500 or 1000 pounds if I recall correctly).
Yes, toy hauler. No heavy toys, just heavy furniture, kid stuff, and equipment/supplies for my wife's vinyl crafting business.
I'm still under on the truck's GVWR by a couple hundred pounds. And yeah, way under RAWR.
2017 Spartan 1245 by Prime Time
2018 Ram 3500 Crew Cab DRW w/ 4.10 gears and 8' bed
FW Hitch: TrailerSaver TS3
Learn to RV- learn about RVing - Towing Planner Calculators - Family Fulltiming FB page
ependydad
Here and there
Posted: 07/26/19 09:58am Link  |  Quote  |  Print  |  Notify Moderator
K Charles wrote:
I don't use a phone or credit card or email. Drive on the scale, push the call button, when they ask for a name I say private. When they say OK I drive around stop at the office pay the 12 bucks and get the slip.
That was my wife's job. I'd drop her off and then go start unhitching.
Both ways work. I'm glad both are offered as it lets each person choose which works best for them.
ependydad
Here and there
Posted: 07/26/19 09:59am Link  |  Quote  |  Print  |  Notify Moderator
4x4ord wrote:
I use the self weigh scales along our highways. If it was going to cost me I don't think I'd bother getting my weights..... It's kind of like stepping on the bathroom scale ... nice to know but it doesn't change anything.
It changes a lot for me. I suffered a buckled frame back in 2017 while fulltiming and that's an experience that I don't want to repeat.
Right now the rig is a bit overweight which means I need to ensure I'm carrying as little water as possible and follow-thru with purging more.
Super_Dave
Harrisville, UT
Posted: 08/05/19 09:17am Link  |  Quote  |  Print  |  Notify Moderator
Is the self weigh scales the truck scales or port of entry scales? I've never seen self weigh scales before.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 21' North River Seahawk
Learjet
Louisiana
Posted: 08/07/19 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
great right up...due for a re-weight since only weighed new...added batteries and other things...plus have a new tow vehicle.
Luckily I have Cat scales close by ...thanks!!!
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2015 Wildcat 317RL, MoRryde rubber pin box, Titan Disc Brakes, Trojan T105
B&W Ram Companion
Yamaha EF2600c tri-fuel generator
Champion Model 46595- 3000/3500w
Splashers3
Oakville, MD
Posted: 11/04/19 04:50am Link  |  Quote  |  Print  |  Notify Moderator
I had my both the truck's and hitched trailer's tires individually weighed, which is even better than having the axles weighed (which I have also done).
I would recommend this if the situation ever presents itself. The guy then pulled out the tire manufacturer's weight vs tire pressure chart and told me what tire pressures I could safely run instead of the max tire pressure (in my case 110PSI) given the tire weights.
Safety should be a priority and Knowledge is always good.
2017 GMC 3500 Sierra Denali, C/C, D/A, DRW, w/40gal Aux tank, 18K B&W Patriot.
2019 Cedar Creek Hathaway, 34RL2 - w/Bells & Whistles and disc brakes
Traded 2009 Cedar Creek Silverback, GII, 32 WRL
ependydad
Here and there
Posted: 11/21/19 09:55am Link  |  Quote  |  Print  |  Notify Moderator
For folks who prefer videos, I have put this same information together in video form:
https://www.youtube.com/watch?v=_oB68BKFB1s
juzplanekrazy
Riverside Ca
Posted: 02/24/20 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
Did I read that right, that your 2018 Dodge 3500 DRW weight is almost 10,500 lbs ?
I'm not sure, but I'm thinking my 2017 F-350 is 8500 +/-.
Why so much ? Interweb says that thing should be 7000lb ish
Must need to deduct Pin.
2017 Ford F-350 4x4 Dually
2019 KZ Durango Gold 371
Pullrite Super5th
Acdii
Capron
Posted: 06/30/20 08:45am Link  |  Quote  |  Print  |  Notify Moderator
Got to try this out yesterday, pretty slick. First weigh of my F350 with the family so I know what I have for available payload. About a ton. This will save a lot of time on reweighs.
rhagfo
Portland, OR
Posted: 06/30/20 11:43am Link  |  Quote  |  Print  |  Notify Moderator
Have you weighed your DRW ready to go camping? Our 2016 Ram Laramie 3500 DRW has a curb weigh of 8,589# and a payload of 5,411#, but scales at 10,000# ready to tow with me DW, beagle, full fuel and DEF and in bed tool box.
Look at your yellow payload sticker, then subtract the listed payload from the GVWR, that is what your truck weighed off the assembly line. Now start adding people and stuff and it only gets heavier.
