RV.Net Open Roads Forum: Beginning RVing: Correct inflation of trailer tires
 > Correct inflation of trailer tires
rvshrinker
Beautiful Pacific Northwest
Posted: 07/29/19 07:26am Link  |  Quote  |  Print  |  Notify Moderator
Everything I read says tires should be inflated to Max psi. Is there general agreement on that? I plan to do whatever is safest and as of last evening, my tires are at 60 and Max is 80, so I have some filling to do.
SoundGuy
S Ontario
Posted: 07/29/19 07:39am Link  |  Quote  |  Print  |  Notify Moderator
General agreement, yes - total agreement, no. [emoticon] Forum pundits who will claim to be experts on the subject would insist you load the trailer as it would normally be for a camping trip, take it to a weigh station, and measure not just the gross weight of the trailer but also the weight bearing down on each side of the trailer, then adjust your tire inflation to match. The reality is almost no one does this, simply inflating to the maximum imprinted on the tires' sidewall.
MarkTwain
Northern, Ca. , USA
Posted: 07/29/19 07:43am Link  |  Quote  |  Print  |  Notify Moderator
I called my tire dealer (Les Schwab) with the same question. The general agreement is to fill the tires to the max. capacity of your tire. To run your tires at 60 psi could lead to tire damage/blow outs/damage to your trailer and accidents. When I am not towing my 5th wheel trailer I run my tires at about 60 to 65 to make the ride more comfortable.
rvshrinker
Posted: 07/29/19 07:47am Link  |  Quote  |  Print  |  Notify Moderator
To be clear, I'm asking about the trailer tires. I keep my 2017 SRW 3500 in the sixties when empty, at 80 when towing.
Sandia Man
Rio Rancho, NM
Posted: 07/29/19 07:58am Link  |  Quote  |  Print  |  Notify Moderator
For ST tires running them at or very close to max psi supposedly increases their ability to perform as designed, inflated to low causes them to heat up which eventually leads to bubbles and tread separation. We always run our ST tires very near to or at max psi and have had no blowouts or even a flat over the last dozen years, although we dutifully replace our ST tires after 4 years of use. LT tires are typically filled to a psi that matches the load they are carrying, we keep our LT tires filled to the psi stated on the door placard of our Silverado HD truck.
BarryG20
Castle Rock, Colorado
Posted: 07/29/19 08:13am Link  |  Quote  |  Print  |  Notify Moderator
You will get two answers. As you stated max psi stated on the tire or the trailer placard which is more then likely max psi on the tire sidewall for the oem tires.
The other answer is weigh the rig and set the psi per the tire manufacturers load inflation table for that tire. which may or may not be the max psi on the tire sidewall that will depend on the weight they are carrying.
Personally (and I have upgraded the tires on my trailer to a higher load rated tire than came oem) I go by the load inflation tables based on the weight of the axles and I add extra for an additional safety margin.
My trailer came with Ranier 225/75/16 load range d tires with a max load of 2540 at 65psi, my new tires well at the time new were load range e with a max load of 3420. Even at 65 psi (same psi as the max on the oem tires and trailer placard) have a load rating of 3000lbs substantially higher load at the same psi rating. My trailer axles weigh in around 7900lbs for both axles for how I load the trailer so for easy rounding lets say 2000lbs per tire and according to Goodyear's table I can run that at 35psi for a load of 2020lbs. Which is not enough margin for me so I run them at 55 to 60psi which is 2730-2870 worth of load well above the oem tires load of 2540 at 65psi. I get a better ride at the lower psi and still a larger load margin so win win for me in my mind. I am sure someone will tell me I'm an idiot for not running the max 80psi on my (new) tires. However I trust the tire manufacturers knowledge of their tires much more than the trailer manufacturer who does not make or engineer tires.
2016 Jayco 28.5 RLTS
drsteve
Michigan
Posted: 07/29/19 08:20am Link  |  Quote  |  Print  |  Notify Moderator
Inflate to max inflation as shown on the sidewall.
1991 Palomino Filly PUP
spoon059
Just north of D.C.
Posted: 07/29/19 08:27am Link  |  Quote  |  Print  |  Notify Moderator
Tires disintegrate faster due to heat. Heat occurs when you have flex in your sidewall. Some flex is necessary, but excessive flex leads to increased heat which leads to increased chance of tire failure.
I buy trailer tires that are rated much higher than I need them. Then I keep those tires inflated for their maximum weight carrying capabilities. When I check my tire and hub temps at fuel stops, they are usually just a little hotter than ambient temps. That is my objective.
2015 Ram CTD
2015 Jayco 29QBS
BB_TX
McKinney, Texas
Posted: 07/29/19 08:48am Link  |  Quote  |  Print  |  Notify Moderator
Even tire different manufacturer web sites don’t agree. Some provide recommended tire inflation charts based on loading. And from a maximum rubber to road contact viewpoint, and therefore maximum traction, that certainly makes sense. But it also means you have to know the weight on each tire. Other sites simply say inflate to the max pressure as stated on the sidewall. That is probably the safest approach, and certainly the easiest. Downside is that if the weight on the tire is far less than the max load rating, there would less rubber contact to the road as the tire tread would be more rounded, the tire may wear faster in the center of the tread, and the ride could be harsher due to the tire being harder.
Take your pick.
BarneyS
S.E. Lower Michigan
Posted: 07/29/19 08:49am Link  |  Quote  |  Print  |  Notify Moderator
I have been inflating my trailer tires to the max as indicated on the sidewall for over 30 years and have never had a tire problem. Trailer tires (especially dual axle trailers) are under a lot different conditions than truck or automobile tires. Inflating them to the max makes them more able to withstand the harsh conditions they operate under.
Barney
2019 Ram Limited 1500, 5.7L Hemi, 4x4, SB
Not towing now.
